Fuel delivery? / 22R -to- 4.3 TBI swap - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-25-2004, 07:42 PM   #1 (permalink)
Member # 4836
*Update;
I ended up using a 87ish 4runner fuel tank and dropped an 89 chevy AC Delco (chevys brand), factory fuel pump. Should give way more years of use and a hell of a lot quieter than any aftermarket inline fuel pump would. I also put bigger, new 3/8" fuel line in which is what chevy used stock*
________________________
Well, I have my motor/tranny ready for the swap; 4.3 TBI/700R4... for my 84 4runner, 22R eng. My biggest snag so far is fuel. I've seen Downey's and A/A's inline fuel pumps, but it must be more involved than that right? I've heard of people that started out life with a 22RE using their stock efi set up and simply changing their pump to the correct psi/gph etc.
I've read many talking about aftermarket inline fuel pumps, but is that with no other mods to their fuel system??? Can you simply through an inline fuel pump on the line of a 22r, (granted it's for the 4.3 TBI eng), and throw the emergency cut off switch, for when the engine stalls??? Or is their more to it than that
I know Vova was going to use a 22re tank in his swap and then put the chevy tbi sending unit into this tank with minor adj... can I just do this with my 22r, (non efi) tank? And if I did use an EFI tank, isnt there more to it than just the tank? Alot more electronics, relays etc. on the 22re fuel system?
Thanks,
Jeff
FZJ80 40th - TLCA #8958
1984 4runner; rubicon tested mother approved SOLD
84runner is offline   Reply With Quote Quick reply to this message
Old 04-25-2004, 07:51 PM   #2 (permalink)
toydoctor's Avatar
Member # 26481
im doing the same swap..except ive got the running astro van for the swap...i just plan on intergating the van tank and lines into my toyota...should work fine...
"you like those spinning tires"- joe dirt
87 sami 16v toys, 35's yj's etc...
toydoctor is offline   Reply With Quote Quick reply to this message
Old 04-25-2004, 08:09 PM   #3 (permalink)
Member # 5329
Send a message via AIM to camo kid Send a message via Yahoo to camo kid
I hvae used both methods of pumps... ie. inline and in-tank. I liked the intank better overall. I just bought a pump for the vehicle, like a astro van for instance. It mated right up for me. I used stock lines and adapted th factory lines from the astro.
Theres lots of info on these swaps and a serch goes a long way around here with all the info from everyone.
Jeff
83 yota ex show truck,406,700r, marlin stuff,and now one ton with big swampers
camo kid is offline   Reply With Quote Quick reply to this message
Old 04-25-2004, 08:42 PM   #4 (permalink)
Member # 4836
Jeff
Camo Kid, are you saying you put the pump into a 22r tank? Just curious.
And about the whole search thing, thanks, been there done that. Like I said above I've read all there is to read, Lot's of info, fuel pump,, tanks, etc, but nothing with my specific question, thanks. Hence the post... And hey anyone want to prove me wrong pleeeez send me the link while your at it...
Old 04-25-2004, 08:51 PM   #5 (permalink)
Member # 5329
you need to use a efi tank... the pick ups are lots different...
Jeff
Old 04-25-2004, 08:55 PM   #6 (permalink)
Member # 4836
cool thanks. And that is "EFI tank" only? Nothing more from the EFI toy?
Old 04-25-2004, 10:14 PM   #7 (permalink)
Member # 19932
has anybody used a fuel cell in their 4runner. that is what i am planning on doing, but i cant figure out where to put it.
97 Landcruiser
Heckler is offline   Reply With Quote Quick reply to this message
Old 04-26-2004, 07:13 AM   #8 (permalink)
Member # 2986
Send a message via AIM to Chad
You can use the Toyota EFI fuel pickup/pump assembly as long as you dont' use the Toyota pump. It is too much pressure for a TBI system and trying to use a regulator to keep the pressure at about 13psi will just burn the pump up prematurely.
Just get the standard GM TBI intake pump and fab it onto the Toyota fuel pickup where the Toy pump was.
[color=yellow][b]Chad[/b]
ASE Master Certified Technician
Off-Road.com Forum Administrator
'84 Extra Cab, 5.29's, Detroit, '98 Vortec 4.3 & 700R4, 7" Skyjacker, etc.....[/color]
Chad is offline   Reply With Quote Quick reply to this message
Old 08-04-2006, 11:13 AM   #9 (permalink)
Member # 45106
Send a message via AIM to Yellowtoytruck Send a message via MSN to Yellowtoytruck
Will the efi tank bolt directly into a carbed truck?
"Roads? Where we're going, we don't need roads."
-Dr. Emit Brown, Back to the Future.
