90 4runner build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-06-2015, 10:32 AM   #1 (permalink)
Member # 221653
90 4runner build
Picked this thing up a couple years ago and have been slowly working on it as a long term project and hopefully long term wheeler. It's the 3rd in my stable of toyota crawlers so only really gets attention when I'm not wrenching on the other two. Anyway on to the pictures and progress.
Bought it wrecked and muddy but running 22re for $600.
thebonds is offline   Reply With Quote Quick reply to this message
Old 11-06-2015, 10:34 AM   #2 (permalink)
Member # 221653
Pulled front sheet metal
And engine
And more
Old 11-06-2015, 10:38 AM   #3 (permalink)
Member # 221653
Started collecting parts
Got a 9.5" 14bolt rear for free so decided to use that.
Paid $900 for a front dana 60
Old 11-06-2015, 10:43 AM   #4 (permalink)
Member # 221653
Attempted to cut the brackets off the rear frame
But it was much easier to do this.
Old 11-06-2015, 11:01 AM   #5 (permalink)
Member # 221653
Held together with self tapping screws here
Old 11-06-2015, 11:04 AM   #6 (permalink)
Member # 221653
Waiting for new welder to show up, built some link tabs from an old rusty cactus
And then the new arrival.
Old 11-06-2015, 11:09 AM   #7 (permalink)
Member # 221653
Work space can be kind of cramped at times
And sometimes any sort of motivation helps the build along
Fuel door was long gone.
Old 11-06-2015, 11:14 AM   #8 (permalink)
Member # 221653
About 2 inches from the top of headrest to the glass.
Old 11-06-2015, 11:21 AM   #9 (permalink)
Member # 221653
Welder and played rear spiders
Regained access to axle c-clips
5:13 gears. First time attempting to set up a ring and pinion. What I ended up with and went with. Should be fine for a trail rig.
Old 11-06-2015, 11:24 AM   #10 (permalink)
Member # 221653
More rear axle work. Went with ruffstuff horizontal mount axle link bracket. My first attempt at a link suspension as well.
Old 11-06-2015, 06:22 PM   #11 (permalink)
Member # 221653
More plates tonight. Waiting for a Bluetorch Fab weld together diff cover to show up to replace the super thin factory piece.
Cardboard
Old 11-07-2015, 05:34 AM   #12 (permalink)
Member # 103621
Looks like a solid start. Nice job on the sheet metal work.
1982 Toyota - Dirt Squirrel - LQ4/Atlas 4.3, D60/14b w/ Reids & RCVs, 3-link/4-link, 43" stickies
the_white_shadow is offline   Reply With Quote Quick reply to this message
Old 11-07-2015, 11:04 AM   #13 (permalink)
toyotanewbi85's Avatar
Member # 155600
x2 nice job on the sheet metal work. I'm anxious to see how the sf 14-bolt holds up. keep up the good work!
toyotanewbi85
87 longbed with some things glued on.
toyotanewbi85 is offline   Reply With Quote Quick reply to this message
Old 11-07-2015, 12:38 PM   #14 (permalink)
Member # 529642
Looks killer!
dyno_mike is offline   Reply With Quote Quick reply to this message
Old 11-07-2015, 02:23 PM   #15 (permalink)
Member # 221653
Thanks everyone. Hopefully it should hold up alright. Probably going to only run 39.5's. Haven't committed to an engine yet, but leaning towards a 4.3 since i just recently did that swap in my other crawler and really like it. But right now any engine is an option, just waiting for the right deal at the right time. Actually, other than axles, I'm kinda wingin' it here as to what drive train parts I am going to use.
Anyways. Dropped the frame from the body. Not starting out with much here anymore, and time to buy more Jack stands.
Old 11-11-2015, 07:22 PM   #16 (permalink)
Member # 221653
Little bit of mockup. Just kinda laying stuff out where ever it looks like it should go at this point.
Old 11-14-2015, 08:03 AM   #17 (permalink)
Member # 221653
Plastic links
Old 11-24-2015, 09:16 AM   #18 (permalink)
Member # 221653
More pics of little bit of progress
Old 11-24-2015, 09:21 AM   #19 (permalink)
Member # 529642
Lookin good!
Old 11-24-2015, 07:33 PM   #20 (permalink)
Member # 221653
Squared the bent frame up and added the front section.
Left frame rail was bent in towards the right. Used hi-lift and a come-a-long to get it back in place.
Burn it in!
Old 11-24-2015, 09:12 PM   #21 (permalink)
Member # 577898
More!!!!!
VayaConYota is offline   Reply With Quote Quick reply to this message
Old 11-26-2015, 08:39 AM   #22 (permalink)
Member # 221653
Been thinking about what I will do for the front suspension on this thing. Right now I'm leaving towards going with a spring under set up with full hydro steering. This should keep everything nice and low and stable. Shackle will be in the rear where they should be
I think the ride is nicer with them in the rear and they always look too vulnerable sticking out in front of the frame.
Burn it in!
Old 11-26-2015, 09:02 AM   #23 (permalink)
YotaAtieToo's Avatar
Member # 25632
OH look another person basing their front shackle experience off of a stock jeep or something
Old 11-26-2015, 11:08 AM   #24 (permalink)
Member # 221653
I have no experience with stock jeep shackles, I know I've bashed my front spring mounts off plenty of rocks. I can imagine the shackles getting pretty beat up sticking out front like that. Not trying to start any sort of shackle location debate. There are plenty of threads just for that. if they work good for you, rock em
... But I still think they are pretty
Burn it in!
Old 11-27-2015, 12:08 AM   #25 (permalink)
Member # 25632
Not quite as as a semifloat 14b.....
Sorry, I couldn't resist.
