JB weld ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-30-2004, 04:57 PM   #1 (permalink)
Richard's Avatar
Member # 233
JB weld ?
my 20R has a bolt hole that is stripped , it is one for the exhaust at the back of the head , can I just fill the hole with some JB weld and jam the stud in , this is a temp fix till I can swap in my 22RE
[COLOR="Red"]The Weather Is Here , Wish You Were Beautiful[/COLOR]
Richard is offline   Reply With Quote Quick reply to this message
Old 03-30-2004, 05:22 PM   #2 (permalink)
Member # 22519
Send a message via AIM to werty
yes it is a good temperary fix I did it to 2 exaust studs. I also drilled a small 3/32 thru the head and thru the stud bolts then I put a pin and jb welded it in there. Held up till I did my rebuild and got a good head. It lasted about 6 months.
84, 4 seater, dove nosed, cut excab, 4.3l-36s= not so slow, Locked front and Rear FOR SALE!!!!
[QUOTE=ev13wt;9871460]Bad time to post nips?[/QUOTE]
werty is offline   Reply With Quote Quick reply to this message
Old 03-30-2004, 07:05 PM   #3 (permalink)
Member # 15316
I haven't done it for a while, but when I had stripped bolts from the exhaust to the head. I would just retap them and go one step higher using standard bolts. Worked for me no drilling holes bigger in exhaust or anything, just remember they are there if you ever take them out, so that you don't get them mixed up with the stock metric ones. Just giving you an idea.
4Runnerdude is offline   Reply With Quote Quick reply to this message
Old 03-30-2004, 07:09 PM   #4 (permalink)
Member # 10969
I like that idea better. I have NEVER had success with JB weld. IMHO JB weld stands for Junk Booger weld
Raptorman57 is offline   Reply With Quote Quick reply to this message
Old 03-30-2004, 07:14 PM   #5 (permalink)
Member # 5315
NAPA sells kits with the tap and helicoils, extra helicoils if you know what I mean.
86 22R Weber carbed Toy Truck
Coop 50 is offline   Reply With Quote Quick reply to this message
Old 03-30-2004, 07:18 PM   #6 (permalink)
Broke Bastard
Benny's Avatar
Member # 1129
I did the same thing to one of my manifold bolts. Still holding up a year later
Obamas war is a war on freedom
Hashtags are for fags
Benny is offline   Reply With Quote Quick reply to this message
Old 03-30-2004, 07:19 PM   #7 (permalink)
Richard's Avatar
Member # 233
If I decide to go this route , what size do I need or how do I find out out what size do you have a part#, It's on a 1980 20R
Old 03-30-2004, 10:02 PM   #8 (permalink)
Member # 404
Use the helicoil, that way you stay with the stock stud bolt.
The size for an 87 22RE is M10 X 1.25
helicoil part # 5543-10
You said exhaust manifold to head stud right?
The kit seems pricy but you will use it more than once, trust me.
Pete Newell 89 4RNR SAS W/ all the goodies. KJ6CXI
Toys on the Rocks FOTR CA4WDC TLCA BRC NRA AMA
Triple Threat Motorsports
chartdog is offline   Reply With Quote Quick reply to this message
Old 03-31-2004, 07:15 AM   #9 (permalink)
toyrunner's Avatar
Member # 36
Chevy rocker studs
tap and go!
I was told about this easy "fix" and it really is as easy as it sounds.
(7/16x14 or 16 tap)
The studs are the shoulderless rocker studs from a SB Chevy.
El cheaper than helicoil and won't pull out
Danny
2004 S-Runner Taco x cab
toyrunner is offline   Reply With Quote Quick reply to this message
Old 03-31-2004, 07:46 AM   #10 (permalink)
Member # 20435
Really! JB weld has gotten me out of a couple pinches. For a short term desparation fix , JB is king. Easy to carry and holds pretty decent. Jb quick works allright to.
turn up the good , turn down the suck!
B.E.R is offline   Reply With Quote Quick reply to this message
Old 03-31-2004, 04:21 PM   #11 (permalink)
Member # 2986
Send a message via AIM to Chad
I always use JB Quick Weld and it has been a great lifesaver over the years!!!! Never travel without it!
