pulling my motor question... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-19-2012, 11:52 PM   #1 (permalink)
Member # 217865
I'm gonna be pulling the motor out of my truck and was wondering if it's possible to pull the motor, trans and transfer case out of the truck all together....is it possible since the radiator core support doesnt come out?
I did this in an 80 chevy, v-8 with no problems...the core support was out at the time....
Has anyone yanked them all together at once?
Ronbo 316 is offline   Reply With Quote
Old 06-20-2012, 12:08 AM   #2 (permalink)
Member # 218977
I don't think it's going to happen. I ve pulled my trans 3 times now and its not too big a job and the motor comes easy after that. They might come together but there's a lot of weight to deal with at the ass end. It's also a pretty long assembly to pull through that engine bay. I think you would be better off in the long run to pull em separately. Have fun.
ryanonthevedder is offline   Reply With Quote
Old 06-20-2012, 02:03 AM   #3 (permalink)
Member # 119871
When I put my engine, transmission, and transfer case back in my truck, I put it in all together.. It was easier for me to bolt everything together on the floor and set it in, than it was to fight with the trans & transfer case on a jack under the truck.... Keep in mind I only have a single transfer case, duals may not be as easy.
gmack192 is online now   Reply With Quote
Old 06-20-2012, 02:37 AM   #4 (permalink)
Member # 24881
Did it that way once. Had to have the truck way up in the air to clear that long mess pulling it out.
#864
notstock is offline   Reply With Quote
Old 06-20-2012, 06:07 AM   #5 (permalink)
Retro Wheeler
toyrunner's Avatar
Member # 36
Done it a few times like this. Single case only. The hoist was at its limit, too. Made it easier to let the air out of the front tires so there was more clearance.
1985 4Runner SR5 not so stock.
toyrunner is offline   Reply With Quote
Old 06-20-2012, 06:20 AM   #6 (permalink)
Benny's Avatar
Member # 1129
I recently pulled my engine/trans/t-case/dual adapter out in one unit. When I got near the top, it bound up against the firewall and broke the bolt on the rear hook point. The back part came crashing down and broke my MC dual adapter. Never Again!!
'87 Toyota 4Runner Turbo, '85 Toyota XtraCab, '83 Toyota Landcruiser, '67 Chevy, 46 CJ2a New Project.
Benny is offline   Reply With Quote
Old 06-20-2012, 07:27 AM   #7 (permalink)
Member # 194078
if you pull the 6 bolts from the rear of the trans (where it bolts to the transfer)
the engine and transmisson will come right out. you can leave the transfer bolted
to the crossmember. to install remove the transfer from the truck-- install engine
and trans then install transfer from bottom. works like a charm.
dawg
krip is offline   Reply With Quote
Old 06-20-2012, 07:41 AM   #8 (permalink)
White Trash Fab
smewhtguy's Avatar
Member # 100827
Send a message via AIM to smewhtguy
Unless there is an extra reason for having the tranny and t case out why go threw all the extra work of taking apart the console and pulling shifters, undoing the tcase cross member and drive shafts. Seems like a lot of extra work for nothing.
"If you are gonna live life on the edge you better have good balance"
06 Tundra DC
The "Trifecta" 3 seat yota buggy
http://pirate4x4.com/forum/showthread.php?t=1027210
http://www.AddictedOffroad.com/
www.ruffstuffspecialties.com
http://f-o-a.com
smewhtguy is offline   Reply With Quote
Old 06-20-2012, 07:58 AM   #9 (permalink)
94toytruck's Avatar
Member # 18614
I've done it both ways, it takes 30 minutes to pull the trans on mine tops. Not worth the time to fight it all coming out. Most of the stuff you have to remove comes off anyways if your swapping or rebuilding the motor.
Eric
www.rightcoast4x4.com www.dazednconfuzed.net www.atozfabrication.com www.alltechmotorsports.com www.davesoffroadsupply.com
Originally Posted by FLEXYSAMMY View Post
Yes you are correct Eric.
94toytruck is offline   Reply With Quote
Old 06-20-2012, 12:37 PM   #10 (permalink)
SWDR4X4
DTCsk8er's Avatar
Member # 118757
Exactly my thoughts. Full rebuilt means getting that crankshaft off, rear main, clutch, flywheel, etc. thus requiring the trans to be removed. And it is so much easier to maneuver just the engine in alone.
Most people are just turned off when they think about accessing the top trans to block bolts.. Just need some extensions and a swivel socket.
www.swdr4x4.com - A site dedicated to outdoor life in the southwest
DTCsk8er is offline   Reply With Quote
Old 06-20-2012, 02:11 PM   #11 (permalink)
Member # 217865
I'm taking the truck completely apart....swapping all onto another frame....lotso fun in my near future...lol.
