pinion angle - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-15-2013, 06:09 PM   #1 (permalink)
toyotanewbi85's Avatar
Member # 155600
pinion angle
It's tuesday!!!
just installed f-150's one the rear and my pinion angle took a dump.
need opinions........
-Take out the over load? will be running an anti-wrap half-leaf on top.
-French the chevy hangers?
-Rotate the spring perches?
-Shims underneath the springs?
Flame suit is on
toyotanewbi85
87 longbed with some things glued on.
toyotanewbi85 is offline   Reply With Quote Quick reply to this message
Old 01-15-2013, 06:54 PM   #2 (permalink)
Member # 139159
Pulling leafs won't do anything. Frenching is alot of work.
Rotate perches is less work then frenching. Just put shims in.
"You break on the trail, You BECOME the trail!" - drunk guy
MY BUILD
85dhor is offline   Reply With Quote Quick reply to this message
Old 01-15-2013, 06:54 PM   #3 (permalink)
Trailbusters4x4 club
FuzzyZ's Avatar
Member # 117547
How about some pictures???
83 toy pickup, 02 TJ, 02 GMC 2500HD, 86 4runner
Trailbusters4x4 club Solano County
ECV 1004
FuzzyZ is offline   Reply With Quote Quick reply to this message
Old 01-15-2013, 07:08 PM   #4 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
If you decide to run shims, (which I hate) make sure to get steel ones and weld them to the spring perches. The aluminum ones will break and get spit out at the worst possible time, happened to me on a drag car.
Myself, I would get new perches and do it right!!!
Old 01-15-2013, 07:15 PM   #5 (permalink)
Member # 129425
i use bolt on steel shims. i get them from 4crawler.com been running them in three different rigs for years and never had a problem
toyotatime is offline   Reply With Quote Quick reply to this message
Old 01-15-2013, 08:01 PM   #6 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
I ran them also, and they kept turning sideways, then I took them off a welded them to the perches, problem solved!!! Yes, the center pin was tight, very tight!!!!
Old 01-16-2013, 06:30 AM   #7 (permalink)
lol
IEATRKS84's Avatar
Member # 118035
just weld new perches, best choice out of them all.
IEATRKS84 is offline   Reply With Quote Quick reply to this message
Old 01-16-2013, 07:25 AM   #8 (permalink)
waskillywabbit's Avatar
Member # 32061
Send a message via AIM to waskillywabbit Send a message via Yahoo to waskillywabbit
Rotate the perches.
waskillywabbit is offline   Reply With Quote Quick reply to this message
Old 01-16-2013, 09:39 AM   #9 (permalink)
Member # 1418
Originally Posted by waskillywabbit View Post
Rotate the perches.
and make new ones that are a little bit taller
84 4runr influenced by a F-toy and rustbucket cj2a with title, with 22re, ..... Potato V4.0
Kyron is offline   Reply With Quote Quick reply to this message
Old 01-16-2013, 10:09 AM   #10 (permalink)
Member # 139159
Why taller?
MY BUILD
Old 01-16-2013, 02:04 PM   #11 (permalink)
Member # 155600
Thanks for the quick replies everyone! i hope to drive it tonight and see how bad the vibrations are.
It still bugs me to have the pinion sit at this angle, so ill grab so new perches and rotate that pinion up and out of the way.
Thanks y'all
toyotanewbi85
Old 01-18-2013, 06:40 AM   #12 (permalink)
Member # 1418
Originally Posted by 85dhor View Post
Why taller?
flat springs flex better than arched ones
Old 01-18-2013, 06:59 AM   #13 (permalink)
Member # 139159
You make no sense. Taller perch is the same as a block. it doesnt change the spring.
MY BUILD
Old 01-18-2013, 08:29 AM   #14 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
Yeah, so you can get axle wrap. Longer I do understand, taller makes no sense to me!!!!
