20R head on 22R block - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-24-2004, 07:23 PM   #1 (permalink)
Member # 21744
Send a message via AIM to cotton4toyota4x4 Send a message via Yahoo to cotton4toyota4x4
Ok I did the search thingy and could not get it to work
Also looked in faq and did not see it either
What I have is a 1980 20r with a good head but with a few busted rings . Just found a short block 22r 1986 .
What will I need to use the 20r head on the 22r motor ?
Will it work at all?
I can buy the short block 22r cheaper than rebuilding the 20r.
About 200 bucks cheaper
MUD IS FUN !!!!
1980 Toyota 4x4 33at's 2.5 body lift
Ain't no rocks to climb here in South Georgia
cotton4toyota4x4 is offline   Reply With Quote Quick reply to this message
Old 03-24-2004, 07:55 PM   #2 (permalink)
blacktoy's Avatar
Member # 22837
it will work, I just can't remeber all the details of the combo, give LC Enginerring a call, they can help you
blacktoy is offline   Reply With Quote Quick reply to this message
Old 03-24-2004, 07:56 PM   #3 (permalink)
Member # 24837
never been able to get a straight answer on it. some people swear by it, others hate it
never seen it done by anybody i know, so i can't really tell
kyle_22r is offline   Reply With Quote Quick reply to this message
Old 03-24-2004, 10:25 PM   #4 (permalink)
Member # 28698
it would be nice to get a little bit of feed back from some of the guys out there that have made this mod in past .
I have spoken to a couple guys that say it boosts compression, but i wonder what is needed if anything to ensure the head will breath as well, are the valves a smaller size or the same size?
hard way is offline   Reply With Quote Quick reply to this message
Old 03-24-2004, 10:29 PM   #5 (permalink)
blacktoy's Avatar
Member # 22837
the valves are smaller on the 20r head, but with porting, some bowl work and bigger valves the 20r head can breath better than a stock 22r head
Old 03-24-2004, 10:43 PM   #6 (permalink)
Member # 18149
I swear by mine!
I used 22r valves(just slightly bigger).
The 20r heads have a much straiter shot through the intake passages, they boost compression, it is a hemispherical cumbustion chamber, and the head just bols on!
TRDV is offline   Reply With Quote Quick reply to this message
Old 03-24-2004, 11:31 PM   #7 (permalink)
crash's Avatar
Member # 1588
I ran a 20r head on my 22r years ago. It was ported/polished, but stock valves. Now, from what I have read, the head alone flows better untouched than a 22r head does, and you get alot of gains by not olny going bigger valves, but doing alot of bowl work. But the downside, you won't produce alot of low end torque, if any really. I wasn't impressed, and dumped that idea and built a good 22r head (agressive bowl work) and it was far better...
But presonally, just dump the POS 22r all together
Mike Crash Kash
Old 03-25-2004, 04:06 AM   #8 (permalink)
Member # 23249
Send a message via AIM to TEAMFX3
You mean 'yota 4cyl's actually make torque?? C'mon you must be pullin my leg!
85 4Runner with some stuff.
TEAMFX3 is offline   Reply With Quote Quick reply to this message
Old 03-25-2004, 04:07 AM   #9 (permalink)
stomper4x4's Avatar
Member # 22805
Originally posted by TRDV
I swear by mine!
The 20r head is a open chamber head like the pre 85 22rs so swaping the head onto a 85and up 22r short block does not boots compresion, unless you have the head shaved (20r head 80-81cc chamber 81-84 22r head 82-83cc chamber 85-95 22r head 58cc chamber).The main reason for swaping to 20r head on a 22r block is becouse the port configuration alows for better flow with there round intake ports (22r heads have square intake ports).
