#626 (permalink) |
Member # 136758
because hyenas truck was right around that, and i think his truck wheeled the best out of anything i ever drove or have seen. and i cant stand the look of the wheels basically touching on the extra cab of these trucks.
your truck would look proportional with 117-120, since its a single cab. but mine wouldnt at all.
Bro-coma |
#628 (permalink) | |
Member # 169872
Haters gunna hate. I love my 124" Climbs like a beast. Good choice IMO
2000 XtraCab 2.7L 4x4 Leaf Sprung SAS. Dana 44HP and Ford 9". |
#631 (permalink) |
Member # 45196
my truck is 112 right now and i think it looks a little retarded because the rear isnt centered in the wheel opening anymore and the front cant go any further forward because it would rub the headlights too much
96 taco, lockd, linkd, caged, beat, daily driven 24" frame on 4dz ready to jump |
#632 (permalink) |
Member # 110365
How do you plan on mounting your coilovers? ie what angle and stuff?
www.4WheelUnderground.com . Specializing in 3 & 4Link Systems for your Toyota Truck, 4Runners and Tacomas . http://chat.4wheelunderground.com 1 Ton Links are HERE!! Price check us here for a real Apples to Apples comparrison http://chat.4wheelunderground.com/in...sg1945#msg1945
#633 (permalink) | |
Member # 136758
is it probable to not run bumps in this situation or is it a must? as for mounting the shocks, i think im gonna start some tube work before i mount them.
Bro-coma |
#634 (permalink) |
Member # 45196
billys runner is set up with about 6" of shaft on his rear coilovers and we were hammering through that pretty easily at the hammers this week but still able to haul total ass. I think running some simple poly bumps would have been huge and some stiffer valving a big plus
#635 (permalink) | |
Member # 136758
Bro-coma |
#636 (permalink) |
Member # 45196
no just the ones on the shock shafts, it needs something though. im redoing my truck right now and going with air bumps up front and large poly bumps out back
#637 (permalink) |
Member # 187697
nice work matt.
The rear link setup on my truck is very similiar to yours. Ill just be mount up frame side uppers differently. Glad to see that my setup is close to some one elses. I don't think you can get away with out running some sort of bump stop, with coilovers. Unless you had it setup where the springs would coil-bind and not allow you to use up any more travel. Bottoming out a shock isn't good. |
#639 (permalink) |
Member # 136758
thanks guys.
i was re thinking, ill need to run bumps. i forgot about when my truck is loaded down with gear. if it weren't for that i could probably tune them right to not have to run bumps.
Bro-coma |
#640 (permalink) | |
Member # 110365
#641 (permalink) |
Member # 136758
ok, thats kinda what i was thinking once i thought about it more. as for the springs rates. should they be slightly stiffer than the front since the backs gonna be changing due to loading gear up all the time?
Bro-coma |
#642 (permalink) |
Member # 110365
Stiffer only in the sense that the back end is lighter usually. But slightly lighter compression valving too. Then there is the angle of the shocks that will play tricks on how much the springs compress too. The rear is difficult because the load changes and the angle of the shocks. If you only want to do it once you may have to take the front coilovers off and use them in the back for mock up and weight estimates. Or barrow someones.
As for dealing with various loads, either go soft springs and be willing to preload that crap out of them when ever you have a load or use a helper coil. Either way you're looking at making adjustments if you're picking about the ride height.
#644 (permalink) |
Member # 136758
didnt do to much this weekend but i finally wrapped up all my wiring, got the battery and arb stuff all finished. waiting on my pillow block to come in the main so i can finish my drivelines. need to save money for a whole bunch of tubing.
also im gonna attempt to make my own light bar. been doing lots of research, ordered a whole bunch of stuff to test different products out. im not gonna give any info on what im using yet until i have it all working (hopefully) but im gonna be using one of the best high powered most efficient leds on the market today (i dont think any of the light bar companies are even using it). if everything works out i should be able to have a legit light bar that will only cost me 300$ in parts. shooting for 20,000+ lumens. might be a while till all the parts show up though. ![]() ![]() ![]()
Bro-coma |
#647 (permalink) |
Member # 37026
matt your not worried about sinking that compressor under water at fordyce? im not familiar with the specs on those pumps but for some reason a top truck challenge ad comes to my mind saying how they can handle anything? i know last summer wheeling with wilson at fordyce his took a crap. we just hit the trail and we turned back to eagle lakes to tear it apart at the parking lot to find water got inside.
[COLOR="Red"]ECV 7-11[/COLOR] RIP troy & daniel KYOTA Forever. |
#648 (permalink) |
Member # 136758
From what I know they can handle anything. And I just wouldnt have it run when I do a crossing. I also could hook the intake to some of my left over flex line and run it under the hood or in the cab.. I might actually do that. Besides the intake everything sealed
Bro-coma |
#649 (permalink) |
Member # 21533
I may have missed it, but did you pull the York?
85 Toy PU @ 5", on 39.5 Pitbull Rockers, flat bed, York OBA, stretched to 111" WB, Marlin Crawler, 5:29's, Aussie Locker and Longs in the front/spool in the rear, crossover steering, doorless... most of the time! |
