3.4 missing/stumbling - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-05-2007, 08:47 AM   #1 (permalink)
red85runner's Avatar
Member # 64095
the 3.4L in my Taco has ran flawlessly for 127,000 miled, but now all of the sudden is running like crap. It has a miss or a "stumble" so to speak when accelerating under, and when cruising 50 or 60 barely on the throttle itll start hiccuping.
Well my check engine light is on, and i plugged it up and it says i have a Cylinder 1 Misfire. Well that Misfire could be pretty much anything correct? i Checked to see if i have spark to the plug, which i did, so then i replaced the spark plug just to be sure. then i ran a bottle of fuel system cleaner through it, which did no good. The haynes manual i have is kinda broad on troubleshooting, and im currently sorting through an online FSM, but i know yall would know where to start looking better than i would.
so possible causes could be?
Clogged or faulty injector
Timing belt slipped and now timing is off
Distributor cap or rotor (assuming it is a normal distributor? the way the ignition is on this engine has always confused me)
ECU went bad all the sudden?
PCV valve?
so any suggestions on which to start with?
red85runner is offline   Reply With Quote
Old 07-05-2007, 09:04 AM   #2 (permalink)
Member # 64095
so after a little more research on other forums its looking like it would be plug wires, even though its sparking it might be causing a misfire, if it is not that then a coil pack? which is one of the things i dont really understand. Any suggestions?
Old 07-05-2007, 09:04 AM   #3 (permalink)
Member # 30542
My cousins 3.4 has done that a couple of times. Try cleaning the Mass Air Flow sensor. That worked the last time. He also had the dealer do a Top End cleaning when it was crapping out a while back. Yours sounds like what his was doing.
www.rebelrockrunners.org
97 Tacoma-Duals,Tons,Coilovers,40's.... still not done
tnxjjeeper is offline   Reply With Quote
Old 07-05-2007, 01:06 PM   #4 (permalink)
Member # 19077
Try swaping the #1 plug wire to a different cylinder, If the Misfire stays with cyl #1, you can safely assume that the plug wires are OK. If the misfire is still on cyl #1 try swapping the coil pack to a different cylinder. Again, if its the coil pack, the misfire should follow the coil pack. Oh, and clean you MAF sensor for good measure.
yotamasters.com <-------- NEW WEBSITE IS HERE!!!!!
Max Volume is offline   Reply With Quote
Old 07-07-2007, 12:43 PM   #5 (permalink)
Member # 92921
Don't forget to do compression test, could be a bad intake valve on that cylinder
RangerCB is offline   Reply With Quote
Old 08-20-2007, 01:47 PM   #6 (permalink)
Member # 45011
The coil pack was the problem for my tacoma with the same problem.
77 FJ 40
90 2-door 4Runner
94 7M-GTE 4Runner :-)
95.5 Taco
aferg is offline   Reply With Quote
Old 08-21-2007, 10:23 AM   #7 (permalink)
Renaud33's Avatar
Member # 23389
Send a message via AIM to Renaud33
My truck has had a "surging" feel to it every couple of seconds when cruising on the highway. Doesn't happen all the time though. Or maybe not enough to be noticable all the time. A few buddies thought it was a worn timing chain/belt. Haven't replaced it yet so I don't know for sure. Perhaps if you find your wires and coil working properly you need to replace the timing chain/belt?
85' 4Runner - AP extreme lift, 37" PB Rockers, duals
TLCA Member# 16265
Renaud33 is offline   Reply With Quote
Old 08-21-2007, 03:08 PM   #8 (permalink)
Sometimes I drink
SinisterTaco's Avatar
Member # 39343
http://www.deserted1.com/FSM/Repair_...e/cip0300p.pdf
http://www.deserted1.com/FSM/Repair_...g5vzfe/pst.pdf
-Thomas
SinisterTaco is offline   Reply With Quote
Old 08-22-2007, 11:07 AM   #9 (permalink)
Member # 93054
O this is an easy one. my 97 taco did the same thing, turns out its just the o2 sensor. if thats not the fix i don't know what to tell you.
My Build: [URL="http://www.pirate4x4.com/forum/showthread.php?t=695669"]http://www.pirate4x4.com/forum/showthread.php?t=695669[/URL]
RockToy94 is offline   Reply With Quote
