wiring electric 4wd - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-13-2007, 02:42 AM   #1 (permalink)
Member # 52753
wiring electric 4wd
Ok so the tranny I got for the conversion was suppose to be a manual 4wd and high/low range. Well the guy didnt really think through it and its a manual high low but electric 4wd.
Anyone know anything on wiring them? Intrex on TTORA did one. I asked him about it and he said he'd find the actual diagram he used.
Basically the way it works is there is a motor that engauges and diseng. 4wd. Polarity one way then the other for eng/diseng. Then there is a sensor that tells it where to stop, or I am under the impression of anyhow.
Anyone have any info?
Tacoma_Kyle is offline   Reply With Quote
Old 09-17-2007, 11:10 AM   #2 (permalink)
Banned
Member # 14006
It's really really close to the E Locker, Kyle. The same kind of actuator circuit is used on the rear E locker, push button 4WD and the front axle actuator in later model tacos when they went away from vacuum. You could probably get my locker control off the TTORA board Wiki and start with that.
Of course you could always yank the actuator and rig up some kind of shifter if it gets down to it.
Dickfoster is offline   Reply With Quote
Old 09-19-2007, 01:58 AM   #3 (permalink)
Member # 52753
Thanks for the info. I'll go check it out.
Old 09-19-2007, 09:47 AM   #4 (permalink)
Banned
Member # 14006
If I had an FSM for the model you have I could help if it gets down to it. If you live anywhere around me I could pitch in if you need it.
Old 09-19-2007, 12:19 PM   #5 (permalink)
Member # 52753
I'm a little north. Thanks for the info though, I found the TTORA one and found the 03 FSM diagram. Oughta be pretty much the same as the onr I have (FSM). I havent really looked into it too much as it was late last night.
Old 09-20-2007, 02:14 PM   #6 (permalink)
Banned
Member # 14006
Oh now I see. Yep Oregon is a fair hike, not a huge hike mind you but a fair hike.
