Member # 101323
gear cases/taco drive shaft. flange?
i am building my taco with gear driven cases and i cant find a flange thta will fit my taco drive shaft. i want to keep it cuz it has the cv. iv called marlin and trail gear and searced but cand find anything that will fit dose anyone have anythi9ng that worked?
Waiting for parts blows. Yes, i know i cant spell. sorry. |
#2 (permalink) | |
DuCaTi MoNsTeR
Member # 2931
i used the quad drilled flange that inchworm sells and my taco cv's bolt pattern worked
Amongst the best of the toyota vendors: Www.4wheelunderground.com Www.addictedoffroad.com Www.hellfire-fabworks.com |
Member # 101323
you have a v6 right? i have the 2.7 and im pretty sure the bolt patterns are different.
thats why im asking iv found some that will work with the v6 but not the 4
Waiting for parts blows. Yes, i know i cant spell. sorry. Last edited by motorwerke; 07-18-2008 at 03:53 PM. |
DuCaTi MoNsTeR
Member # 2931
measure your bolt patttern hole center to center as an X and ill see if itll fit on the flanges ive got??
Member # 72297
Talk to Jim at Inchworm, this should bolt right up.
http://www.inchwormgear.com/store/pr...products_id=57 |
Member # 112024
i just dropped in an inchworm built t-case with quad drilled flanges in to my taco 4 banger. bolt patterns work fine
98' tacoma 2.7 pushin 40s sas hp44 linked 2.5 kings, d60 ARB f&r,inchworm lefty. "Oversteer is where the passengers are scared. Understeer is where the driver is scared." [url]www.myspace.com/thesofttaco[/url] |
Member # 69547
you need the front output from a cv front shaft from an older p/u. Thats what i had to use with the Tacoma rear shaft and gear drive case.
95 Taco 4x4 2.7 - 4 linked front - 3rz-R151-4.7s - FJ80 axles F+R Build-up Northeast Toyota Crawlers |
Member # 69547
you need the front output from a cv front shaft from an older p/u. Thats what i had to use with the Tacoma rear shaft and gear drive case. Or a rear one of a Turbo case will work.
Member # 101323
i called marlin and he said the turbo flange would work to so i bought it but when i tried bolting it up it didnt work.
DuCaTi MoNsTeR
Member # 2931
sorry, i was gone at we rock all weekend, i can measure that for you tomorrow morning
#12 (permalink) |
Grocery Getter
Member # 59
Using front t-case flanges or turbo flanges works for the older CV joints (IFS/straight axle front CV's), but the newer rear CV's bolt pattern in tacos and 4runners is even bigger. I think the one Inchworm sells works for all of them, but give him a call to make sure.
I just used my old shafts in my new runner, so I didn't have to worry about the flanges, but I did notice the original one was bigger and wouldn't bolt up. |
#13 (permalink) | |
Member # 73099
this is what i did, i used the front flange from the case and drilled it for my rear. very simple
01 tacoma |
