'96 gear ratio - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-28-2007, 07:49 PM   #1 (permalink)
Member # 94151
'96 gear ratio
anybody know what the gearing is in the rear axle of a 96 2-by? ive looked everywhere (including not on this site). maybe im a tard but i got nothing. i wanna run 33's and i want to make sure i have a ratio that could handle it. cuz i know theres more to big tires than just wheel-well clearance.
i<3fo'runners is offline   Reply With Quote
Old 06-28-2007, 08:46 PM   #2 (permalink)
locotaco85's Avatar
Member # 39143
Send a message via AIM to locotaco85 Send a message via Yahoo to locotaco85
http://www.pirate4x4.com/forum/showp...45&postcount=3
Depends on engine and transmission selection, along with other variables. You should be able to figure it out with the gear ratio code chart.
locotaco85 is offline   Reply With Quote
Old 06-28-2007, 09:49 PM   #3 (permalink)
Member # 94151
i have a 2rz 2.4 cyl and a 5 speed manual (cant remember off top of my head which one). think ill be cool?
Old 06-29-2007, 06:32 AM   #4 (permalink)
locotaco85's Avatar
Member # 39143
That would depend on the gear ratio... if it has something like 3.55 in the rear, your truck will hardly move with 33s on it. I have a 3RZ and 5 speed, with 4.10s and 33s, and it does pretty good, but it's far from fast.
Old 06-30-2007, 06:42 PM   #5 (permalink)
Member # 94151
thanks thats what i needed to know
Old 06-30-2007, 07:01 PM   #6 (permalink)
Member # 94151
k according to the chart mine is 6.78, however i have never heard of such a high ratio. what the hell does this mean?
Old 06-30-2007, 08:10 PM   #7 (permalink)
locotaco85's Avatar
Member # 39143
That ain't quite right... :huh:
You can always use the old 'jack up one tire, spin the tire and count driveshaft revolutions' method. That's rather foolproof.
If I had to guess, I'd say you likely have 3.90s, or more likely, 4.11s.
Old 06-30-2007, 09:59 PM   #8 (permalink)
Member # 94151
just jack up one tire? i jacked up both, popped it in neutral, spun the shaft,and tried to count. but when i spun the wheel i got like a little over two rotations of the shaft. shouldnt the shaft spin whatever the ratio is for one rotation of the wheel? maybe it didnt work cuz i had both up.
Old 06-30-2007, 10:01 PM   #9 (permalink)
Member # 94151
cool. i wonder if it makes that detrimental of a difference with a 2RZ though.
Old 06-30-2007, 11:26 PM   #10 (permalink)
locotaco85's Avatar
Member # 39143
With an open diff, if you spin one tire, the opposite side will usually spin the opposite direction instead of the driveshaft moving at all. From "Erik's Toyota Differential Info" in the aforementioned link:
For "open" diffs:
* Block the tires at one end of the vehicle to keep it from rolling, and then jack up a tire on the other end.
* Place the transmission in neutral and release the parking brake if you are checking the rear diff.
* Spin the tire exactly TWO full revolutions while at the same time counting exactly how many revolutions the driveshaft spins (marking the driveshaft and tires beforehand will make it easier to count revolutions).
* The number of revolutions the driveshaft spins is your gear ratio.
If it spins just over 4 times, then the ratio is probably 4.10; 4-1/3 = 4.30; 4-1/2 = 4.56; just under 5 = 4.88; 5-1/3 = 5.29, etc."
I would imagine even the 4.11s would be marginal with the smaller 2RZ, as would 3.90s. With anything (numerically) lower, it would suck- no low range and a tall first gear with little torque like that would suck ass off road. Take advantage of the fact that you only have one axle to put gears in, and put in a locker and some 4.88s.
Old 07-01-2007, 10:09 PM   #11 (permalink)
Member # 94151
right on im gonna check, i think its 4.11. and i really think im gonna take advantage of my single axle do like you said. appreciate the help greatly.
Old 07-07-2007, 12:56 PM   #12 (permalink)
Member # 92921
Try these 2 links. They might be helpful.
http://home.4x4wire.com/erik/diffs/
http://www.brian894x4.com/Gearratiosanddiffs.html
RangerCB is offline   Reply With Quote
