4" Lift Kit - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-29-2007, 10:16 PM   #1 (permalink)
Member # 94473
4" Lift Kit
I currently have 33x11.50x16 with a 3" lift. They rub on my frame. A 4x4 shop told me a 4" lift would cure my problem and I could run 33x12.50x15, since I hate my OEM wheels and I would like to get aftermarket wheels. What do you guys think, will the 4" lift solve my problem? The only 4" lift kit I found for my 2004 Tacoma 4x4 TRD V6 is the Procomp 4" which does not require the crossmember to be cut... Any ideas would be appreciated.
markie is offline   Reply With Quote
Old 06-29-2007, 10:44 PM   #2 (permalink)
Member # 75624
I would run rims with a better backspacing... like a 3.5 to get them away from the frame. Should help, but may cause problems in other areas.
2003 Tacoma
sonofmayhem is offline   Reply With Quote
Old 06-29-2007, 10:52 PM   #3 (permalink)
Member # 94473
I am trying to stay away from backspacing and use an offset. The shop told me that because the tire is 33" it will rub no matter what with a 3" lift... Is this true?
Old 06-29-2007, 11:08 PM   #4 (permalink)
Member # 75624
Check out ttora.com lots of people run 33s with 3in lift. The cheaper way is some aftermarket rims that will just move the tire from the frame. or look for some 33x10.5s
Good luck
2003 Tacoma
Old 07-07-2007, 08:36 AM   #5 (permalink)
Member # 64089
Send a message via AIM to 800MJ
ha ha ha! after all that shit i read about you boasting of your truck on ttora, your tires rub on your frame??!!! HA HA HA. are you sure toyota warrantied that "3 inch toytec lift with micky thompson rims" frame rub included?? if you got the time, read up peoples. goooooooood shit
Originally Posted by Toyotaholics.com View Post
You're the troll from TTORA. Yeah, the guy who rips on for sale posts and asks stupid questions and tries to be a badass all the time.
Do you really want me to post links to your stupid ass threads???
See, you're this guy:
http://www.ttora.com/forum/showthread.php?t=64930
My personal favorite qoute:
http://www.ttora.com/forum/showpost....02&postcount=8
Some more:
http://www.ttora.com/forum/showthread.php?t=73100
http://www.ttora.com/forum/showthread.php?t=73098
True trolling here:
http://www.ttora.com/forum/showthread.php?t=62420
Please pull your head out of your ass. Pirate is not like TTORA. Its way above your head. Leave dipshit.
[QUOTE=roastbeef;10323284]last night, this girl was sucking my dick and she stated licking my balls and then she starteld likcing my ass. i almost nuttd right on top of her fucking head before i got to stick it in her.
im drunk.[/QUOTE]
[QUOTE=sucker;10784484]ok straight six and reliable don't go together. But have fun with that one.[/QUOTE]
800MJ is offline   Reply With Quote
Old 07-07-2007, 11:20 AM   #6 (permalink)
Member # 87189
i have a 2.5 inch lift and run 285/75/16's on black steelies with 3.75 backspace. minimal rubbing, no rubbing on the frame at all. if you are 4wd and ADD you shouldnt raise it much more without a drop bracket...but those are gay.
ECV 1069
badmoonrising is offline   Reply With Quote
Old 07-15-2007, 05:50 PM   #7 (permalink)
Banned
Member # 72658
First off, find a new shop.
Second, stock backspacing is 4.5" which is very close to the frame. Your front tire will rub the frame nomatter what with 33's, but it will rub a whole lot less if you get some wheels with a 3.75" backspacing. With the right backspacing and some trimming you should be able to run 33's with 3" lift and not too much rubbing off road.
highplainsdrifter is offline   Reply With Quote
