85 runner build...operation field recovery- Blown 5vz-fe, 40deez, and metal - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-18-2012, 03:05 PM   #51 (permalink)
KStacoma's Avatar
Member # 51493
Hey guys,
I have been wrenching quite a bit but bad about updating
Here's the latest:
I got super sick of the 22re being such a dog:
so I found a 3.4 out of a 96 T100 with only 75k miles on it!
I had a hell of a time with my exhaust cross over because I was using an R150 trans with a driver side slave cylinder. Squeezing the exhaust through w/o hitting the firewall, frame or slave was interesting. Since I had to make the engine a drivers side exhaust anyways, I was up for the challenge.
85 4runner- Duals, 4.7, longs, 40s, Blown 5vz-fe
76 FJ40 - 5.3/4L60E, atlas, dynatrac 60
KStacoma is online now   Reply With Quote Quick reply to this message
Old 06-18-2012, 03:06 PM   #52 (permalink)
KStacoma's Avatar
Member # 51493
I also got a blower, so I put that on the shelf for the time being until I got it running strong natrually aspirated:
Old 06-18-2012, 03:07 PM   #53 (permalink)
KStacoma's Avatar
Member # 51493
I put an oil PSI and coolant temp gauge in to make sure the engine is running healthy.
I also put the ECU in the glove box and wired in an OBD port so I can log data wirelessly with my 20 dollar amazon.com code reader thingy:
Old 06-18-2012, 03:08 PM   #54 (permalink)
KStacoma's Avatar
Member # 51493
Just cause I am a ricer, I put a push button start on it also
Old 06-18-2012, 03:09 PM   #55 (permalink)
KStacoma's Avatar
Member # 51493
SO here it is:
Open element air filter is not my ideal choice but I tubbed my fenders for my 40's a while ago and the stock airbox wouldn't fit.
Old 06-18-2012, 03:11 PM   #56 (permalink)
KStacoma's Avatar
Member # 51493
Here is the fun of squeezing the exhaust through with a R150
I put both o2 sensors in but did the resistor mod on the rear so I don't get a MIL for a PO420
I could use my existing driveshafts, t-case cross members and skid w/just minor re-drilling:
Old 06-18-2012, 03:12 PM   #57 (permalink)
My dog will eat you
xj chopper's Avatar
Member # 143131
what no shift light?
xj chopper is offline   Reply With Quote Quick reply to this message
Old 06-18-2012, 03:14 PM   #58 (permalink)
KStacoma's Avatar
Member # 51493
This is where the shifters end up with the R150, adapter, then duals:
3.4L fan, 3.0L radiator, 3.0 shroud
Had to get the 2wd oil pan and pickup tube:
pushed as far back as I could get it:
Oh and most importantly:
Old 06-18-2012, 03:22 PM   #59 (permalink)
KStacoma's Avatar
Member # 51493
Engine fit under the hood fine until I added the blower, then it hit:
Old 06-18-2012, 03:28 PM   #60 (permalink)
KStacoma's Avatar
Member # 51493
If anyone has any questions at all about how to do a 3.4 swap, or anything I've done please feel free to ask!
Old 06-18-2012, 03:39 PM   #61 (permalink)
Member # 207614
Some good work there KS. So hows the power and whats the milage like?
85 4runner
Framer is offline   Reply With Quote Quick reply to this message
Old 06-18-2012, 03:48 PM   #62 (permalink)
Member # 165401
Wow... that's a lot of work you did there to get that 3.4 in. It would be awesome to have the power of the V6 but it sure seems like it would take some thinking through to get it right. Anyways nice work and I like how the crawler looks.
-Will
2stroke rider7 is offline   Reply With Quote Quick reply to this message
Old 06-18-2012, 04:26 PM   #63 (permalink)
KStacoma's Avatar
Member # 51493
Thanks guys! Honestly the swap isn't so bad. I was worried mostly about the wiring and it was easy once I got the right wiring diagrams.
As far as power, it is fast as hell. It will spin 40" tires no problem from a stop....but I don't want to blow up my 8" R&P yet lol. I haven't figured my fuel economy yet, but now that I have it running right I am getting more than double the mileage out of it than I was with my 22re.
Old 06-18-2012, 06:19 PM   #64 (permalink)
snatchblock_13's Avatar
Member # 90327
Looks good! I may have missed it, but what did you do for motor mounts? I will be doing the exact same swap soon.
snatchblock_13 is offline   Reply With Quote Quick reply to this message
Old 06-19-2012, 12:15 PM   #65 (permalink)
KStacoma's Avatar
Member # 51493
I used the mounts that came with the 3.4 on the actual engine, then on the frame, made some similar versions to the 22re mounts but out of 1/4" and welded em on. I will snap a pic next time I think of it.
Old 06-19-2012, 09:33 PM   #66 (permalink)
Member # 189799
im doin a 3.4 swap right now also. where did you find the wriring diagrams for each vehicle? im having a hard time finding the EWD's. Thanks!
YUMADTHO is offline   Reply With Quote Quick reply to this message
Old 06-19-2012, 10:42 PM   #67 (permalink)
Member # 175512
I would give my left nut for this fawker... shit is exactly what I want man! Props!
2017 Chevy 2500
1994 Toyota 4Runner
kaiserdtm is offline   Reply With Quote Quick reply to this message
Old 06-19-2012, 11:12 PM   #68 (permalink)
My dog will eat you
xj chopper's Avatar
Member # 143131
I wonder if he would trade if you produced your nut?
Old 06-20-2012, 12:24 AM   #69 (permalink)
Member # 175512
My nut will never produce as much of a good time as this runner.....lmao
2017 Chevy 2500
1994 Toyota 4Runner
Old 06-20-2012, 04:34 AM   #70 (permalink)
KStacoma's Avatar
Member # 51493
If you can't find your wiring diagram on here:
http://www.ncttora.com/fsm/index.html
you can pay like 15 bucks for a day to get on toyota's tech website and print off everything you need.
THanks man! I had to give my left nut just to build it
Old 06-20-2012, 08:48 AM   #71 (permalink)
so call me maybe?
]4RunnerKid['s Avatar
Member # 45812
Send a message via AIM to ]4RunnerKid[ Send a message via MSN to ]4RunnerKid[ Send a message via Yahoo to ]4RunnerKid[
nice build man. super jealous of that new powerplant...
-Mikey-
Party Wagon
locked, geared, caged, topless, dents
Jeff Goldblum
LBZ, Allison, 4WD, TV, towing duties
4 doors for more whores
]4RunnerKid[ is offline   Reply With Quote Quick reply to this message
Old 06-20-2012, 09:32 AM   #72 (permalink)
BIG-O's Avatar
Member # 109702
X2! I wish I would have done that swap instead of rebuilding my gutless 22re.
Why did god invent whiskey? So the Irish wouldn't rule the world!
BIG-O is offline   Reply With Quote Quick reply to this message
Old 06-20-2012, 10:16 AM   #73 (permalink)
Member # 21974
Send a message via AIM to Stinson
WTF are you thinking??
Supercharged 3.4 with toy running gear on 40's? I wouldnt wheel with you cause Im not going to drag your ass off the trail when you break
Stinson is offline   Reply With Quote Quick reply to this message
Old 06-20-2012, 04:30 PM   #74 (permalink)
KStacoma's Avatar
Member # 51493
Thanks buddy Just keep talking crap but when I'm at the top of the rock or hill and your at the bottom I will throw you a strap We need to go wheeeeeeeeling!!!
Old 06-20-2012, 07:23 PM   #75 (permalink)
Member # 21974
Since you bring it up.........
