Member # 207660
1980 20r truck will not start
Truck was running fine, parked it for a couple of days and now will not start. Truck cranks fine, fuel pump is pumping fuel, getting spark from coil and at plug, has new plugs, rotor button and cap, timing is set still nothing. Poored a little gas in the carb and still nothing. I've searched the post can't find anything.Been workin on this thing all day any suggestions?
Member # 124410
Maybe 30 year old wiring? Bad connectons at the battery? 30 year old ignition switch? Could be a lot of things. Just start narrowing it down. First. I would try running a fused wire straight from the battery so you know your getting full voltage. Then if it starts look for what is causing the low voltage. If it still doesnt start than that may be only part of the problem or not the problem at all.
80 4wd longbed (Stan) |
Member # 138384
look at all your ground connections make sure there is good clean metal to metal contacts points
It all started when Marty went back to the future and opened that garage door. |
#12 (permalink) |
Member # 111797
Check where the starter bolts to. Might have a loose starter, where it bolts to. Mine was way loose could take the bolt all the way out. After I fixed that it starts way easier.
Also they way you are describing the ignitor might be bad, as what RcBro said. Sometimes on my 22r when I only pour a lil of gas in carb it wont start like it should. So I pour alot more down into the carb, and that usually starts it right up. Good luck
Rotten Destruction Last edited by ToxicToy; 04-15-2012 at 11:30 PM. |
#14 (permalink) |
check the external regulator ALSO check the relay for the voltage regulator if its not working it will draw a voltage. ALSO check to see if anything is drawing power when the key is off RADIO, DOME LIGHT, if you put a aftermarket electrical product on it make sure its not getting power and drawing the battery down. but I am going to aim at the voltage regulator on the truck under the hood B/C if its not telling the alti to charge its not going to charge and the only way to make it charge is to have a closed circuit (FROM THE RELAY IN/ UNDER THE DASH) had the same problem on my 1980 truck with a 22r so I know about that area of the grid
#16 (permalink) |
Member # 207660
ITS ALIVE!!! Luckily I have some yota friends with a surplus of parts so I replaced the coil with a factory yota one changed the magnetic pick up in the dist and set the timing again and gave her a nice helping of gas in the carb and she fired right up. Thanks for everyones help.
