Tacoma Help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-20-2007, 03:31 PM   #1 (permalink)
Member # 40436
Tacoma Help
Ok so my girlfriend just bought a 96 2wd tacoma with a 3" fabtech lift kit and add leafs in the rear. However being a jeep guy I don't know much about toyota's so I was wanting to know if there anything we can do to make the ride not so stiff?
Would some new shocks front and rear help? or should I take the add leafs out and put a new leak pack in?
Any help would be great.
thx
Quik 99 is offline   Reply With Quote
Old 08-20-2007, 03:59 PM   #2 (permalink)
Member # 96786
thx
Definitely ditch the add a leaf and go with a new spring pack.
As for the front, not sure what spring they Fabtech kit is using, or if they are just cranking down the torsion bars, but a new spring pack out back will soften up your ride a lot.
zmtnbik is offline   Reply With Quote
Old 08-20-2007, 04:35 PM   #3 (permalink)
Sometimes I drink
SinisterTaco's Avatar
Member # 39343
No torsion bars on the Tacoma.
Probably a spacer up front. Going back to stock or switching to a coilover will yield the softest ride.
-Thomas
SinisterTaco is offline   Reply With Quote
Old 08-20-2007, 04:48 PM   #4 (permalink)
Member # 86863
Maybe you meant reducing the preload on the CO's ?
This is most likely the case... and fix
'00 Tacoma 4X 3.4 manual trans and some extras...
TacoDell is offline   Reply With Quote
Old 08-20-2007, 04:53 PM   #5 (permalink)
briansc33's Avatar
Member # 80201
I beleive that the only Fagtech lift's made for the Tacoma were either drop bracket, or adjustable CO's. The previous owner may have stacked a spacer on top of the CO though .
Ditch the AAL, check the front CO's to see if they've got a spacer on top, and see how far they're cranked up. If they're cranked too high (more than 2.5") that will make the truck ride like a ton of shit.
I thought this was a hardcore 'wheelin board
Back to where I came from.
Tacoma thing, 37's, duals, some tube, 'n things 'n stuff.
briansc33 is offline   Reply With Quote
Old 08-20-2007, 04:54 PM   #6 (permalink)
briansc33's Avatar
Member # 80201
You type much faster than me
Old 08-20-2007, 05:18 PM   #7 (permalink)
Member # 40436
It has a 3" fabtech with CO's and I'll check to see how high there turned up.
As far as being this thread not being "Hardcore" sorry man I was just looking for some quick answer's and I know that this board is the best, so thx for everyone's ideas.
Does anyone know which spring pack would be better?
Jeremy
Old 08-20-2007, 05:28 PM   #8 (permalink)
Member # 86863
OK... I'll only use one finger instead of two... from now on...
Old 08-20-2007, 05:37 PM   #9 (permalink)
briansc33's Avatar
Member # 80201
Jeremy
Naw, just givin' some shit.
I ran OME's for about three years, 'wheeled the hell out of them and was very happy with how they performed. Some will tell you Deavers, and although pricey you can't go wrong with Alcans........Those (for the money) would more likely be seen on a rig that is on the trail quite a bit.
Old 08-20-2007, 05:39 PM   #10 (permalink)
Member # 86863
Jeremy
At least you don't have the drop bracket... so it's all good...
But those basic fabtech co's really blow... lose those for something better... SAW/Racerunner 2.0's and some Alcans out back... I run the Deavers... And like them alot... But the Alcans can be ordered with 1/2" more arch for the drivers side to compensate for the heavier drivers side... at no extra charge... the Deaver's will cost more... and you'll be charged extra if you want the drivers side to have more arch (custom required)... If you don't get the 1/2" extra for the drivers side... you'll be having to compensate increasing the pre-load on the drivers front coil... Unless you don't mind a drivers lean... then worry not...
Old 08-20-2007, 05:43 PM   #11 (permalink)
Member # 86863
See... if I use one finger... you type faster then me... LOL
Old 08-20-2007, 05:50 PM   #12 (permalink)
briansc33's Avatar
Member # 80201
I've got a finger for 'ya....Make that two
At least we're getting some tech (kinda) in this folder!
Old 08-20-2007, 05:55 PM   #13 (permalink)
Shefron's Avatar
Member # 80692
We'll get alot more in a couple of months. Just wait till the plasma cutter arrives
Steel Shooting Targets
Custom cutouts on request
AR500 plate for shooting targets
Now cutting 80% tomahawk for the DIYer
Shefron is offline   Reply With Quote
Old 08-20-2007, 06:12 PM   #14 (permalink)
Member # 86863
Nice fingers... But they don't type fer shit...
First thing I saw coming over here was that Exodus Thread... thought I was in the twilight zone and was thrown back into TTORA zone...
Not that any of this shit matters to me... tech would be nice tho'
But the best tech... is on the trail... were I'll be mostly...
Example... last saturday Mike Wood blew a rod end thru his 3.4L block... we were being all techy trying to figure out what happened... I guess the hole in the side of the block answered the tech question of the day... yes we cleaned the trail up ( dirt tech )
