I dont know if this is worthy of pirate, but I thought id share my 2001 4runner conversion with you folk.
First off, im going to admit my shear stupidty of buying a 2wd, but i was 20 at the time, had hardly any credit at all and the 4wds that I looked at would not accept my loan applications, but this dealer did and I decided to go ahead and get this truck,
the Lowdown.
I started modding this 4runner back in Aug of 2006 with the intent to go ahead and try and make it somewhat capable with a locker, sliders, and a front bumper. its been like that for a year now and also has 33s, and some other bs.
Now the truck has ARBs, 4.56 gears cryoed, 5:1 inchworm lefty with cryoed output shaft and front range offroad twinsticks.
only problem, i do not have the compressor installed so im in 4wd open right now, still better then 2wd locked hi
on to the process.
first step was putting the tcase in with a budbuilt crossmember and the prerunner adapters on to the tailhousing end of my 2wd transmission
This conversion was ment for tacoma prerunners so we ran into some issues with my tailshaft being too long and my speed sensor (which is fucked up right now anyways) not being in the right position to read the gear.
IMG]http://i101.photobucket.com/albums/m68/neliconcept/mail.jpg[/img]
tail housing off and you can see the sensor on the right
sensor plugged in, well yeah its way far back
here is the problem, those 5 or so teeth on the gear ring before the tail shaft is what the sensor is supposed to read, see how far the sensor is from that? thats what is delaying this, and no way in hell i would have attempted this install as it is more fab work then im capable of.
Now the tube adapter built by advanced adapters was able to be connected.
the Lowdown.
on to the process.
