#27 (permalink) |
Member # 66587
Oops. Yep. I miss wrote that. Yeah it's a 96-04 Tacoma / 4runner 3.4 5-speed 150 not a turbo 151. Thanks for the heads up on that
#28 (permalink) |
Member # 110365
That's some pretty good fab work. And a pretty hardcore build. Sweet I love seeing builds like this.
www.4WheelUnderground.com . Specializing in 3 & 4Link Systems for your Toyota Truck, 4Runners and Tacomas . http://chat.4wheelunderground.com 1 Ton Links are HERE!! Price check us here for a real Apples to Apples comparrison http://chat.4wheelunderground.com/in...sg1945#msg1945
#30 (permalink) |
Vendor
Member # 145879
The build is looking great, Eric!
Let me know if there is anything else I can do to help! (Subscribed)
. Filthy Motorsports / 303-834-7895 / sales@filthyms.com [ Beadlocks | Transfer Cases | King Shocks | ORI Struts | Limit Straps | Rigid Lights | Gears & Lockers ]
#36 (permalink) |
Member # 175512
This is shaping up to be one sick build!
2013 Ram 1500 1999 Camaro Z28. Iron 6.0, G5X3 on a 116, GTO T-56, STS rear mount kit "Don't quote me boy cause I ain't said shit" - Eazy E |
#38 (permalink) |
Member # 66587
Im back and this afternoon I began on the rear bumper. I started with a 3x3 crossmember to box the rear of the frame. From here I will tie the side areas into the frame. I am going to tie the entire bumper into the cage, so it will not be removable.
#40 (permalink) |
Member # 66587
Ok got a second to work on the truck today. So Ive decided that im going to 4-link the rear so I dont need to go back.
Anyway Ben at Filthy hooked me up, as Im going to use the Evo joints on the rear as well so everything is the same. Btw Ben is a great vendor and has these on the shelf......MUCH better than trying to ship them from Canada and all the crap that goes along with it. Decided to put the spray can in there to show the size of these things!!!
#43 (permalink) |
Member # 66587
Thanks. Hopefully everything comes together. Ok I started work on the rear. The leafs are out (does anyone want a set of custom Alcan front and rear springs?????
) Too bad I didnt just decide to link it in the rear from the beginning. I guess these things always go this way. I removed the spring hangers and mounted up a Artec 14-bolt truss. I wanted a full width truss but obviously had little options with regards to the rock jock. Nate and Ardy (hope im spelling those right) had the idea of using the 14-bolt truss as it would have more room for the pumpkin. Well it worked out great. I slanted the truss slightly forward. I had to cut some around the center section but it should work great! Along with this the last pic below shows the lower axle mounts.
#47 (permalink) |
Truss Master
Member # 117381
I'd try to add a little reinforcement where the arrows are since some of that material was cut out. You could cut some tubing and put it around the speed holes in between the two plates.
ARTEC INDUSTRIES artecindustries.com 1-855-ARTEC99 PIRATE COUPON: pirate4x4 Like us on FACEBOOK Quick Links: Battery Mounts ULTIMATE HIGH STEER QUART CRATE Axle Trusses Fuel Cell Mounts |
#48 (permalink) |
TheMOTHERFUKINHIPS!
Member # 171538
Sweet rig man. I'm definitely gonna copy your rock sliders there
Can't wait to see how the rear bumper turns out too. I cut off the rear section under the body line on mine and am in the process of figuring out a rear bumper.
#49 (permalink) | |
Member # 66587
Thanks man! Yeah going to try and get the rear setup this weekend then I can finish up the rear bumper. Its going to have a tire swingout and Jerry can swingout. Yeah I'm going to be cutting under the body line as well. |
#50 (permalink) |
Member # 66587
Distraction
Been distracted this week trying to finish the wiring on a friends 5.3 vortec fj60 swap. Hopefully I'll be done early tomorrow and it will be off the the muffler shop. In an effort to keep the thread going I was going to post the engine computer mount I built from scratch. It's all out of 1/8 plate.
