#80 (permalink) |
Member # 22547
no pics yet. but the formula chassis is officially welded to the frame. its a big day around here
so who's comin over this weekend to get this thing running for the jambo?
-Hobie GOTPROPANE.COM HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER! |
#81 (permalink) |
Member # 22547
well i got my ifs box mounted and the hysteer setup.....
here are some updated pics see my frame is actually welded to the frame..its not a poser so tommorrow i will finish cutting out the pedal assembly and steering column.... thing left to do just to get it to the jambo: brakes make front shock mount elctrical mount radiator and power steering resivour fab up temp seat make sqaure shafts mount gas tank mount arb air comp i need to track down 2 bolts that hold the front caliper on. i dont have one set. the other is there but not on the passenger side......where could i get these exact bolts from?
#82 (permalink) |
Member # 22547
i got the pedal assembly in and steering column in....
WARNING: THESE PICS MAY ACTUALLY BE TRAUMATIC TO SOME PEOPLE pedal assembly
-Hobie GOTPROPANE.COM HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER! Last edited by a2b; 04-16-2004 at 02:29 AM. |
#83 (permalink) | |
Member # 4091
but that ranks real high on the botty fab scale its not even straight man ![]()
im dumb blah |
#84 (permalink) |
Member # 23253
holy hell, very traumatic, i'd revmove that shit, weld in a nice piece of steel to mount the booster and clutch master too and the steering colum, then i'd make a nice stainless firewall to go along the front. you dont need any of those blinker switches and shit...............man another tip is to remove the paint where your going to weld it makes it much nicer...........i can wait to see this thing finshed..........i sure to hell hop you dont put wood floors in it and tie a milk crate down for a seat
TOYOTA $X$ |
#85 (permalink) | |
Member # 22547
ya, i will make a nice wall and pedals...but later...
#88 (permalink) |
No comment
STOP !!! NOW !!!
go cut that shit off and do it right. that is just wrong.. you get an A for effort but lets just chalk that up to a practice run. seriously, cut that shit off and try again. stop trying to rush it together for the jambo and take your time and get it right. you will learn more and improve your fab skills by not slappin it together. look at wilsons pedal setup and copy it. it is a very simple design that can be made from pre made tabs available from www.polyperformance.com send dave at poly a pic of wilsons pedals and tell him you need those tabs and a 3/4 x 3/4 heim. it will cost you under 20 bucks. then take your time and do it right |
#89 (permalink) |
No comment
ok i just looked at those pics again and if you bring that to the jambo i will light it on fire on the lake bed.
what is your addy ? i am going to the hardware store tomorrow and buying you a 4" grinder and you are going to cut that shit off and redo it. |
#90 (permalink) | |
Member # 15071
you want turn signals on that buggy why?
In the pics you have the turn signals on it. Why!? camos right btw sup camo man Boy
Spawn of ReTodd And proud supporter of wheeling and the Tin Benders. By the way.....My Dad GETS IT What DO YOU NEED!! |
#91 (permalink) |
Member # 22547
well i was just making do until that pedal assembly was available
and what is so wrong, it works and it looks better than your fire flaming grill thingy ![]() no, really, j/k...i will fix it or how about i just paint over it real nice so no one will notice
-Hobie GOTPROPANE.COM HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER! Last edited by a2b; 04-16-2004 at 01:59 AM. |
#92 (permalink) |
Member # 422
Hobie, cut that crap off
Todd Steele TINBENDERS Formula Toy #006; Thanks to Deaver Spring, High Angle Driveline, Longfields, Rock Buggy Supply, PRP Seats, Marlin Crawler, Coast Motor Supply and RockStomper. [url=http://www.tinbenders.org]TinBenders.org[/url] |
#93 (permalink) |
No comment
i was serious....what is your addresse ? email me at elinker@creativebeginnings.com
#95 (permalink) | |
Member # 24269
Location: Way closer to the Hammers than you!!! Was Montrose, CO
Official OG13-2013 KOH Recovery Team. Formula Toy #11 is For Sale... PM me. |
#96 (permalink) | |
Member # 22547
done ![]() thanks for the offer but i have a grinder already...
-Hobie GOTPROPANE.COM HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER! Last edited by a2b; 04-16-2004 at 10:56 AM. |
#98 (permalink) |
Member # 22547
i am glad everyone is here to help. so, i think i am cool on the pedal assembly. i am going to get a pedal assembly here from a race shop. the brake will have 2 master cylinders. will that work?
also, could someone post pics and or explain to me a decent way to fab up the steering column?
#99 (permalink) |
No comment
yes dual master will work great. the benifit to running that setup is that you still have good brakes when the engine dies since you don't run the vacuum booster.
for the steering it is really simple. get a piece of 3/4 rod ( either hollow or solid ) and weld on the stock toy ujoint down at the steering box. then put a heim joint at the dash bar and weld a tab on to hang the heim. order a steering wheel quick disconect from summit and put your steering wheel on. arron has pics of erics rig on his thread. |
#100 (permalink) | |
No comment
I was thinking about this post on the way home from work. it is kinda like those people who call the 1-800-suicide hotline as a cry for help. they don't intend to really do it they just want help. maybe we need a 1-800-bootfab hotline for aspiring fabricators who are tempted to just slap their junk together.