1985 Pickup 4.3 TBI, Th350. 5.29s. Lincoln Locked.
Yellowtoytruck is offline   Reply With Quote Quick reply to this message
Old 08-04-2006, 12:00 PM   #10 (permalink)
Member # 38563
I imagine someone makes a fuel cell with a TBI pump setup
84' M1031 CUCV 37's, 8kW gen
Pietro is offline   Reply With Quote Quick reply to this message
Old 08-04-2006, 12:03 PM   #11 (permalink)
Member # 24837
i think it'd be OK to run an external fuel pump with a carbed toyota tank. the tank doesn't care if the engine is EFI or carbed.
as for the cut off switch, if the 4.3 doesn't have something like it already, summit sells a fuel pump kill switch that plumbs into an oil pressure sender hole in the engine block, if the pressure goes to zero(engine goes off) it shuts the pump down.
'79 toy, 20R/22R hybrid with oversized valves, thorley header, offy intake and 32/36 weber
longbeds rock!
kyle_22r is offline   Reply With Quote Quick reply to this message
Old 08-04-2006, 01:50 PM   #12 (permalink)
FrankenToy's Avatar
Member # 36822
Correct.
Dr Floyd: Don't suppose you have any idea what the damn thing is, huh?
FrankenToy is offline   Reply With Quote Quick reply to this message
Old 08-04-2006, 02:18 PM   #13 (permalink)
Member # 1852
Send a message via AIM to dcg9381 Send a message via Yahoo to dcg9381
Why would it burn the pump up? The fuel by-pass allows fuel to flow back to the tank. A high pressure pump worked fine for me (bosche).
I used a carb'd tank and inline pump. I didn't have any problems. I've seen indications that some EFI applications need baffled tanks to prevent problems at low fuel levels.
dcg9381 is offline   Reply With Quote Quick reply to this message
Old 08-04-2006, 02:29 PM   #14 (permalink)
Member # 26330
Correct, but the engine will care when you have no baffles in the tank.
It's not what you drive it's how you drive it!!
vortectoy is offline   Reply With Quote Quick reply to this message
Old 08-04-2006, 07:36 PM   #15 (permalink)
2manyprojects's Avatar
Member # 39901
In tank pumps are believed to last longer also. Always cooled by the fuel surrounding them.
"]my 90 project [/URL]
Save a tree, eat a beaver.
There are two keys to life, leverage and lubrication. Sometimes you need both.
Because there is no 2nd chances on Pirate!
2manyprojects is offline   Reply With Quote Quick reply to this message
Old 08-04-2006, 09:53 PM   #16 (permalink)
Member # 37016
Would an inline pump like the walbro 255 supplie to much pressure or what kind of inline pump should you run. Also what size line would you run for this swap. I'm doing the same swap and have the same questions. THanks
65Chevy4x4 is offline   Reply With Quote Quick reply to this message
Old 08-05-2006, 07:57 AM   #17 (permalink)
Member # 4836
HOLLY SH!T! Way to bring back a dead post!
This post of mine was 2+ years old! Damn.
To answer your question though... Yes. And even though I bought a factory TBI 12-15PSI internal pump and fabbed it to fit in the stock toyota tank, I have seen guys since that just use the Toy EFI fuel pump with the TBI chevys. Granted the stock Toy EFI is higher pressure but the regulator on the intake will flow unused fuel back to the tank no prob. (wish I would have known that prior to my build)!
EDIT- I changed my fuel lines to the 4.3 lines, (I think they were 3/8 instead of stock 1/4). And I went with the in tank fuel pump since it is way cheaper and should technically last longer than external, (heat damage).
Remember too that 4runner and p/u tanks are the same except different in shape only. The 4runner dips down in the front to allow for the back seats. So; 4runner will fit p/u but p/u will not fit 4runner. Don't ask how I know this one!
Old 02-13-2007, 01:24 PM   #18 (permalink)
Member # 75530
Gauges
What about running an aftermarket gauge VDO, Autometer and so on.
I heard the toyota sender has something special about it?
Kevin
Ps went through the search thats where
I found this....
Kevin
kryan is offline   Reply With Quote Quick reply to this message
Old 02-13-2007, 02:54 PM   #19 (permalink)
Member # 20276
I just install a 4.3 tbi in my 85yota. It had a 22re in it. i just ran the factory pump with the factory lines. No problems. One thing i did notice was the amount on air presure come out the vent hose from the tank so i restalled the charcoll tank. Because of the large amout of fuel presure been returned to the tank.And the pump is just a hot and a ground. No special setup for them.
And dont try to use a pump over 15 psi with a holley aftermark throttle body. They can not regulate over 15 psi. They well over fuel your motor. I know. Leard the hard way.
01 RAM 2500 24V CUMMINS DD/Krawlerhauler
85 Yota Buggy 4.3/tb350/x2ler/2.5tons/42"s
Ramrock is offline   Reply With Quote Quick reply to this message
