Tech Topic the week: Front Bumpstops - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-23-2004, 09:54 AM   #1 (permalink)
Cranky Moderator
steveh's Avatar
Member # 2026
Send a message via AIM to steveh
Arrow Tech Topic the week: Front Bumpstops
With the amount of lift a lot of us run, bumpstops area must.
So, how do you figure out how much Bumpstop to use? IE, what should be considered when designing front bumpstops
  • What kind of bumpstop?
  • How much space for travel?
  • Standard vs. air or hydraulic?
  • Is it even Important??
A search turns up some info, but not really any process to follow to determine the design.
Results of Title search for "Bumpstops"
Some pics of various designs:
85 Toy Xtracab
"I DON'T want to understand !!"
Click here to donate to the Rubicon Trail Foundation
"Wow this is unbelievable"
2013 Cantina for the 'Con supporters!
WIN a fully built Toyota pickup at Cantina 2013
Davez Off Road and Trail Gear are supporting Rubicon Trail Foundation
We have returning Platinum sponsors for Cantina 2013 with Raceline Wheels and Falken Tires!!
steveh is offline   Reply With Quote
Old 06-23-2004, 10:01 AM   #2 (permalink)
Angry Gecko
flecker's Avatar
Member # 23744
Location: White Mtns., Arizona... it's on the map, just not on any map!
Energy suspension sells a huge variety of bumpstops... I always went by the "stop it where it hits, or binds anything" theory. As for important? Yeah I think so... Helps in all kinds of ways. Just MO.
I R A REVOLUTION LEADER!
flecker is offline   Reply With Quote
Old 06-23-2004, 10:25 AM   #3 (permalink)
Member # 1860
Here's the best way to periodically check them .....
derek
the more i play with it, the bigger it gets...... my truck that is
derek is offline   Reply With Quote
Old 06-23-2004, 10:30 AM   #4 (permalink)
Member # 16114
Send a message via AIM to bursemike Send a message via Yahoo to bursemike
on full stuff take a measurement from mounting surfaces and then add a 1/2" or so of give on the bump stop. Energy suspension is a great place to find them. Yes they are important and any type that is used is better than none at all.
bursemike is offline   Reply With Quote
Old 06-23-2004, 10:38 AM   #5 (permalink)
Member # 16789
This is what I've taken as a general rule of thumb, except I take my measurements from when the spring goes flat. It also depends on what style of bump stop you are using, and how tall it sits. JCA here on the board has done a couple of really nice set-ups on different vehicles. Maybe he will chime in.
The Parts Pimp.
Wanted! Solid axle steering boxes from 1979-1985 toyota pick-ups and four runners. PM me for details.
Wanted! Power assist Rams and Valves from 75-77 Ford F-250's. PM me for details.
$78 for Toyota front knuckle rebuild kits DELIVERED!! PM me for details.
montezuma is offline   Reply With Quote
Old 06-23-2004, 10:47 AM   #6 (permalink)
Bones's Avatar
Member # 3007
You can kinda see mine here. They are energy suspention ones. They collapse a fair amount. As you can see, not much uptravel at all and I am considering lowering it another inch. Shock is ~1/2" from bottoming out. Prerunning I'm sure it just might bottom out.
Today is the tomorrow you worried about yesterday
Bones is online now   Reply With Quote
Old 06-23-2004, 11:09 AM   #7 (permalink)
Banned
4RnrRick's Avatar
Member # 3933
This is my theories:
Before you can add bumpstops I make sure nothing is binding. How I do this is I flex up each of the 4 corners one at a time slowly and look at the following items while I steer the front tire back and forth. If I seen any major issues I stop and deal with that before I try any farther.
Steering linkage (drag link, tie rod, pitman arm)
Brake lines (enough slack, not rubbing anything)
Tire rubbing (frame, springs, sheetmetal, brakelines)
Shackles (hitting/binding , sideways flex, angle of them)
Springs (kinking, seperating too much, springs gapping, reverse arching)
After I make sure everything is safe and I don't damage anything flexing then I measure for bump stops. Its best to use factory vulconized rubber type bumps instead of they poly bumps. For me teh poly ones are just not strong enough and I end up ripping them off. Also since I sit really low my springs don't have much arch to start with so I do reverse mine a bit. I think my gap to the bumps are about 2 1/2 - 3" up front and 3-4" out back when the vehicle is on level ground. For me most of my flex is from droop and not stuff.
The other thing to take into consideration is that once the axle hits the bump stop the vehicle will then rotate on that bump so it needs to hit what ever surface perpendicular so it doesn't quirt out the side. hence thats why my bumps stops are installed at an angle.
4RnrRick is offline   Reply With Quote
Old 06-23-2004, 11:16 AM   #8 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
Some good replies so far here
BTW -the stock Toyota front or rear bumpstops are pretty nice actually, and are easily used in a variety of applications... Keep that in mind before you go spend the $$$ on aftermarket ones
>David
> 4x4Spot.com
>It only hurts the first time you agree with me...
>"A little nonsense now and then is cherished by the wisest men."
DRM is offline   Reply With Quote
Old 06-23-2004, 11:23 AM   #9 (permalink)
Cranky Moderator
steveh's Avatar
Member # 2026
Good stuff! Keep it coming, and I bet 4RnrRick will be adding the best of this to the FAQ!
85 Toy Xtracab
Old 06-23-2004, 11:37 AM   #10 (permalink)
Bones's Avatar
Member # 3007
I run stock ones in the rear, but could not find anymore locally so I nabbed the poly ones off the shelf at the poser shop. Held up great for a couple years. I have a nice 1.5" piece of tube on the flip plate for it to land on so it spreads out the load better.
