Build a set of BULLETPROOF Toyota axles - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-09-2012, 09:03 PM   #1 (permalink)
Member # 228178
Here's the deal. I own a box stock 85 4-runner. I would like to some day turn it in to a truggy type build. I would like to stay with all Toyota parts except for the engine. Engine will be a BUILT 4bt. Manual transmission dual transfer cases. 4 link front and rear. Where my knowledge is lacking is in the axle department. To stay true to my vision for the truck, I would like to keep the Toyota axle housings front and rear. The task I lay before you fine gentlemen is this. Spec out the rest of the axles for me. Also I would like to know the maximum tire diameter I could run with each set-up. Thank you in advance gentlemen. I have searched but have not come up with exactly what I am looking for.
EDIT: After the first couple of answers I have revised the question. Instead of a 4bt lets say the engine is a 1.9 TDI. Afterall, the main focus of the engine was diesel.
solidrunner85 is offline   Reply With Quote Quick reply to this message
Old 12-09-2012, 09:07 PM   #2 (permalink)
Member # 231156
AFAIK 4BTs are real heavy engines. I don't think you'll have much luck running toyota axles unless this is just a street truck.
Logan81Pickup is offline   Reply With Quote Quick reply to this message
Old 12-09-2012, 09:12 PM   #3 (permalink)
shoes optional
drewp's Avatar
Member # 142117
you cannot build a set of bullet proof toyota axles especially with thte stock housings like you mentioned... call or go to the trailgear website, they sell completely assemble axle assemblies for people like you
I NEED A HARLEY SS175 PISTON!!!!!!!!!!!!!!!!Found and now its time to build a bobber
drewp is offline   Reply With Quote Quick reply to this message
Old 12-09-2012, 09:13 PM   #4 (permalink)
Member # 192976
Even if a street truck the housing will smile at you in a matter of no time. Just build a set of tons and slap a toy emblem on the diff cover and call it a day. I have have to ask why the hell do you want to ruin a stock 85 runner with a 4bt? There no benefit what so ever in having a 4bt in a toyota mini.
02 Tacoma - Skids, sliders, 35's
Carolina Trailblazers
Redneck92 is offline   Reply With Quote Quick reply to this message
Old 12-09-2012, 09:15 PM   #5 (permalink)
I'm Zach
Beat95YJ's Avatar
Member # 22176
4bt and toy axles/t-cases might require rethinking.
:tank:
Old 12-09-2012, 09:16 PM   #6 (permalink)
Member # 228178
OK...so how about we change the engine to a 1.9 TDI? Diesel was the main focus of the engine. How does that change the answers already given?
Old 12-09-2012, 09:26 PM   #7 (permalink)
Wilson's Avatar
Member # 7233
None
Old 12-09-2012, 09:28 PM   #8 (permalink)
Member # 228178
So what I am reading is, no matter what you do to a set of Toyota axles they will never be bulletproof is this correct? Or they will just not be bulletproof with a diesel engine?
Old 12-09-2012, 09:30 PM   #9 (permalink)
I'm Zach
Beat95YJ's Avatar
Member # 22176
Yes, toy axles will never be bulletproof.
:tank:
Old 12-09-2012, 09:32 PM   #10 (permalink)
shoes optional
drewp's Avatar
Member # 142117
wont be bullet proof ever...if you are just dd and light wheeling you will probaby be fine
if you want to stay toyota go with fj80 axles...alot of us run fully built toy mini axles with 40inch tires on big rocks and get by just fine, but they do break eventually.
Old 12-09-2012, 09:33 PM   #11 (permalink)
Run what you brung.
gottoys2000's Avatar
Member # 40432
You didn't search very well.
http://www.pirate4x4.com/forum/toyot...yota-axle.html
88 4Runner, run what you brung.
Build:
gottoys2000 is offline   Reply With Quote Quick reply to this message
Old 12-09-2012, 09:35 PM   #12 (permalink)
Member # 228178
So why all the people using them? If it is as easy as swapping in a Dana 60 then why go through the effort to build up something not as strong? The way I look at it, you could be in to a set of 60's for cheaper than building up the stockers and the 60's according to you guys will always be stronger.
Old 12-09-2012, 09:36 PM   #13 (permalink)
Member # 228178
Originally Posted by gottoys2000 View Post
I found that thread, but he is not using the stock housing.
