Just Another 2nd Gen Build - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-27-2012, 11:10 PM   #51 (permalink)
RKREADY's Avatar
Member # 66587
Got quite a bit done yesterday and this afternoon. My wonderful wife is understanding of the time I spend on the truck thankfully. Anyway I started on the rear. The axle mounts are done and tacked on so I began building the rear frame mounts. I knew that I wanted the mounts to tie into a custom cross member so I came up with a design on that. I began by putting in a temp cross member and removing the stock one behind the rear output..... To begin is the truck as it sits...I just realized I have no pictures of that yet.
RKREADY is offline   Reply With Quote
Old 05-27-2012, 11:44 PM   #52 (permalink)
RKREADY's Avatar
Member # 66587
My idea was to run the frame mounts off of a frame plate that boxed the inside of the frame and was tied together with a cross member both front (in the existing location) and rear (will be added when installed).
Old 05-27-2012, 11:49 PM   #53 (permalink)
RKREADY's Avatar
Member # 66587
Here is the cross member being built.... I think I need a camera. My phone is just not cutting it with picture clarity....
Old 05-27-2012, 11:54 PM   #54 (permalink)
RKREADY's Avatar
Member # 66587
Gusseting the crossmember....made me a little nervious it being five pieces. This should help....too bad this thing so going to weigh a crap load! Also I got the lower frame heim mounts welded up.
Old 05-27-2012, 11:57 PM   #55 (permalink)
RKREADY's Avatar
Member # 66587
And last but not least I built the frame upper mounts. I still have more work to do on these to get them mounted to the frame plates but you can get the idea.
Old 05-28-2012, 12:00 AM   #56 (permalink)
RKREADY's Avatar
Member # 66587
frame uppers continued....
Old 05-28-2012, 12:44 AM   #57 (permalink)
Member # 203479
Nice build..you have some badass toys to play with(tools)..
CA: anti-fun zone
On the search for something that is not illegal.
UndefinedTaco is offline   Reply With Quote
Old 05-28-2012, 05:20 AM   #58 (permalink)
Never Gunna Wheel
Clifcattankass's Avatar
Member # 40472
Lookin good Eric. I need to swing by and give you a hand one of these days when I have time!
Clifcattankass is offline   Reply With Quote
Old 05-28-2012, 07:28 PM   #59 (permalink)
RKREADY's Avatar
Member # 66587
Thanks they help! Not as many as some. That's for sure.
Hey man! Yeah I think this I could use some of your skills on this truck!! Let me know when your free.
Old 05-28-2012, 07:49 PM   #60 (permalink)
Member # 151018
Wow looking good!
Ekj. is online now   Reply With Quote
Old 05-28-2012, 08:40 PM   #61 (permalink)
Nickb45's Avatar
Member # 209316
Awesome build!
Subscribed.
Nickb45 is online now   Reply With Quote
Old 06-04-2012, 10:55 PM   #62 (permalink)
RKREADY's Avatar
Member # 66587
Taking shape......Should have a good chunk of time to work on this tomorrow.....
Old 06-05-2012, 04:07 PM   #63 (permalink)
RKREADY's Avatar
Member # 66587
Unfortunately not much in the way of pics. Got quite a bit done finishing up the cross member. I just need to weld everything and install. Also I am going to be running a rear Warn 8000 for recovery/ suck down. It will be mounted above and slightly in front of the rear axle. Basically right under the rear seat. Hopefully it all fits!
Old 06-05-2012, 04:09 PM   #64 (permalink)
RKREADY's Avatar
Member # 66587
I thought I would try my camera on the last pics and they look worse than my phone!!
Old 06-05-2012, 04:14 PM   #65 (permalink)
Mooseknuckle OG
85dhor's Avatar
Member # 139159
Looks great! Excellent fab skills too!
"You break on the trail, You BECOME the trail!" - drunk guy
MY BUILD http://www.pirate4x4.com/forum/showt...083&highlight=
85dhor is offline   Reply With Quote
Old 06-08-2012, 09:17 PM   #66 (permalink)
RKREADY's Avatar
Member # 66587
Thanks man!
Ok so I finished the cross member. Got it all welded up and installed it.
Old 06-08-2012, 09:19 PM   #67 (permalink)
RKREADY's Avatar
Member # 66587
built the links and got everything mocked into place..
Old 06-08-2012, 10:00 PM   #68 (permalink)
kdub0013's Avatar
Member # 103588
Work of art there, looks freakin awesome! I was curious though and I'm sure it's just the angle of the camera, but how is your pinion angle?
PLACERCOUNTYCRAWLERS.COM - MEMBER
COMBAT VET - USMC 01-05
Project "HIPPIE KILLER" /forum/toyota-truck-4runner/972000-project-hippie-killer.html
kdub0013 is online now   Reply With Quote
Old 06-08-2012, 11:26 PM   #69 (permalink)
RKREADY's Avatar
Member # 66587
Haha. Yeah. Good eye. I was wondering if someone would catch that. It was the end of the day and the uppers need to be adjusted in a lot.
Old 06-10-2012, 12:08 PM   #70 (permalink)
RKREADY's Avatar
Member # 66587
Ok im finishing up the front end, namely the panhard. It has been difficult getting the panhard to fit with full compression being what I want it to be. I am running the frame mount on the drivers side and the axle mount on the pass side. I will need to notch the frame on the pass side and probably slightly alter the oil pan to get about an inch more up travel from the pictures below. Any ideas on how to fit this thing?!!
Old 06-10-2012, 12:25 PM   #71 (permalink)
RKREADY's Avatar
Member # 66587
I started on the drivers side frame mount.....
Old 06-10-2012, 12:27 PM   #72 (permalink)
RKREADY's Avatar
Member # 66587
moooooore
Old 06-30-2012, 07:45 PM   #73 (permalink)
RKREADY's Avatar
Member # 66587
Been out of town for a few weeks. Started mocking up the rear shocks and rear swaybar:
Old 06-30-2012, 07:50 PM   #74 (permalink)
RKREADY's Avatar
Member # 66587
swaybar..... I really liked how ErikB mounted his swaybar to his axle for more space, so I decided to copy that idea....
Old 06-30-2012, 07:54 PM   #75 (permalink)
RKREADY's Avatar
Member # 66587
more
