Extending the Toyota Front Axle - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-24-2011, 12:48 AM   #1 (permalink)
Member # 156219
Anyone done this? I searched, and didn't see anything offhand. Trail Gear makes their dirty 30 plus 3s, that is, the short side bird is extended 3 inches, designed to work with their axle housing. Makes it IFS width, without wheel spacers (duh, I know).
But, has anybody just spliced 3 inches into their stock Toyota front housing? Seems like something pretty easy to do if you're already doing an SAS. I don't have an axle here in front of me, and this might be totally retarded, but seems like you could just cut, weld in 3 inches of correct sized tube, then probably weld a sleeve over the outside of it for extra strength (I'm guessing this would be better than sleeving inside, to make sure the axle shaft has plenty of clearance on the inside, but I could be wrong?), and then you'd have to relocate your spring perches and steering stops - not too big a deal, especially if say you upgraded to something like the Ruff Stuff elongated perches... Then you could mod as usual - shave, truss, armor, whatever... Am I missing anything? Is this totally dumb? I know I'm a newb, but I've searched, and I don't think this is totally dumb... Would mean IFS width with no wheel spacers.
Spruce
spruce is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 01:01 AM   #2 (permalink)
Member # 167658
If the goal is just to be IFS width without wheel spacers you could go the simple route and install the IFS hubs, rotors, etc. on the solid axle. There is good info on it in the FAQ 2.0 Front Axle-IFS Hub section.
jersummers is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 04:57 AM   #3 (permalink)
Member # 140945
start reading
/forum/toyota-truck-4runner/854674-another-home-brew-front-axle-build.html
malo periculosam libertatem quam quietam servitutem
-Jake- is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 07:31 AM   #4 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
Do you have access to a "jig bar" to keep it all straight when welding it back together?
Old 08-24-2011, 09:11 AM   #5 (permalink)
Member # 156219
jersumers - It seems to me that even with the IFS hubs and all, you're still using a spacer, which wouldn't be as strong as having a longer axle.
Jake - I've read that - super cool, but a ton of work, and quite expensive. If you already have a front axle, making it a little longer, rather than fabbing an almost completely new one seems easier and cheaper.
OOP'S - I don't have a jig, but could have one machined up, or could weld up a half assed jig. Or, I think you would have decent success with tacking, installing your birf/eyeballing with a straight edge, pull the birf and weld a bit, repeat, massage with BFH as necessary. You would definitely stand a chance of warping your axle, but with a bit of patience, I would think you could do it. Definitely the best way to go though would be to have somebody machine up a 'jig bar'.
I'm getting ready to order all of my goodies, so now would be the time, if ever, to try this...
Spruce
Old 08-24-2011, 09:32 AM   #6 (permalink)
Member # 186116
I would just make a jig out of square tube and old perches, flip perchs and weld them on to the square tube and drill holes so you can run a u-bolt through it and clamp down the axle housing. make some feet for the square tube and connect the two together with more square tube. If you take your time and make this right is will hold the axle tubes and prevent it from warping. It still is a good idea to have a alignment bar in it too
When in doubt gas it
91 4runner
SAS
Locked Front and Rear
Leafs in front Coils out back
Chopped top and bobbed rear
Full Cage
Auto tranny
4.7:1 case
37's on bead locks:flipoff2:
Sparticus is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 10:09 AM   #7 (permalink)
Member # 156219
Sparticus - I was thinking the same thing. After reading a bunch, it definitely seems like a 'jig bar' would be worthwhile - I wonder if there's anything out there which would work, which didn't have to be custom machined?
After searching, I wasn't able to find anything other than the link above which shows an axle housing being almost completely fabled - but apparently I didn't include all the right search terms - kept using the word 'extend' instead of 'widen' - plug that one in and you come up with this thread:
http://pirate4x4.com/forum/showthrea...t=gettin+wider
which shows a guy doing almost exactly what I was thinking, except way higher quality then what I was envisioning. Way cool. I'm only 7 out of the 11 pages through it.
Spruce
Old 08-24-2011, 10:16 AM   #8 (permalink)
Member # 6363
or... even easier, put a dana 60 in it
IRUNROCKS is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 11:01 AM   #9 (permalink)
Member # 186116
i will have to draw up the jig plans i think it would make the axle houseing easier to make by far
91 4runner
SAS
Full Cage
Auto tranny
4.7:1 case
Old 08-24-2011, 11:15 AM   #10 (permalink)
Member # 100827
Send a message via AIM to smewhtguy
There is always one bad apple in the bunch.
