Member # 112954
4.3 wiring ?
so im lookn at wiring my cpi v6 i have all the harness for motor to the fuse block this is guna be from scratch from hear i have most of what i think i need but cant figure out what wires i need to power up to make it run any insite will be appreciated
Newbie
I have a complete 4.3 under hood wiring harness and both of the under dash dammits to make a 4.3 go, IN A BOX, I'm swapping in a edelbrock intake, carb, hei dist. 3 wires, hot to battery, ignition to coil, ignition to starter...More or less. Too many wires gave me a headache...Three feet below my shoulders. So I went retro to something that I understand.
Give it a set of cohones, then baptize it in the mud, pray to the rock gods, and wheel it till it croaks, then resurrect it's bones, and drive it like its stolen. Amen ____//,/___\, [ _^ ____ ^ [o—o] ~~ / \---------/ \ ()_)~o~()_ ()_)~o~)_) |
Newbie
You might find these useful.
4.3 wiring diagram blazer fsm toyota vacuum diagrams cam degreeing beadlocks including acad dwg afm adjustment https://skydrive.live.com/embed?cid=...KPO1pufAlQ88Hs click on the folder pic to DOWNLOAD files
Give it a set of cohones, then baptize it in the mud, pray to the rock gods, and wheel it till it croaks, then resurrect it's bones, and drive it like its stolen. Amen ____//,/___\, [ _^ ____ ^ [o—o] ~~ / \---------/ \ ()_)~o~()_ ()_)~o~)_) Last edited by coyote577; 05-09-2012 at 07:35 AM. |
Member # 42993
I have a '94 4.3L vin W ( vortec CPI) with 4L60E Automatic in my '86 runner(CA smog Legal). I wired everything together from the factory harnesses using the factory manuals. GM dealer gave me the name of the company that makes their manuals and I ordered a Toyota factory wiring manual from Toyota. I'd say start with getting those manuals and I can probably dig up most of my old notes. I connected all gauges and lights except the oil pressure gauge. Never could get it to work so I installed aftermarket. Also tach is not accurate, but otherwise all works great. What resources do you have and how far along are you?