[B][COLOR=Green][QUOTE]
So you want all for yourself alone
And you don't think about the other man
Let me tell you my friend if you gonna live this life
It's not good for you to build strife
Robert Neshta Marley ; Cravin choke puppy[/QUOTE][/COLOR][/B]
stomper4x4 is offline   Reply With Quote Quick reply to this message
Old 03-25-2004, 12:25 PM   #10 (permalink)
Member # 18149
right,
Learn something new everyday
Old 03-25-2004, 01:07 PM   #11 (permalink)
Member # 5315
Like Blacktoy said, LC Engineering has info on that, this is from their website:
It is possible to run a 20R Head on an 85-95 laser block. In order to keep the cam and crank centerline consistent with an 85-95 head, you must mill the 20R head to a measurement of 3.130 (measured from the bottom of the front cam journal to the deck of the head). Remember to re-machine the oil passage back into the deck surface of the 20R head after milling to retain oil passage to the top of the motor.
http://www.lcengineering.com/home.htm
take a look at their "Tech Notes", good reading
86 22R Weber carbed Toy Truck
Coop 50 is offline   Reply With Quote Quick reply to this message
Old 03-25-2004, 01:11 PM   #12 (permalink)
Member # 5315
You can also go to the "Tech Info" on this site for the 20R and 22R.
http://www.toysport.com/index.htm
Old 03-25-2004, 09:25 PM   #13 (permalink)
Member # 23216
This combination will not work with out modification.
The 1980 20R is a 98 row timing chain motor [75-84], and the 86' is a 96 row timing chain short block [85-95].
The 20R head must be surfaced 0.147" [as i recall] this will be the thickness of the 85-95' head. Then the factory chain will fit.
I have done many of these conversions, but due to the smaller combustion chamber, only the factory cam can be used unless you flycut the pistons for valve clearance.
You must also use the 85-95' shorter head bolts.
I have been running this combination in my 1980 crawler truck for years now. It increased my compression ratio from 8.4:1 to 10:1 and was quite impressive when i built it.
At first i installed the larger 22R valves in the 20R head but was beat out by a motor using the factory valves.
I am at present running a 90' "lazer" block with a BMW double row timing chain, turbo oil pump and cooler, and a ported 20R head with factory valves and a 86' turbo camshaft.
Marlin
Marlin Czajkowski
Owner - Marlin Crawler Off-Road
559-252-7295
Marlin Crawler is offline   Reply With Quote Quick reply to this message
Old 03-26-2004, 06:46 AM   #14 (permalink)
Member # 25724
Marlin You stated that you must flycut the pistons, Are you refering to the 85 up 22r. I got a 1983 22r with a 1979 20r head popup pistons and way bigger then stock cam, I checked the clearence to the pistons/valves on this motor and there was alot of room. Yes you are right the stock valves will build more torque, I was going to go with bigger valves but i would have to give up any chance of low end torque. I also went with dual coil valve springs, to up the valve seat preasure wich also will bring back some torque. This motor turns it on right around 1500rpm and falls off about 4500rpm. This combo works killer on my motor.
86 samurai, dana/44 front, ford9"rear,4.88 gears, ARB lockers. Toyota 22r motor/tranny/tcase, Warn 8274 on front, Im not getting stuck. http://www.teamultimate4x4.com
mypayperview is offline   Reply With Quote Quick reply to this message
Old 03-29-2004, 02:43 PM   #15 (permalink)
Member # 23083
Send a message via Yahoo to lal357
man i cant beleive it finally some answers i have been searching this combo for 4 months now trying to get some info on the combo from what ya'll say i should be fine (80-20r head 83 22r block ) i even went ahead and got a 92 block just incase the 83 wouldnt work .the answers i got in the past were that it wouldnt work unless i did some major machining to the gain is not as good as just going with a 22r complete setup
oh and
lal357 is offline   Reply With Quote Quick reply to this message
Old 03-29-2004, 02:59 PM   #16 (permalink)
Member # 2986
Send a message via AIM to Chad
Here's what I was running:
'80 20R Head. Ported & polished intake and intake runners, just ported exhaust runners. Head cut to an overall height 3.797" Duel springs, stock 20R valves.
'86 Laser block 93mm bore. Stock crank & rods, 9.4:1 compression pistons. (No flycuts) balanced and blueprinted rotating assembly
TRD Stage 3 cam
Weber 32/36
Longtube Header
'86 Timing chain set with DOA guides
MSD 6A
Ran super stong for a 4 popper!!!!!!
