Tips on Bobbing Beds - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-15-2003, 10:09 PM   #1 (permalink)
Member # 21150
Send a message via AIM to DontStall_RockCrawl
ok, well i plan on bobbing my bed tomorrow on my 84 single cab longbed. any tips you guys wanna recommend. what kinda cutter did you guys use? any pics?
DontStall_RockCrawl is offline   Reply With Quote
Old 07-15-2003, 10:23 PM   #2 (permalink)
Member # 20208
Location: Pollock Pines, but dont worry, I decided to keep my full set of teeth, unlike most everyone else up here...
angle die grinder with a 3 in green corps cutoff wheel. they got em at custom colors, or a plasma torch
[QUOTE=Myanarchy;6682920] Thanks for the tips, I think I'm gonna stick it between max volume and his boyfriend's pelvis. The force of their love could crush a bowling ball[/QUOTE]
sickfab is offline   Reply With Quote
Old 07-15-2003, 10:24 PM   #3 (permalink)
TNToy's Avatar
Member # 5776
To cut the body, use cutoff discs in your angle grinder. END OF DISCUSSION.
I've used a sawzall, air die grinder, plasma cutter, tin snips, and probably half a dozen other tools to cut sheetmetal. Use an angle grinder and 3-4cutoff discs. Fast method that's by FAR the cleanest and striaghtest. Clean is nice, but straight is **VITAL** for a good alignment after the cut.
Bobbing my 4Runner 12 inches:
Day 1 - http://www.pirate4x4.com/forum/showt...&highlight=bob
Day 2 - http://www.pirate4x4.com/forum/showt...&highlight=bob
Day 3 - http://www.pirate4x4.com/forum/showt...27#post1553827
Bobbing ChopSuey's 4Runner after doing mine:
Run a search in the Toy forum for "bob" and "bobbing"... should tell you a bunch.
[size=1]ASE Certified Master Automotive Technician
Toyota Certified Expert Technician
Volvo Certified Expert Technician
Suzuki Certified Master Technician
IDPA Certified Master Cardboard Killer[/size]
TNToy is offline   Reply With Quote
Old 07-15-2003, 10:37 PM   #4 (permalink)
RMW
Moo 2 U
RMW's Avatar
Member # 16565
Send a message via AIM to RMW Send a message via Yahoo to RMW
i'll support TNToy's suggestion. ANGLE GRINDER CUT OFF DISCs, tho it only took me 2 to do mine (but since i was cutting over the wheel wells i think i had less to cut). the cut is damn staight and turned out well.
no real intetion as of yet to put a section back on the back again (think boogerweldz old truggy kinda cut on the back) but the 4.5" cut off discs worked really well to cut off the ass-end.
[_] Show signatures.
RMW is offline   Reply With Quote
Old 07-15-2003, 11:02 PM   #5 (permalink)
Member # 21150
well currently my friend has my welder and i am letting him borrow it. what will require welding? i dont plan to put the tailgate back on but i do plan to keep the lights. i have an angle grinder and the cutoff discs
Old 07-15-2003, 11:12 PM   #6 (permalink)
Member # 14778
Is everyone in good moods lately?
Dude... bobbing beds has been covered way too much,SEARCH! You'll be amazed at what you'll find.
I used tape to mark the lines, a sawzall to cut the bed sides, jigsaw for the floor and a welder to weld the other half back on. Took 13" out.
Again, SEARCH!
Toyofast is offline   Reply With Quote
Old 07-15-2003, 11:52 PM   #7 (permalink)
Member # 12662
skill Saw and a Sawzall is all I use to cut it.... just get a long straight edge and do lots of measuring
1943 Flat Fender Medic Special 4.3l/th350, dual toy t-cases D44/D60, on 38 tsl's and some other cool stuff
1998 dodge cummins 4X4 sled puller
[url=www.sanjuanrockcrawlers.com] San Juan Rock Crawlers[/url]
Chrisf is offline   Reply With Quote
Old 07-16-2003, 12:00 AM   #8 (permalink)
Member # 13696
Whats the deal with the flap disc's do they actually grind down metal or do they just clean up the grind wheel marks?
