79 Toyota 4x4 axle question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-06-2012, 09:40 AM   #1 (permalink)
Member # 223175
Ok so I have a 1979 toyota 4x4 truck (chevy 350 30 over) with a 3" body lift and a 3" suspension lift on 35" grapplers and I was wondering if I could put a Dana 40 in the front and a Dana 60 in the rear would I need a conversion kit? Or could it even be done?
The.bc.bogger is offline   Reply With Quote Quick reply to this message
Old 07-06-2012, 09:43 AM   #2 (permalink)
Member # 139159
Spring hanger yes. Search and read the 1 ton swap threads. And Depending on if your running toy cases or not will determine if you have to change out the flanges.
"You break on the trail, You BECOME the trail!" - drunk guy
MY BUILD
85dhor is offline   Reply With Quote Quick reply to this message
Old 07-06-2012, 10:09 AM   #3 (permalink)
Member # 132582
will a 44 hold in a 355 toyota? if not dont waste time man up to a 60 or put the 4 popper back in. with 2" backspace wheels and 1.5" wheel spacers shes ton width
search search and search again
you'll find the answers you seek
i hate k5/yotas my.02
toyoturd is offline   Reply With Quote Quick reply to this message
Old 07-06-2012, 04:38 PM   #4 (permalink)
Member # 84719
A "dana 40" (44?) is not an upgrade over a toyota axle...
05 F250 - ccsb - psd - 4x4
95 4Runner - 3.4 - R151f - 2.28 - 4.7 - 4.56 - 37s
nigels_world is offline   Reply With Quote Quick reply to this message
Old 07-12-2012, 08:50 PM   #5 (permalink)
Member # 207564
real hard not to flame on but this is the place for info soooo. build the toy driveterain and you will be happy. there are upgrade parts and a good following so parts are always worth something. a good investment, not like a dana 44. it is a dana 44 you are talking about not a dana 40? havent heard of a dana 40?
shut the fuck up ricky
05 ctd, mis shitwagon, toy tubebuggy 60/14b
artj123 is offline   Reply With Quote Quick reply to this message
Old 07-12-2012, 09:52 PM   #6 (permalink)
Member # 136919
Might as well keep the toy if you're going Dana 44. And you need different rotor hats if you want to upgrade your brakes
SASed 94 Toy, getting there
1991 lowered jetta DD, Vdubing
Nimyad is offline   Reply With Quote Quick reply to this message
Old 07-13-2012, 07:22 AM   #7 (permalink)
Member # 189716
What this guy says, it's a downgrade IMO, 60 or nothing
510sam is offline   Reply With Quote Quick reply to this message
Old 07-13-2012, 11:54 AM   #8 (permalink)
Steer Much?
Von Wilsonator's Avatar
Member # 182242
Yes it "could be done" and it has many times. A 44 and 60 would be awesome to swap into a '79. especially since im sure your breakin some stuff with that SBC.
You need to widen the front spring hangar, and get bow shackels for the rear of your front springs to match the chevy perch width. (Sky Offroad Design makes a kit. the rear is easy, just grind off the perches, and re-weld them at the toy width. Then you need custom driveshafts, custom brake lines, a Chevy master cyl, 8-lug rims, new tires probably, crossover/hi-steer arms for the 44 (much more expensive than mini axle hi-steer)
Lots of time, fab work, and money. Your better off staying with what you have especially considering you called it a Dana 40!!!
-'92 Yota,4.3vortec /R150 5-speed/2.28/Atlas4.3/
D60/14B 5.38's 42"PBRs, 3/4linked and exo'd.
-'02 ex-cab Duramax chase-truck SAS w/ D80 front. 4.63s, 4Ds, tube bed.(MaddMax)
-'06 Tacoma 6-spd
-'97 Int. 4700 box truck RV/toy hauler in the works.
-'02 KLR650 bugout bike
Von Wilsonator is offline   Reply With Quote Quick reply to this message
Old 07-13-2012, 04:51 PM   #9 (permalink)
Member # 165979
X2, with longs and some other good upgrades, studs, 5th stud set-up and proper maintence, the toy axle is just as strong as the 44, if not stronger. Save the money and go 60D or stay toyota
87 Runner
j4wheelintoys is offline   Reply With Quote Quick reply to this message
Old 07-13-2012, 05:36 PM   #10 (permalink)
BUFFALO_STEW's Avatar
Member # 220111
I think the quote goes something like this, "Don't ruin a Toyota by putting a V8 in it. Buy a Jeep they suck already."
BUFFALO_STEW is offline   Reply With Quote Quick reply to this message