[color=yellow][b]Chad[/b]
ASE Master Certified Technician
Off-Road.com Forum Administrator
'84 Extra Cab, 5.29's, Detroit, '98 Vortec 4.3 & 700R4, 7" Skyjacker, etc.....[/color]
Chad is offline   Reply With Quote Quick reply to this message
Old 03-29-2004, 07:59 PM   #17 (permalink)
Member # 25724
Chad sounds like a winning combo. But how's that weber working. I havent seen to many that work good off road..
Old 03-30-2004, 12:04 PM   #18 (permalink)
Member # 2986
The Weber worked great!!! No problems at all...other then almost straight up and down.
I ended up selling the whole deal because I'm putting intalling a Vortec 4.3 in.
Old 03-30-2004, 12:59 PM   #19 (permalink)
Member # 24837
seems like there's few people who like webers, because i'm happy with mine. works great offroad
i think i'm just going to combine the two 20Rs i have and make one good engine. i have a spare sitting in the back yard that definitely needs to be taken to a machine shop and checked out...the engine's probably been sitting 20 years! i figure i could at least use the head and intake off it and maybe the block i have in my truck...
Old 04-01-2004, 02:14 PM   #20 (permalink)
Member # 23083
how would they compare to a stock 2bbl asain from a 22r the donor engine came with a almost new carb but i also have a weber 32/36 either way a will need to get a adapter plate to use it on the 20r or go offy intake
Old 04-24-2004, 09:56 AM   #21 (permalink)
Member # 29718
Send a message via ICQ to 2RowTC4Runner Send a message via MSN to 2RowTC4Runner Send a message via Yahoo to 2RowTC4Runner
20R head modification link
This link might be helpfull
http://www.speedtoys.com/~oldmage/20RE-1.htm
Luc
2RowTC4Runner is offline   Reply With Quote Quick reply to this message
Old 05-18-2017, 03:17 PM   #22 (permalink)
Member # 758098
same exact swap
I'm doing the very same swap. 80 20r into an 86 22r.
The trick here, i gather, is that the 86 block is taller than the 20r or the earlier 22r. the later block will take the re head, i'm told, while the earlier 22r won't.
just talked to lc engineering- they say i'll need to shave the head to 3.130" (minus .160") to make things fit. They said the ports would have to be matched. This is looking very extreme for compression, so I'll probably dimple the chambers and cc them when i do the ports. There's a guy online has a used quad 44mm mikuni setup for 500 bucks for a 20R, that's really tempting me.
There's what i've managed to gather so far. I'm kindof getting I'm going to need a 20r intake manifold, though? The engine is in my 86 toy 4x4. It'll do 90 with marginally fat tires haha but i want it to be able to bury the speedo.
Or shall i just say hell with it and put a turbo on the thing? Looks like buyaparts got a kit on ebay for $486 i could adapt to blow-thru ok (needs downpipe-no biggie.) Cheaper than the used mikuni setup and all the head work i gotta say. makes 8 psi but the stock mill won't take much boost anyway they say.
chrisso is offline   Reply With Quote Quick reply to this message
Old 05-18-2017, 07:26 PM   #23 (permalink)
Mr Stubs's Avatar
Member # 102813
If you do a head swap and give your engine more compression are you prepared to run a better fuel?
I think it's a waste of time IMOP.
Help bring back Swartz Canyon, Join
The good guys...
Marlin Crawler, Hellfire Fabworks, Dave'z Offroad, gearinstalls.com (Zuk), Diamond Axle, RADesigns, Advanced Adapters, Jantz Engineering, G-Fab motorsports, Got Propane, JHF
Mr Stubs is offline   Reply With Quote Quick reply to this message
Old 05-18-2017, 07:32 PM   #24 (permalink)
Mr Stubs's Avatar
Member # 102813
7lbs + 110 octane propane = 116 hp and 136 TQ at the tire on a rig with 4ds, dual cases, and 5.29 gears.
I was able to drive through the clutch on 4wheel drive hill climb pulls.
The good guys...
Old 05-19-2017, 10:20 AM   #25 (permalink)
Member # 231056
That sounds like my kinda fun!
Do what you wanna do. That's what I do.
Stevsie is offline   Reply With Quote Quick reply to this message