Kcrawler is offline   Reply With Quote
Old 07-16-2003, 12:40 PM   #9 (permalink)
freds40's Avatar
Member # 14437
Measure, Measure, Measure. I used a die grinder with a 4" wheel worked good. If you do weld it back together, use .023 wire, you can actually run a bead on the tin foil, i mean sheet metal.
Marlin Crawler Sales
www.marlincrawler.com
559-252-7295
brendan@marlincrawler.com
freds40 is online now   Reply With Quote
Old 07-16-2003, 12:48 PM   #10 (permalink)
TNToy's Avatar
Member # 5776
They grind a little bit slower, but MUCH smoother.
I use a grinding wheel, then finish up with a flap disc.... if it's a small weld bed, just straight to the flap disc. They rock.
Old 07-16-2003, 12:55 PM   #11 (permalink)
freds40's Avatar
Member # 14437
The discs I use are about 4.5-5". You have a backing piece that attatches to the grinder and then you put on the disc. I use 36 grit and it's nice and smooth. If I want it really smooth, I can throw on an 80 grit disc.
559-252-7295
Old 07-16-2003, 01:04 PM   #12 (permalink)
Member # 8626
I disagree
TNT: sorry, but cut-off wheels are NOT the end of discussion. is it the cheapest solution....yes. is it the easiest and most accurate of all the cheap solutions....yes. is it the end of discussion....no.
DONTSTALL: if you have the resource, i'd recommend a plasma cutter. simpler, more accurate, and much faster than any cutting discs. granted, you have to have access to one, and they aren't cheap....but it is the overall best solution. if you set it up right, the cuts are much cleaner and it makes cleanup for welding slightly more hassle-free.
Again, if you want the cheapest route...TNT is right on. if you want the best route, go plasma. To me, there is no middle ground, and don't even consider a oxy-a setup....metal's too thin.
Max
'86 Runner: Sold it...Haven't seen it :(
Ishikawa is offline   Reply With Quote
Old 07-16-2003, 02:03 PM   #13 (permalink)
Member # 10379
Originally posted by DontStall_RockCrawl
well currently my friend has my welder and i am letting him borrow it. what will require welding? ............
you gotta be shittin me! you gotta weld everything that you cut
off, sorry for being so blunt but, you need to doa little research B/4 trying this or anything else.
Don't tear it apart and then not finish it.
"[SIZE=7][COLOR=black]ATOR Sucks !! click link below[/color][/size]"
[url]http://www.pirate4x4.com/forum/showthread.php?t=575873
[/url]
fabricator is offline   Reply With Quote
Old 07-16-2003, 04:45 PM   #14 (permalink)
Member # 18089
Here's a cheezy write up I did of my bob job...
http://members.cox.net/krawlinacoma/new_page_9.htm
I'd also have to say PLASMA CUTTER if you have access to one.
TIP: cut about 1/16" from your line then grind down to it for a finished edge. This is the technique I used on my bob. You can see how tight the seam is in one of the pics towards the end.
TIP: Use solid wire WITH GAS. It's a MoFo to do with FluxCore!
Happy Bobbin'!
Yoats n stuff
Hoodlum is offline   Reply With Quote
Old 07-16-2003, 06:39 PM   #15 (permalink)
Krusty's Avatar
Member # 906
sawzall off the rear, cut x " out and weld back----- 2 hours!
cap off the stock tail lites (they WILL break on every run), and mount Grote rubber mounted tail lites in the tailgate.
Krusty, aka. Krustoy
Official Tin Bender.
older than dirt/before rocks were invented!
*Cancer survivor since 02-06*
Grand Marshall -KOH 2012
"Dad' to some of the greatest kids EVER
I was around when Pearl Harbor was bombed !
Krusty is offline   Reply With Quote
