85 pickup/22re oil pressure gauge? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-24-2012, 09:14 AM   #1 (permalink)
usafcrawler's Avatar
Member # 206554
I want to install an aftermarket oil pressure gauge in my pickup. Just wondering what kind of gauge other wheelers run. Most importly what gauge is an easy install and trustworthy. If i could get some pics or part numbers that would be awesome! Thanks!
85 yota locked, bobbed, high steer, 33s played with hard and put away dented
usafcrawler is offline   Reply With Quote Quick reply to this message
Old 07-24-2012, 12:58 PM   #2 (permalink)
Provience's Avatar
Member # 138976
I don't run one, they will run for a while with poor to no oil pressure
To be clear, this is not to suggest that in similar circumstances, a person who engaged in this activity would face no consequences. To the contrary, those individuals are often subject to security or administrative sanctions. But that is not what we are deciding now.
- Comey on Clinton 2016
Old 07-24-2012, 01:05 PM   #3 (permalink)
Member # 86280
Stick to autometer and mechanical and you will be fine.
David D is offline   Reply With Quote Quick reply to this message
Old 07-24-2012, 03:06 PM   #4 (permalink)
79fourby's Avatar
Member # 195197
yes easy to install, they plug into stock holes in the block since toyota built them with extra ports for add ons.
most are the same, just be careful routing it and use sealant and youll be okay
ASE
79fourby is offline   Reply With Quote Quick reply to this message
Old 07-24-2012, 04:35 PM   #5 (permalink)
Member # 148065
I used the hole where the stock sending unit was. Not sure what brand of gauge it is, neighboor gave me it. Had to use an adapter, 3/16 NPT to what the guy behind the counter said was 1/4" british pipe. It fit perfect, still put a little pipe dope on it. If you measure it with vernier calipers, the threads are tapered on the stock toyota oil pressure sender.
LAILEY is offline   Reply With Quote Quick reply to this message
Old 07-24-2012, 05:17 PM   #6 (permalink)
Member # 43587
Send a message via AIM to TBItoy
If you want it to be really reliable, adapt the gauge and block port to -3 AN and run a braided stainless steel line, that way you wont have to worry about breaking a little piece of shit nylon or brass line and pumping your oil out.
The Gremlin - small ugly linked beater Toyota
TBItoy is offline   Reply With Quote Quick reply to this message
Old 07-24-2012, 05:24 PM   #7 (permalink)
Member # 156412
I smoked my 22re because i didnt have one and lost oil pressure. On the rebuild, i put a cheap oil pressure gauge on it, but i also put a oil pressure sending unit from a chevrolet on it that works an idiot light, it goes off at 7 psi. Works great!
Sent from my Inspire 4G using Tapatalk 2
1987 Samurai, 22RE W56 2XRF1A with 4.7 in the rear, yota axles, one linked front and rear, 38" TSL SX
rlltide12 is offline   Reply With Quote Quick reply to this message
Old 07-24-2012, 05:28 PM   #8 (permalink)
CSR
CSR's Avatar
Member # 3495
I'll take a picture of mine at idle tomorrow. 0 psi. It's been like that for 2 years and 20,000 miles.
My '81 had a gauge in the factory SR5 pod under the dash. I didn't hook it up after the engine swap. Didn't like the idea of pumping hot oil into the cabin.
'85 4runner, locked, lifted, TSL's, 4.7:1 twin stick tcase...
CSR is offline   Reply With Quote Quick reply to this message
Old 07-24-2012, 09:49 PM   #9 (permalink)
Mr Stubs's Avatar
Member # 102813
I have a autometer mechanical gauge...
Braided line..
And the fitting in the block is a 28 BSPT thread type.
Search my build /forum/toyota-truck-4runner/731541-blueberry-krunch.html for pics
Help bring back Swartz Canyon, Join
The good guys...
Marlin Crawler, Hellfire Fabworks, Dave'z Offroad, gearinstalls.com (Zuk), Diamond Axle, RADesigns, Advanced Adapters, Jantz Engineering, G-Fab motorsports, Got Propane, JHF
Mr Stubs is offline   Reply With Quote Quick reply to this message
Old 07-24-2012, 09:58 PM   #10 (permalink)
Member # 187757
the block has two oil ports, one is behind the engine mount. I personally recommend using both. Use the one being the engine mount for the idiot light sending unit, then plug your mechanical gauge into the port where the original sending unit was. That way you have two methods to check oil pressure.
Unclejesse88 is offline   Reply With Quote Quick reply to this message
Old 07-25-2012, 07:21 AM   #11 (permalink)
Member # 118757
Adding on to the last post..
I used the second port on the block, under the engine mount. Idle PSI is usually around 20psi. Here is all that I used:
1/8 BSP to 1/8NPT
1/8NPT 90deg adapter
1/8 NPT to 4AN
4AN 4ft Braided line
4AN to 1/8NPT
1/8NPT to 1/8 copper tube compression
about 3 ft of copper tube
1/8 compression to back of gauge.
And the pics:
swdr4x4
DTCsk8er is offline   Reply With Quote Quick reply to this message
Old 02-01-2013, 12:39 PM   #12 (permalink)
Member # 153770
good info
atc70 is offline   Reply With Quote Quick reply to this message
Old 02-01-2013, 01:39 PM   #13 (permalink)
Provience's Avatar
Member # 138976
Pimp.
Old 02-03-2013, 07:56 AM   #14 (permalink)
Member # 118757
Originally Posted by atc70 View Post
good info
Pimp.
If y'all are talking about my post.. maybe I should request it be added to the FAQ sine I think it's a bit lacking.. what you guys think?
swdr4x4
Old 03-23-2013, 10:39 PM   #15 (permalink)
Member # 153770
yes definitely
