Body Lift Required On Passenger Drop 23 Spline Duals In '99 4Runner?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-01-2007, 12:30 PM   #1 (permalink)
Member # 2538
I'm planning to start a build up on my 3rd Gen. 4Runner (1999 model with the 3.4L and manual trans).
B/c I want to run a passenger side drop D60 front axle to work with a passenger drop 23 spline dual ultimate Marlin (2.28 & 4.70 gears)....I need to find out if I definitely MUST run a 1" or 1.5" body lift in order to clear the gear driven cases on the transmission tunnel?
Thanks,
Sean
Education is what you get when you read the fine print. Experience is what you get when you don't.
Sean is offline   Reply With Quote
Old 06-01-2007, 01:08 PM   #2 (permalink)
Banned
Member # 72658
Id say its going to depend on how much floor modification your willing to do. A 1" body lift will minimize the amount of pounding you'll need to do but there is only one way to really know for sure... start fitting parts and be prepared to use the BFH. I had to pound just to run dual cases on my IFS Tacoma, so yeah, your going to need to do some pounding but its not the end of the world.
highplainsdrifter is offline   Reply With Quote
Old 06-06-2007, 12:50 PM   #3 (permalink)
Twisty4runner's Avatar
Member # 18322
I am running a 1.5" body lift to clear the same dual set up, no tunnel mods needed.
2000 taco
sas'd
36's beadlocked
other goodies
Twisty4runner is offline   Reply With Quote
Old 06-07-2007, 07:39 AM   #4 (permalink)
Banned
Member # 72658
Mine is clocked 20* with a 1" body lift and needed a little coersion.
