#76 (permalink) |
Member # 156489
I also spent some time putting together a switch panel for in my dash. It's pretty much ready to be put in now.
1989 extracab. 4.3 vortec. 38 inch toyos, rear tacoma e-locker, 4.88 gears, d44 front axle, OBA - SOLD 1990 4runner 5.3 vortec, 38 inch Toyos, Dana 60, 14 bolt, 3 link f+r - work in progress |
#77 (permalink) |
Fart club modesto ch
Member # 143131
Sick build! Your wiring looks tits. I had a fj80 with a 5.7 vortec 4l60e and a split case and that was a fun rig! You will love the finished product.
GET IT |
#78 (permalink) |
Member # 156489
Thanks! I'm hoping the 4runner will be a lot of fun!
#79 (permalink) |
Member # 83913
Keep up the good work! This is exactly what I have planned for next year but NV4500 to 241/205. You rig is coming out sick.
'85 Xtra Cab 3rz,Duals, D60/14b, Detroit front/rear, 35spline chromos,rears/chevys, bad temper |
#80 (permalink) |
Member # 156489
Another update:
I got the front gas tank crossmember raised up and I completely replaced the rear gas tank crossmember with square tubing. ![]() here's a poser shot of close to ride height sitting on the hoist. ![]() I got my panhard bracket ready to be welded on. ![]() Also welded my rear link mounts/coil pads welded up and put on my rear axle. ![]() ![]() here is the front axle at full bump. ![]() ![]() ![]() ![]()
#81 (permalink) |
Member # 156489
#82 (permalink) |
Member # 156489
Some more:
I finished up the the steering box plate ![]() I also got my upper rear coil mounts done ![]() and the factory panhard bar bracket plated ![]() The rear axle is done with all the brackets welded on ![]() ![]() ![]() I also got the rear shock mounts done. They are just the top few inches of the ford shock towers.
#83 (permalink) |
Member # 156489
And some more random pictures showing the rest of the track-bar bracket put on the front axle and the coilover hoops put on after I made them.
#84 (permalink) |
Member # 156489
ok so I actually got a lot done since the last time I uploaded pictures... which means I didn't have a lot of time to take pictures because I was trying to get things done. So it is actually sitting on tires now and the engine, transmission, transmission, transfercases are back in the frame and I put a couple bolts back in the body temporarily. I also temporarily put the grill and front bumper on so that it would look decent and be trailered to the Swap-meet and show n' shine that our club put on. Here are a couple pictures with it washed and out in the sunshine.
#85 (permalink) |
Member # 156489
I need to take the body back off to finish things. I will take more pictures for you guys when I do that.
#86 (permalink) |
Awesome Fab Tools
Member # 84883
Damn man you do have OCD... look at how clean everything is!! Love it!
Cool build. I like the look of the flares, I wish there was some company that made huge ones for general application. Like trim'n'fit type stuff. Nice welding BTW. Clean beads, no undercut, and actual penetration. None of that show-crap stack-a-tack cold junk. Keep up the work. Looking forward to flex shots and some wheelin pics!
ROGUE FABRICATION -Portland, OR Air/Hydraulic Tubing Bender $580 with 180 Degree Dies Drill Press Reduction Kits $119 Shipped Joe@RogueFab.com www.RogueFab.com |
#87 (permalink) |
so call me maybe?
a little on the tall side... but that is some damn fine work you've done there
can't wait to see more progress
-Mikey- The Party Wagon locked, geared, 4XI-caged, 37s, party lights, room for four bitches... The Lesbo Wagon AWD, turbo, tint, wheels, navi, leather seats, room for four bitches... Priorities. Polygoats 4-Wheel Drive Club Poly Performance ![]() |
#88 (permalink) |
Member # 156489
Thanks! Yeah I would really like to drop it a couple inches, the rear was sitting tall so I just adjusted the front coilovers so it would sit level. I'm hoping the rear coils will settle down a little bit, and also when I build a rear bumper and pack tools it will hopefully help bring it down.
#90 (permalink) | |
Member # 156489
#92 (permalink) |
Member # 22506
Nice build. A little different direction that I took with mine, but it looks like you have replaced every major part. Keep up the good work.
94 4Runner with Cummins 4BTA diesel, 700R4, Unimog 421 Axles, Link Suspension, 46 Claws, STaK 3spd. |
#93 (permalink) |
Member # 156489
I have some pictures for you guys! They aren't necessarily in an exact order of events...
#94 (permalink) |
Member # 156489
#95 (permalink) |
Member # 209541
Seriously awesome build! Can't imagine having a 5.3 in my yota
[COLOR="White"]'82 First Gen Yota work in progress :smokin:[/COLOR] [COLOR="White"]04' Chevy Tow Pig[/COLOR] [COLOR="white"][QUOTE][COLOR="white"]I'd rather be laughing and joking broke on the [B]TRAIL[/B] than pissy and miserable behind my [B]KEYBOARD.[/B][/COLOR][/QUOTE][/COLOR] |
#97 (permalink) |
Member # 156489
At the very front there is about 26 1/2" between the inside of the framerails and they taper in as they go back. There is roughly 25 1/2" between the rails where the header collector flanges are. Clearance between the headers and framerails is REALLY tight... like almost touching on the drivers side and about 1/4" on the passenger side.
#99 (permalink) |
Member # 156489
They are bushwacker flares. I got them off ebay. They don't make rear flares of that style for the 2nd gen 4runners so I ordered 2 front sets and did a little triming to make one of the front sets work for the rear
#100 (permalink) |
Member # 156489
Front Sway-bar:
![]() ![]() ![]() What each piece started as ![]() Torsion bar from a 1990 Nissan pickup. It's about 35" inches long ![]() welded washers to cap one side of each spline sleeve ![]() Drivers Side arm ![]() ![]() Passenger side ![]() I used set screws to keep the arm from coming off the bar
1989 extracab. 4.3 vortec. 38 inch toyos, rear tacoma e-locker, 4.88 gears, d44 front axle, OBA - SOLD 1990 4runner 5.3 vortec, 38 inch Toyos, Dana 60, 14 bolt, 3 link f+r - work in progress Last edited by nick89toy; 09-02-2012 at 08:05 PM. |
