oil pan ?/problem - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-24-2007, 08:56 PM   #1 (permalink)
Member # 87990
oil pan ?/problem
working on 2000 4x4 tacoma
putting a 2001 4cyl 2rz motor(2wd) into a 2000 4x4.
The oil pan is hitting on the front diff on the drivers side before reaching the motor mounts.
Does the 3rz motor that came in the 4x4 have a different oil pan? What can i do?
bbbddd is offline   Reply With Quote
Old 06-24-2007, 09:58 PM   #2 (permalink)
Member # 91768
Send a message via AIM to toySA
4x4 pans and 2x4 pans are usually always different. Look for a another pan at a junkyard
"I am clearly the driver, you are supposed to provide intel, you have not done that"
toySA is offline   Reply With Quote
Old 06-25-2007, 08:13 AM   #3 (permalink)
Member # 86672
why are u putting that pan on it? are u doing a SAC or is your other one busted....i just did my SAC and have my factory 3rz oilpan off a 4wd if you would want it
tacoma87 is offline   Reply With Quote
Old 06-25-2007, 09:16 AM   #4 (permalink)
Member # 87990
my 4x4 was stolen and they took the motor and tranny. I'm tring to rebuild cheap and found a 2rz. Tried to put it in yesterday and found oil pan hits. what's? SAC Will the 3rz 4x4 pan fit on the 2rz motor?
Old 06-25-2007, 11:14 AM   #5 (permalink)
Member # 86672
whats a 2rz is that teh same as a 22r? if its a 22r then i dont think the 3rz 2.7L will work. a SAC is solid axle conversion and you need a different oil pan because the drag link hits the oil pan on tacomas because of there forward sump.
Old 06-25-2007, 02:12 PM   #6 (permalink)
Member # 87990
the 2rz is the 2.4 liter that they put in the 2wd. 3rz 4x4. I think it is the same block but the 3rz has a longer stroke. I'll call toyoyta to find out. what do you want for the oil pan?
Old 06-25-2007, 08:20 PM   #7 (permalink)
Member # 86672
i doesnt matter whatever u think is fair and i will check on shipping if u give me ur zip code
Old 06-25-2007, 08:41 PM   #8 (permalink)
Member # 87990
what year is it? checking with toyota tomorrow to make sure it will fit. zip 85027 THANKS
Old 06-26-2007, 05:02 AM   #9 (permalink)
Member # 86672
98 toyota tacoma 4wd 5 speed
Old 07-04-2007, 12:02 PM   #10 (permalink)
Member # 87990
toyota says it will work. did you check on how much it will cost to ship to 85027?
