#701 (permalink) |
H M F
Member # 8758
You can feel the effects of a panhard at speed through the bumps if you are either cycling a lot of travel or have a really short panhard (axle and body moving opposite directions).
You can also play with the angle/height of the panhard to virtually eliminate body roll. For the lower links, who says you can't run them just like the lowers on your 4 links? Or are you just trying to keep it simple and use the TG parts? Honestly, I seriously doubt you'll be able to feel the difference between the 2 setups. I bet the biggest difference will be from the coilovers. You've been running 1/4 ellip on all the 4 links, right? The CO's are always pushing out, nuetral is full extension. Causes some quirky stuff, kinda sucks going down trails without a rear winch to the axle. But with the right tuning, winch, limit straps and maybe a sway bar, it should be sweet! Last edited by Im4yotas; 03-08-2008 at 12:54 PM. |
#702 (permalink) | |
DuCaTi MoNsTeR
Member # 2931
i was super leary of running 4 coilovers on this truck from the get go and getting lost in the valve pack tuning, spring rates, etc...i originally had the fox coilovers without the springs on them and trail gear 3'' rear leafs....hopefully i dont end up with a big mess and frustration do to my leaps and bounds of changes in suspension setup that im not familiar with...yes, all my other trucks were 1/4 eliptical with little compression travel and no need for a sway bar or valve tuning, spring rate was obviously easy to change...
Amongst the best of the toyota vendors: Www.4wheelunderground.com Www.addictedoffroad.com Www.hellfire-fabworks.com Last edited by Booger Weldz; 03-08-2008 at 01:01 PM. |
#703 (permalink) |
H M F
Member # 8758
Good news for you, BV just posted the 1st installment of his coilover bible!
![]() http://www.pirate4x4.com/tech/billav...lovers/Part_1/ From what I understand with co's (I've only played with air shocks and emulsion shocks), it's not that hard to tune things to work "just fine" but when you are trying to get the most performance possible, it starts getting tedious. The only part that worries me is selecting the right coils. Seems like everyone gets them wrong the first couple times, and they aren't cheap to keep buying... |
#704 (permalink) | |
DuCaTi MoNsTeR
Member # 2931
Amongst the best of the toyota vendors: Www.4wheelunderground.com Www.addictedoffroad.com Www.hellfire-fabworks.com |
#705 (permalink) | |
Grocery Getter
Member # 59
I'm swapping my slightly bowed 1.5x.120 + 1.25x.250 (1.5x.375) Rockstomper TR for a 1.75x.250 TR that is stronger and a little lighter. Got my rear links done yesteday. Now to work on shocks/bumpstops/coils/airbag. |
#706 (permalink) | |
DuCaTi MoNsTeR
Member # 2931
![]() if what you say is true, we'd all be runing 4'' OD .120 wall links, no? if your right, i hate you for telling me this after ive got it all welded up
Amongst the best of the toyota vendors: Www.4wheelunderground.com Www.addictedoffroad.com Www.hellfire-fabworks.com Last edited by Booger Weldz; 03-09-2008 at 08:39 AM. |
#707 (permalink) |
Member # 8286
I dont like panhards because of the side to side movement it causes in the body. If you get big wheel travel with a panhard you will typically get a lot of side to side swing of the axle when going through vertical wheel travel. This causes the body to shift side to side.
If you run front and rear panhards and they are opposing the body will pivot through wheel travel. If you run the panhard bars the same way it will corner different each dirrection. This can be particularly noticable if you have a lot of body roll. I have driven a TJ with panhards front and rear and it is noticable with 12" of wheel travel. I have also heard other people compain of the same thing. If you just want to go rockcrawling then a panhard will be fine. If you want to go fast through the woops I would reccomend a really long, flat panhard or a triangulated suspension. I am on V2.2 of my rear suspension & V3.0 will eventually happen. Since you have already started you may as well finish it. If you dont like it then you can change it down the road. And next time someone asks the question you can be the authority on the matter
-Ryan |
#708 (permalink) |
Grocery Getter
Member # 59
If I did the calculations right,
1.75x.250 wall is 4.0lbs/ft and has a MOI of .341 1.5x.750 wall (solid) is 6.0lbs/ft and has a MOI of .249 The first is 37% stiffer in bending and 33% lighter. Don't hate! ![]() 1.5x.250 wall is 3.34lbs/ft and has an MOI of .199 By adding the solid rod to yours you added 20% to the strength, but 80% to the weight! ![]() Think about this: You could jump on a 6' chunk of 1" rod and bend it pretty easily, but not some 1.75x.120, even though the 1.75 is actually less steel. 1x.5 (solid) is 2.67lbs/ft 1.75x.120 is 2.09lbs/ft You can see it in the numbers: The MOI of 1" solid is only .049, while the 1.75 is 2.05. That's 4 times stiffer in bending... and its lighter! ![]() Yes, there is a balancing act between wall thickness and kink/dent resistance, as well as diameter since you don't want to have a giant tube for clearance issues... but I think .188 and especially .250 is pretty hard to dent in the diameters we are working with. ![]() MOI and lb/ft calcs here: http://www.pirate4x4.com/forum/showp...7&postcount=59 MOI (moment of inertia) is a bend strength calculation. The 4-link calculator uses it on the materials tab (along with material property and link length) to find the bend strength of your link. The 4-link calc is the easiest way to calculate the MOI and lbs/ft by just plugging in the material dia/thickness. For lbs/ft just make your link length 12" or divide the link weight by the link length in feet (42"=3.5', etc.). If you read that thread you'll see why I'm using square tube for my lowers.