I do math and stuff, on a professional level.
smewhtguy is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 11:42 AM   #11 (permalink)
Member # 181071
/forum/axles-tires-wheels/997804-fj80-high-steer-way-you-need.html
toyotathomas is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 12:44 PM   #12 (permalink)
Member # 81334
http://www.diamondaxle.com/index.htm
http://www.ruffstuffspecialties.com/...eHousings.html
"Chrome won't get you Home"
85 Yota Sittin on 38.5 Sx's and a whole bunch of du-dads...
Monster Yota is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 12:47 PM   #13 (permalink)
Member # 21320
My Diamond is 5" longer on the short side
TDI swapped lwb Samurai
BCzuk is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 01:22 PM   #14 (permalink)
ryantowry_81's Avatar
Member # 122722
widening toy axles is common in the cruiser world when they put fj-60 axles under fj-40's cause it puts the pumpkin where the spring perch should be:
/forum/toyota-land-cruiser/694646-fj60-axle-sleeve-widening-front.html
the guys name is Dave Gore, real nice guy and easy to do business with. i bought two spacers from him and the long side inner longfield shaft (he was out of the short sides at the time) to build my axle.
I was planning on grinding the weld for the knuckle balls, and making two identicaly beams out of some smaller I beams that would mount to the top and bottom knuckle studs which would not only ensure they were welded back on strait and hold it strait but make sure each had exactly the same caster.
I am still planning exaclty how this will work but i think it it should keep it strait enough.
ryantowry_81 is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 03:13 PM   #15 (permalink)
Member # 167658
Spruce
I was mainly referring to the last line on your original post where you mentioned "IFS Width with no spacers" which is what the IFS hub swap offers. It puts you almost exactly at the same width of the IFS rear axle. I agree it probably isn't as strong as extending the axle itself, but many guys on here have been running it with big tires, lockers, etc. even as daily drivers with no issues at all for years.
Anyway, good luck with the axle build.
Old 08-24-2011, 04:04 PM   #16 (permalink)
Member # 156219
Huh, nice links fellas. Overall I doubt I'll go to the trouble at this point - gotta learn to crawl, before you can walk, and at this point I have enough other things to learn how to build, so that this should be the least of my worries. But, I get sidetracked...
Spruce
Old 08-24-2011, 04:11 PM   #17 (permalink)
Member # 100827
Do the ifs hub mod, my current truck has it as do the last 4 trucks I have done SAS on.
Old 08-24-2011, 05:30 PM   #18 (permalink)
surftaco's Avatar
Member # 47670
Jake posted the link to my thread already
but i think what your looking to do is more like what Pat did in his "getting wider" thread
http://pirate4x4.com/forum/showthrea...=654231&page=3
"Whoso Speaketh Of What Concerneth Him Not Shall Hear What Pleaseth Him Not."
Sir Richard Francis Burton
Build Thread -
surftaco is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 06:30 PM   #19 (permalink)
94toytruck's Avatar
Member # 18614
Nope...
I agree with him
Eric
[B]
[/B] [B]
[/B] [B]
[/B] [B]
[/B] [B]
[/B]
[QUOTE=FLEXYSAMMY;13977957]Yes you are correct Eric.[/QUOTE]
94toytruck is offline   Reply With Quote Quick reply to this message
Old 08-25-2011, 02:18 AM   #20 (permalink)
Member # 62881
Wasn't there a picture in one of the FAIL threads where someone made a centered toy front with two long side shafts? It was was pretty, um, special.
IFS hub mod, and if you want to go baller do the taco rotor swap at the same time.
Or buy a Dana 60.
Dragging more ass than a dog with worms...
VasToyBoy is offline   Reply With Quote Quick reply to this message
Old 08-25-2011, 09:01 AM   #21 (permalink)
SeaBass44's Avatar
Member # 40
this^^^^^^^^^^^ I owned that axle awhile
& you better have a good jig, these axles bend even tacking on a weld on truss.!
# 530.532.4529
TTC 2010 1989 BRONCO
-Awesome web development for your business.
SeaBass44 is offline   Reply With Quote Quick reply to this message