[color=yellow][b]Chad[/b]
ASE Master Certified Technician
Off-Road.com Forum Administrator
'84 Extra Cab, 5.29's, Detroit, '98 Vortec 4.3 & 700R4, 7" Skyjacker, etc.....[/color]
Chad is offline   Reply With Quote Quick reply to this message
Old 04-03-2004, 01:05 PM   #12 (permalink)
Ganoid's Avatar
Member # 27508
These work good too
Just remember to grind off the little collar or sink them in a bit so you dont hang up on the collar when installing your manifold. You should be able to just retap as the size isnt that much larger so no drilling should be needed.Learned this from another thread.
Ganoid is offline   Reply With Quote Quick reply to this message
Old 04-03-2004, 01:20 PM   #13 (permalink)
Member # 4703
It got bawz fixed at EC4RJ at Paragon last year(ripped out the drain plug in the rear diff.) Good thing I had some in my tool box.
sold my sh*t
but getting ready to start again
OffroadRunner is offline   Reply With Quote Quick reply to this message
Old 04-03-2004, 03:27 PM   #14 (permalink)
Member # 5787
Helicoil complete kit from napa is Part# 7703020
Jim
Yes I'm in the Navy. F/A-18 Jet Engine Mechanic.
“MICROSOFT: Where do you want to go today? APPLE: Where do you want to go tomorrow? LINUX: Are you coming or what?”
NavyDood is offline   Reply With Quote Quick reply to this message
Old 04-03-2004, 10:26 PM   #15 (permalink)
Richard's Avatar
Member # 233
Originally posted by Ganoid
These work good too
are these the right size studs
MRG Rocker Studs (3/8")
Part#: 1075
Price: $32.99
Old 04-04-2004, 05:29 PM   #16 (permalink)
Richard's Avatar
Member # 233
Old 06-11-2004, 06:49 PM   #17 (permalink)
Lowtorious's Avatar
Member # 2387
Send a message via AIM to Lowtorious
Come on Ganoid - spill it. I've got 3 stripped exhaust stud holes that need to be fixed.
Thanks.
Lowtorious is offline   Reply With Quote Quick reply to this message
Old 06-11-2004, 06:57 PM   #18 (permalink)
Booger Weldz's Avatar
Member # 2931
only success ive had with JB weld is to cover up real welds that looked like ass
color="lime">
Ducati street fighter 1098s. Spoiled 1wd.
Booger Weldz is offline   Reply With Quote Quick reply to this message
Old 06-11-2004, 07:45 PM   #19 (permalink)
desertPOS's Avatar
Member # 3835
you must've gone through that stuff by the case
Special Thanks to: West Kern Environmental Consulting,
desertPOS is offline   Reply With Quote Quick reply to this message
Old 06-11-2004, 07:51 PM   #20 (permalink)
Member # 2931
color="lime">
Old 06-11-2004, 09:01 PM   #21 (permalink)
Lowtorious's Avatar
Member # 2387
Factory stud - 10mm = .3937"
I think I might put 7/16" (top and bottom) studs in place of the 3 bad holes I have in my head - 7/16" = .4375" (a little over 11mm = .4331")
Do the holes need to be drilled first or I can I skip that and go right to the 7/16" tap?
I'm pretty sure all the original threads in each of the holes are gone. I planned on cleaning them out real well first then having at it with the tap. The main reason for asking being I think it's going to be a bitch to fit my drill down in the engine bay in the right spots and make straight runs - 2 front most holes are bad (top and bottom) and the rear most top hole is bad too.
Old 06-11-2004, 09:31 PM   #22 (permalink)
Lowtorious's Avatar
Member # 2387
This pretty much answers my question! Doh...
Old 06-11-2004, 11:52 PM   #23 (permalink)
jschell's Avatar
Member # 4709
You might get by with the JB weld, I would use it with the combination of a bigger SAE bolt to try and catch what little material there is to grab, it will get you by till you can do the helicoil. You need to pull the head to get to that rear bolt, drilling, tapping, the works. If you pull the head, you might as well put inserts in all the holes to prevent future occurance, also, studs in all rather than bolts work great. Oh yeah, something better than a helicoil, look for an insert called Timesert. I have these, they are a better design, faster to install. You can go to their home page to check em out. www.timesert.com
'85 Toy, crawler locked front and rear, on-board shower, on board air. '88 zuk, spoa, 6:1. grocery go getter.
jschell is offline   Reply With Quote Quick reply to this message
Old 06-12-2004, 02:52 AM   #24 (permalink)
desertPOS's Avatar
Member # 3835
i know what your welds looked like, I'm still running your old sliders
Old 06-12-2004, 07:08 AM   #25 (permalink)
Lowtorious's Avatar
Member # 2387
POS - thanks for the info. The Timeserts look quality.