#709 (permalink) |
Member # 38006
So, do you thing a single piece of 1.5 x .250 DOM would be strong enough for a Panhard bar? the reason I ask is I'm building an almost identical rig, and just trying to save some $$
Thanks Joe
Better to have it and not need it, than need it and not have it. |
#710 (permalink) | |
Member # 73963
I am building 42's and 1 tons under a turbod 96 lx450 right now. ARBed d70 with radius arms and panhard in rear and 3link with panhard ARBed d60 front. my front is congested and has packaging issues similar to yours. You certainly know what you're doing more so than myself and so I pose a question more for my benifit than yours: What would happen if you were to offset your axle side panhard mount farther in front of the axle so as to allow easier clearance between the panhard and diff cover so to allow the panhard to drop lower and avoid the oilpan? In other words: why not move the entire panhard assembly forward? what complications does this present?
IFS build http://www.pirate4x4.com/forum/showt...ht=starfighter turbod the Lexus http://forum.ih8mud.com/80-series-te...rbo-build.html Tons and 42's on the Lexus http://forum.ih8mud.com/hardcore-cor...j80-build.html |
#711 (permalink) | |
Grocery Getter
Member # 59
What I did on mine is moved just the frame end mount forward so that the PH clears the diff cover when the axle stuffs, but the axle end mount still isn't forward/longer. The axle end is probably 2" in front of the axle and the frame end is probably 8" in front of the axle. Drag link is similar, so the geometry doesn't affect the steering. ![]()
#712 (permalink) | |
Member # 6892
So which do you say is a better option, mounting them off the same side of the frame or mounting them off different sides of the frame? In your opinion what length constitutes a really long panhard?
Yarr! I've been to the Hammers... There in the tool section at Home Depot. Rally for The Hammers post #141 Rally for Tellico post #100 Last edited by Blue-Beard; 03-11-2008 at 08:38 AM. |
#713 (permalink) |
Member # 8286
if you look at the vehicle from the top view. While traveling over a big roller for example. As the suspension unloads the chassis will rotate.
Mounting them opposite is your best bet. A long panhard would ideally keep the maximum angles under 10 degrees each dirrection. Shifting the panhard too far forward can, in extreme situations, cause weird shit to happen. But again, it is all dependant on your other geometry.
-Ryan |
#714 (permalink) |
DuCaTi MoNsTeR
Member # 2931
thanks for all the help for sure! trd, im4toyotas, erik....
![]() erik, im cool with the solid tie rod, it is much greater resistant to denting, which eventually will bend...you would know better than i having run high steer all my wheeling, but im sure a tierod in regualr crossover steering is just as prone to destruction by rock hits as a set of lower links are. once you dent them, your done sooner or later(much sooner)as they will bend @ the dent, if the solid adds in dent resistance, its worth its weight for sure... after reading the article you posted i could have made my links in 1/4'' wall square 2'' or 2.5''(free at work), instead of the few hundreds ive spent on thick walled DOM tubing over the last few builds...a few companies even sell threaded inserts for square tubing(rod ends) i also made an adjustable link that can be changed in size to fit any of my links and also the tie rod location in emergency.........it also fits the lower link location on the red rocket 4runner i sold my friend, and i believe 408 jiggas one ton trucks lowers(we all wheel together and can share a spare in a time of need)...
#715 (permalink) | |
DuCaTi MoNsTeR
Member # 2931
#716 (permalink) |
DuCaTi MoNsTeR
Member # 2931
i dont think panhards are going to be an issues here as both my axles are limited in extreme amounts of verticle travel(not articulation) to save driveshaft cv's...we'll see soon enough as i plan to take the ole gal to pismo and make sure the air bumps work correctly
nevertheless, i can easily swap the rear over to the triangulated stuff im used to if im willing to cut a hole in the bed under the tool box for the tank...i even have the junk to make the extra upper link. im sure ill hate the 127ish wheelbase and will wanna shorten it sooner or later...
#718 (permalink) |
DuCaTi MoNsTeR
Member # 2931
i dont think so, bought two plane tickets to alaska for kayaking/glacier backpacking with my son in august and used up my vacation time
#719 (permalink) | |
Does yer dewg bite?
![]() I'll head up Thursday night...
85' Toyota truck/runner. 60/14 bolt, 4.3L, 39.5's. 07' Turner RFX for exercise. (Ride hard or ride cross country) In loving memory of Madelyn Rose Ekhilevsky
04/17/04 - 12/08/08 |
#720 (permalink) | |
DuCaTi MoNsTeR
Member # 2931
what day do you plan to return??
#723 (permalink) | |||
Grocery Getter
Member # 59
![]() Quote:
Aluminum is something I haven't looked into. I'm guessing $$$ for material and machining tho. Probably need another $ digit there by the time you get done with 8 links and a TR! ![]() Quote:
![]() I want to see your Taco there and we can see how our rigs work in the whoops and the dunes!
#724 (permalink) | |
DuCaTi MoNsTeR
Member # 2931
there was a kid on here selling some 7075(?) in the bay area but he didnt really return my PM's??? i gave up on it
