Tis the season.. for half doors - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-28-2012, 07:15 PM   #1 (permalink)
bawright's Avatar
Member # 98115
finally got around to finishing my half doors. i used some swiss cheese doors that came with a cab i traded for some tires for a mini truck build. Anyways, I shopped around google and the forums to find a style I liked. I ended up using a combination of two styles I liked and added a viewing window to the passenger door because i wasnt sure how well it would work, and only one way to find out.
tape and marker combinations to get the look right, then the grinder
covering up the handle hole
passenger door the same.. if you can notice, i didnt notice until later on..
started my window thing
and here you can see a mistake, or a difference in initial plans.. the top cut doesnt match side to side
bawright is offline   Reply With Quote
Old 04-28-2012, 07:18 PM   #2 (permalink)
bawright's Avatar
Member # 98115
now i fixed the main cut shape
back to drivers door
passenger door getting better
NOW the more helpful tech part, the door handle/latch modification
new door handle
specific tech: notice the difference, i drilled a hole that the factory plastic tab and therefore linkage will be able to attach to.
i attached it to where the interior handle goes, so there is no risk of it locking and not opening(inside handle unlocks and opens in same motion)
measure stuff, weld a bolt of same thread as aftermarket lock tabs(didnt trust 30 year old plastic and screw threads)
metal work done i think
Old 04-28-2012, 07:20 PM   #3 (permalink)
bawright's Avatar
Member # 98115
now on to the Electrolysis rust removal process
12$kiddie pool, 4$ of washing soda and my battery charger and jumper cables(two pieces at once connected) and a junk trailer wheel or any other waste metal.
sorry i didnt really take any pictures before of the rust, but based on the after shots im sure you will get the idea
during
cut out an easy section to replace with angle iron i had sitting around the garage, give it some strength and a backing for bondo(eh, their half doors not a restoration..lol)
some of the swiss cheese action
i sanded them down and converted any leftover or flash rust, and etched the healthy metal i exposed when sanding
Old 04-28-2012, 07:22 PM   #4 (permalink)
bawright's Avatar
Member # 98115
test fit before bondo
(my toyota trailblazer with the fiberglass top off)
after bondo and first application of primer
had some pinholes and imperfections i hit again and then reprimed them
then Paint!
Old 04-28-2012, 07:27 PM   #5 (permalink)
Member # 201353
i really like the lines of those doors. Ive never seen it before. Nice idea on the window
95 IFS Toyota with sliders and 35s-Beater
yoder519 is offline   Reply With Quote
Old 04-28-2012, 07:29 PM   #6 (permalink)
Stay the Trail
mrboyle's Avatar
Member # 3937
Those are some nice half doors. I really like the window idea.
Mike Boyle
1980 Toyota PU
"Those who hammer their guns into plows will plow for those who do not..." - Thomas Jefferson.
Battlement Fab
mrboyle is offline   Reply With Quote
Old 04-28-2012, 07:30 PM   #7 (permalink)
bawright's Avatar
Member # 98115
im painting the truck flat black with gloss trim, so i did the doors black to motivate me to get the rest of the body fixed and painted.
i know i need armor ASAP, and some other stuff in the works.
i gotta get tube to connect the factory roll bars Soon!!
close up of new handles, pull up 1/4" or so, less leverage than a handle makes it sturdy and kid proof, but any older kid or adult hasn't had a problem
(the ugly stuff on the cab is what was under the factory fiberglass topper, the cap's that connect the bed and cab are screwed on and sealed with silicone or something. going to remove them and store with all the other original parts i can gather. and put the original truck vents back in and connect bed and cab with steel.)
I know my truck is naked, Ordering metal next week so i can get some armor made as soon as i get the body straight and a soft top made. pronto
That's all i have for the half doors for now. i will do interior panels and a plexiglass window with it on the passenger side, although no crazy whistle (makes an awesome breeze),i just dont wanna have crap fall out.
A cool thing with the lines i cut, the factory sr5 door handle/arm rest follow the cut out great and will look perfect when they install, 1st gen guys might be able to visualize what im talking about. otherwise just wait for me to get around to finishing and posting more pics.
Old 04-28-2012, 07:43 PM   #8 (permalink)
PHATIM's Avatar
Member # 123101
Those are nice ! Good job...
85 Yota shortbed, 5.29's,detroit, 6 shooters,,30splines, spool, duals w/ 4.7's, beadlocks,37 Pitbulls... still not done
2003 F250 Crewcab sb v10
PHATIM is offline   Reply With Quote
Old 04-28-2012, 08:01 PM   #9 (permalink)
Guyechka's Avatar
Member # 165838
I have to admit I was skeptical of the outcome until the final paint, but those doors look really fucking awesome! I'll be eagerly awaiting the finish for the entire body.
Guyechka is offline   Reply With Quote
Old 04-28-2012, 08:23 PM   #10 (permalink)
HGlavin's Avatar
Member # 179190
good work! probably some of the best half doors ive seen in a while. just missing cup holders lol
"Abraham Lincoln may have freed the slaves but Sam Colt made them all equal again"
HGlavin is offline   Reply With Quote
Old 04-28-2012, 08:37 PM   #11 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
Very nicely done! I like the window idea - that's a new one. Also interested to see the electrolysis done on that big a scale. I've done it in a fair sized Tupperware container for tools and such, but a kiddie pool sized one gives me some new ideas. How long did you leave it in for?
GET INVOLVED - Join the Blue Ribbon Coalition
SIGN THE PETITION - SAVETHEHAMMERS - #85
'93 Chevrolet 6.5TD K2500 NV4500 Std. Cab Longbed 170K
'85 Toyota 22R RN60 4x4 Std. Cab Shortbed 178K (Currently retired for rebuild)
PAToyota is offline   Reply With Quote
Old 04-29-2012, 06:38 AM   #12 (permalink)
bawright's Avatar
Member # 98115
Thanks guys. I left the doors in there for 2 days. but i think i needed to stir the solution again because it didn't seem to do much the second day and i could see the solution had settled quite a bit.
this was my first time messing with electrolysis. i was concerned i wouldn't have enough juice for the two doors connected with jumper cables. I read somewhere you could use an old stick welder or batteries too, so maybe next time i'll try adding some batteries to supplement the charger or borrow a welder for extra current/amp/whatever.
but all in all i was pleased, even if i could have done better with one door, stronger electricty source, or stirring/remixing the solution the second day. It still got a LOT of rust off of a LOT of hard to reach places.
in the pictures where you can see the swiss cheese it was AFTER i converted whatever flash and leftover rust with "ospho". it looked like some areas were either still a little rusty or just looked like it from being rusty with the texture/pitting and discoloration. I wasnt sure, so i "cover yer ass" with rust converter/etching stuff to be safe.
Old 04-29-2012, 06:41 AM   #13 (permalink)
bawright's Avatar
Member # 98115
cup holders:
i have an idea for cup holders when i do door panels or just going to get some of those boat double axis tilt all over cup holders rather then the recessed/frenched in style.
Old 04-29-2012, 12:52 PM   #14 (permalink)
Registered user
bdatud4x4's Avatar
Member # 117525
I like the window Idea, would like to know how well it actually works? let us know.
bdatud4x4 is offline   Reply With Quote
