Steering Pulls - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-25-2007, 06:57 PM   #1 (permalink)
Member # 77384
Steering Pulls
I'm trying to help my mom with her '97 Tacoma's issue.
Apparently, it pulls left and right while going down the road, and jumps to the side when a bump is hit. The truck has been doing this for the past year or two and has had two alignments that haven't helped.
I don't suspect a ball joint as it does this all the time, and I don't think the tires are too blame, since the truck has done this on two different sets.
It's a stock '97 with 31x10.5s and 110k.
'86 Jeep MJ
Doors are for the weak.
feerocknok is offline   Reply With Quote
Old 09-25-2007, 07:30 PM   #2 (permalink)
Member # 87189
tie rods or rack is my guess. i dont know what else it could be
ECV 1069
badmoonrising is offline   Reply With Quote
Old 09-25-2007, 11:40 PM   #3 (permalink)
Member # 77384
Anyway to decide which it is?
'86 Jeep MJ
Old 09-25-2007, 11:57 PM   #4 (permalink)
Member # 86863
Thumbs down Apparently yer no help...
Get under there and look as she's turning the steering wheel... duh...
Maybe she'll hit the gas... and end yer sorry ass
'00 Tacoma 4X 3.4 manual trans and some extras...
TacoDell is offline   Reply With Quote
Old 09-26-2007, 12:01 AM   #5 (permalink)
Member # 77384
While I appreciate the help, I was looking more for what sort of symptoms the tie rods would show of wear, as well as the rack.
Also, are either of these things common to go out on the Tacomas?
She drives it like a normal woman of her age would drive it, so it has seen little abuse.
'86 Jeep MJ
Old 09-26-2007, 12:18 AM   #6 (permalink)
Member # 86863
Movement and or slop
I've been thru a rack already at around 90K... Inner tie rods could be worn... You need to get under there and push shit around and watch as shit moves... Shit don't just show itself with a visual look see... you have to make the shit work to see what it's doing... You trust yer mom don't you ?.. LOL
A most likely culprit is the bushings that hold the rack in place... these wear easily and early on... even under normal use... and the rack shifts on it's mounts... creating lots of slop...
Check these...
Rack bushings for play/movement
Inner/outer tie rods for play
Ball joints... they could be worn but not obvious...
The guy doing yer alignments sucks... if he's not noticing shit that is going bad... find another...
Old 10-03-2007, 02:10 PM   #7 (permalink)
Member # 77384
Tie rods look/feel good. Gotta get the truck in the air to check the ball joints.
The bushings look good, no cracking or weird texture where I can feel. Is there anything else to look for in bushings?
'86 Jeep MJ
Old 10-04-2007, 02:57 PM   #8 (permalink)
Krylon..'s Avatar
Member # 2042
Send a message via AIM to Krylon.. Send a message via MSN to Krylon.. Send a message via Yahoo to Krylon..
Did you watch everything as Tacodell said while someone was turning the wheel back and forth(and its best when the truck is on the ground)? As casual visual inspection wont cut it.
And I agree. Your alignment guy isn't doing his job and you need to find another.
Mike
Krylon.. is offline   Reply With Quote
Old 10-04-2007, 02:59 PM   #9 (permalink)
Banned
Member # 14006
X2 or more.
Dickfoster is offline   Reply With Quote
Old 10-05-2007, 09:21 AM   #10 (permalink)
4XTaco's Avatar
Member # 88203
The bushings looked good on my steering rack too and when you got under it and watched as someone moved the steering back and forth the rack was wandering every where.
Seriously get under it and watch it as someone is moving things around. I replaced my rack bushings and it made a huge difference.
'96 Tacoma- (Toy bought it back)
'00 Excursion- 7.3L Powerstroke
4XTaco is offline   Reply With Quote
Old 10-05-2007, 12:40 PM   #11 (permalink)
Member # 77384
I had her start it up and put the e-brake on, then while I was underneath, I had her turning the steering wheel lock-to-lock while I inspected everything. The truck was on the ground.
The rack was moving 3/8" to each side. Is that too much?
'86 Jeep MJ
Old 10-09-2007, 10:34 PM   #12 (permalink)
Member # 77384
Bump.
Is 3/8" to each side too much play on the bushings?
Seems like they'd have to move some with so much stress.
'86 Jeep MJ
Old 10-09-2007, 10:56 PM   #13 (permalink)
Member # 10480
3/8" is a huge amount when it comes to steering. you shouldn't even really see the rack move at all. the driver side bushing probably went bad. order some energy suspension bushings and follow these instructions
http://www.keystonekrawlers.com/Mods...eeringBush.htm
broncoboy351 is offline   Reply With Quote
Old 10-11-2007, 10:33 PM   #14 (permalink)
Member # 77384
Thank you!
'86 Jeep MJ