Old 06-20-2012, 02:40 PM   #12 (permalink)
Member # 201812
I've pulled all 3 before but it was on a junk truck and I cut the core support off. If your swapping everything onto another frame, why not pull the cab off first then pull the motor/trans/transfer? Be a helluva lot easier then trying to pull through the engine bay like your planning to.
crawling4runner is offline   Reply With Quote
Old 06-20-2012, 03:29 PM   #13 (permalink)
94toytruck's Avatar
Member # 18614
^^^this^^^
Eric
Old 06-20-2012, 04:09 PM   #14 (permalink)
Member # 217865
I would but...limited space and equipment. I'll probably just pull the motor and trans as one...leave the transfer case on until the frame is wheeled out from under the cab. Thanx all.
Old 06-20-2012, 04:17 PM   #15 (permalink)
bottoms up
thursday's Avatar
Member # 90943
Send a message via AIM to thursday
lots of extensions and swivel adaptors/or a wobbly extension to get the top bolts out...dont be scared to put the tool box on a diet as well.
1990 toy on tons
2003 dirtymax
thursday is offline   Reply With Quote
Old 06-20-2012, 05:32 PM   #16 (permalink)
Member # 201812
I used 4 55 gallon drums and 2 6x6's. Jack the cab up, place the drums at the front and back of the cab, and put the 6x6 across the drums, lower cab. With the drums and 6x6 I think it was 43" tall overall. Might have to put itty bitty tires on it for the top of the motor to clear the core support. Don't know if that helps you any or not, just thought I'd mention it as I was limited on equipment myself. Good luck.
EDIT: Thursday, I see you found out just like I did that those swivels don't like impacts even a lil bit.
Old 06-20-2012, 05:33 PM   #17 (permalink)
Member # 218977
Lol. I want to see the pics of your knuckles after that one. Thats a tough day at the office.
Old 06-20-2012, 08:36 PM   #18 (permalink)
bottoms up
thursday's Avatar
Member # 90943
i was pulling the trans... wound up dropping the tranny low enough to reach that top bolt thru the shifter hole and a 1/2 drive ratchet with straight extensions...pita....
1990 toy on tons
2003 dirtymax
Old 06-24-2012, 11:23 AM   #19 (permalink)
Member # 201695
Anyone ever just hole saw 2 holes in the floor for access then fit some rubber plugs in to seal them back up?
dusty husky is offline   Reply With Quote
Old 06-24-2012, 11:37 AM   #20 (permalink)
whitwilliams74's Avatar
Member # 209340
That's what Stubs did on the Blueberry crunch.
whitwilliams74 is offline   Reply With Quote
Old 06-24-2012, 12:27 PM   #21 (permalink)
RcBro's Avatar
Member # 78101
I pulled the trans and motor out, but I also had a good engine lift to do it. Was scary high but it worked. I have a hell of time at my house getting the top two trans bolts off.
At the shop with a car lift, air gun and 6" extension there a piece of cake lol.
My 1980 toyota project
RC Crawlin.
RcBro is offline   Reply With Quote
Old 06-24-2012, 12:56 PM   #22 (permalink)
Piggin' Ain't Easy
TBItoy's Avatar
Member # 43587
Send a message via AIM to TBItoy
I dont know what the big problem with the upper trans bolts is, you can get to them with a wrench from top.
It's pretty easy, or if you got real big paws, pull the bolts out of the tcase mount and jack it up a bit.
TBItoy is offline   Reply With Quote
Old 06-24-2012, 05:34 PM   #23 (permalink)
94toytruck's Avatar
Member # 18614
Those top bolts are easy, top access or long extension and a universal socket from the bottom.
Eric
Old 06-24-2012, 05:59 PM   #24 (permalink)
Trailbusters4x4 club
FuzzyZ's Avatar
Member # 117547
Is the T-case really that heavy that your worried about taking it out? Come on its only about 50lbs if that. It's easily removed/installed by one person under the truck! Grow some musceles!
X4! Even my messed up hands have never had a problem getting the top bolts out. This guy is going to be screwed if he ever has to replace his clutch! Pull the whole drivetrain at once! Thats the answer!
83 toy pickup, 02 TJ, 02 GMC 2500HD
Trailbusters4x4 club Solano County
Dont blame me i voted Republican!
ECV 1004
FuzzyZ is offline   Reply With Quote
Old 06-24-2012, 06:28 PM   #25 (permalink)
Mr Stubs's Avatar
Member # 102813
My main reason for the holes is that I did a body drop and it made the extension trick much more complicated....
My friends call me "The butcher"
Because I didnt know until now how important this really is.....
Outstanding businesses (going above and beyond) that I have dealt with to date:
Marlin Crawler
Hellfire Fabworks
Daves Offroad
gearinstalls.com (Zuk)
Local 125
Mr Stubs is offline   Reply With Quote