Old 12-09-2012, 09:40 PM   #14 (permalink)
NATER623's Avatar
Member # 132507
Man, the only way to go is with Birfield Eliminators
ECV-1846
NATER623 is offline   Reply With Quote Quick reply to this message
Old 12-09-2012, 09:44 PM   #15 (permalink)
shoes optional
drewp's Avatar
Member # 142117
building a 60 inst cheap either...usually people build the toy axles part by part and its what they have. if someone just had 5 grand to spend on an axle they wouldnt go toyota...well sometimes.
its also cheaper to get into a toy axle..usually 300 complete, chevy dana 60's are usually 1200ish complete.
the truck im building right now is my last all toyota build. my other truck will basically only be a toyota cab...maybe trans and motor...but i never want toy t-cases or axles again,,,,
Old 12-09-2012, 09:45 PM   #16 (permalink)
Member # 20957
Send a message via Yahoo to Hyena
Weight. Built tons weigh a metric shit ton more then built toyota axles.
Old truck
Jimmy's 4X4
Hyena is offline   Reply With Quote Quick reply to this message
Old 12-09-2012, 09:47 PM   #17 (permalink)
Member # 228178
This was my thought for wanting to stay Toyota. So lets say weight was an issue. What would be the best built set of Toyota axles?
EDIT: Or should I say, less likely to break set of Toyota axles.
Old 12-09-2012, 09:51 PM   #18 (permalink)
Blue MT. SnowRunner's Avatar
Member # 37649
Send a message via MSN to Blue MT. SnowRunner
Get a ruffstuff 9.5 lc housing run 80 outters with the hellforge knuckles and longfield birfs outta be plenty strong. My buddy is running same thing but with the mini outters and 30 spline longs behind and supercharged 3.4 on 39 iroks and they are holding up just fine and he is not afraid of the skinny peddle.
Link to my 85 yota build:
Blue MT. SnowRunner is offline   Reply With Quote Quick reply to this message
Old 12-09-2012, 10:04 PM   #19 (permalink)
Member # 48072
Originally Posted by blue mt. Snowrunner View Post
get a ruffstuff 9.5 lc housing run 80 outters with the hellforge knuckles and longfield birfs outta be plenty strong.
x2!!!
85 4Runner with some stuff.
Mawnov is offline   Reply With Quote Quick reply to this message
Old 12-10-2012, 01:03 AM   #20 (permalink)
Member # 43587
Send a message via AIM to TBItoy
Because tons and 35s is dumb.
I find it quite entertaining when people are like "I'm gonna swap in a 4BT CUMMINS! DIESELS IS COOL!!".
Fuckin 4BT with accessories is 800+lbs. For a 4 CYL!
A 1.9 VW or small merc diesel might make sense, if you like that sort of thing.
The Gremlin - small ugly linked beater Toyota
TBItoy is offline   Reply With Quote Quick reply to this message
Old 12-10-2012, 02:01 AM   #21 (permalink)
Provience's Avatar
Member # 138976
It seems like axle questions are really frequently asked here. Somebody from, say Colorado, should compile a list and sticky some info or some shit.
I just want to build cars, collect watches and get tattoos.
Old 12-10-2012, 04:00 AM   #22 (permalink)
Dick Head
jroach3210's Avatar
Member # 166048
Genius!
99 4runner 3.4 5spd boosted and locked
79 pickup 2rz, w56, dualed, e-locked, caged and injected
Build Thread-ish
jroach3210 is offline   Reply With Quote Quick reply to this message
Old 12-10-2012, 05:22 AM   #23 (permalink)
Member # 228178
I'm not sure if diesels are cool, but it's what I know. I was a Generator Mechanic in the Army for 4 years and after that for 3 more years in Iraq. I know the 4bt inside and out. I know it is heavy, but did not know how that would translate in to a vehicle of this type. Now that I do, I am considering any other type of lighter weight diesel engine.
Old 12-10-2012, 07:55 AM   #24 (permalink)
Member # 79221
Look at it this way then. 500+ ft/lbs of torque + 7.8" ring gear = That will just about cover it.
4BTs are great motors. Good luck getting one to fit into a mini truck though. I've done it. Its not fun. We moved the whole cab back 6" on the frame to get it to clear the firewall.
IMHO, one tons are the way to go under that motor. especially a "Built" one like you are talking. Don't waste time with Toyota axles. And, I am most definitely a Toyota guy.
Also plan on a lot of lift to clear the oil pan. 4BTs are very tall.
The one we mocked up was going into a truck with a 14B rear, D60 front and 42" TSLs. It needed all of it IMHO behind that motor. Both to clear the pumpkins and to clear the motor.
Scotty
970-420-4198
Ruffstuff Racing Sponsored
AddictedOffroad is offline   Reply With Quote Quick reply to this message
Old 12-10-2012, 08:06 AM   #25 (permalink)
Member # 228178
Scott, while I respect your opinion and appreciate you taking the time to answer my silly questions, how would your answer differ if the engine was a 1.9 TDI?