Old 06-23-2004, 11:41 AM   #11 (permalink)
Grocery Getter
ErikB's Avatar
Member # 59
I used stock rear bumpstops welded to the frame and trimmed them a tad w/ a sawsall. I set them up so that they keep my drag link off the frame on the passenger's side and my spring off the drag link on the driver's side. I ended up with about 2.5" of vertical travel before the tips hit on flat ground. I'd like more compression travel, but stuff starts hitting...
Oh yeah, in the rear I've never had any bumpstops ever since I put in the Chevy springs. No problems...
ErikB is offline   Reply With Quote
Old 06-23-2004, 11:49 AM   #12 (permalink)
4CrawlR's Avatar
Member # 4716
Here's what I run (Energy Susp.):
Gives me about 3.5" of up travel, top of stop is about 5.5" off the top of the spring plate. I can change out the aluminum spacer to change the height of the stop if needed, may drop it down another 1/2" or so:
http://www.4crawler.com/4x4/4R_suspe...html#Bumpstops
4CrawlR is offline   Reply With Quote
Old 06-23-2004, 11:56 AM   #13 (permalink)
Roc Doc's Avatar
Member # 20631
I run the stockers in front, (run 44044's and 9012's), and the only thing I don't like is they're pretty damn hard. When you blow through the travel, Baja'ing it to the trail head, they slam pretty hard. The Enery Suspension type are a poor-man's air bumps, much more progressive.
I also run the stockers in the rear, spaced down from the frame rail with a 3" box tube, to keep my Chev's, and buggy leaf intact. Although I don't think I've ever actually used up all my up travel.
Doc
Doc
Buy my buggy.
Roc Doc is offline   Reply With Quote
Old 06-23-2004, 12:13 PM   #14 (permalink)
Member # 1860
STEVE!!!
derek
derek
Old 06-23-2004, 12:42 PM   #15 (permalink)
www.12voltguy.com
SeaBass44's Avatar
Member # 40
also plentyfull! I bet you and I have more then enough with the trucks we have parted out , that is if we kept them I would like to see the hydro ones, I've never seen them 4sale or a detailed write up of how to brew your own, just remember CAMO havin some, so I justy guess they are BIG$$$$$$$
12voltguy
info@12voltguy.com--davezoffroadperformance.com
# 530.532.4529
TTC 2010 1989 BRONCO
-Awesome web development for your business. www.mudnworks.com mud@mudnworks.com
Pat's W I D E TOYOTA Front Axle
--07 KTM 450XC----with "stuff"
SeaBass44 is offline   Reply With Quote
Old 06-23-2004, 12:54 PM   #16 (permalink)
Banned
4RnrRick's Avatar
Member # 3933
I've been running those for the last couple of years and now I consider them a consumable on the front axle! I'm constantly loosing them because they break off. My buddy has the factory ones remounted and has had no problems, and our suspension is almost identical. Heck I even think I've got a couple spares in my tool box! I usually get about 5-10 good trail ride on mine before they pop off. Guess that means I need more lift so the spring can take up more of the force before I bottom out on the bump. Or maybe I should have the 4runner go on a diet!
I think my problem up front is that the axle compresses on against the bump stop and then as the other side keeps drooping down, it actually pivots on the poly bump and puts a side load on the bump and eventually pops it right off the center pin bolt. And thats already with teh bumps installed at an agle to make them hit perpendicluar when I flex. if I go any more of an angle, they pop off if I hit a speed bump to hard!
I'm too lazy to find some factory ones and redo them again!
Old 06-23-2004, 01:08 PM   #17 (permalink)
4CrawlR's Avatar
Member # 4716
I have lost one myself and I do carry a spare. Its been about 3 years since I did lose the last one, so I guess I have better luck with them, knock on wood.
Old 06-23-2004, 01:45 PM   #18 (permalink)
GRMhick's Avatar
Member # 87
Location: I live in hotels tear out the walls I have accountants pay for it all
Send a message via AIM to GRMhick
I run the factory front bumpstops. They are welded to a piece of 2x4 tubing, which is welded to the frame. They contact the spring right when the spring goes flat. Out back I run stiff overloads, and call it good.
I run some rancho poly bushings on my other truck and like them more, as they are more progressive.
Those air bumps that are shown, if I am right, those are off of camo's buggy, and he made them himself.
Any chance you, or anyone else wants to post up about how they are made?
GRMhick is offline   Reply With Quote
Old 06-23-2004, 02:14 PM   #19 (permalink)
Brandon's Avatar
Member # 6
Send a message via ICQ to Brandon
I use my drag link on one side and my pitman arm on the other - shocks bottom on both sides LOL
curious as to why you say they are a must? One of these days I'll put em en but..
Coming out of the end of the trail saturday on the tahoe end I bottomed out a few times, slammed the drag link into the frame pretty good! Didn't hurt anything though..
This Space for rent!
Brandon is offline   Reply With Quote
Old 06-23-2004, 02:28 PM   #20 (permalink)
Banned
4RnrRick's Avatar
Member # 3933
IIRC, The air bumps are purchased. The brackets are custom....
Old 06-23-2004, 02:58 PM   #21 (permalink)
mobil1syn's Avatar
Member # 9795
Send a message via AIM to mobil1syn
nah camo and a friend built them ... cant seem to find the thread right now
going back to the basics
Originally Posted by ZukIzzy View Post
Oh and Frequency is for radios
We are all born Arminians. It is grace that turns us into Calvinists
-George Whitefield
mobil1syn is online now   Reply With Quote
Old 06-23-2004, 03:05 PM   #22 (permalink)
Brandon's Avatar
Member # 6
Bob Roggy sells em I believe..
Old 06-23-2004, 03:16 PM   #23 (permalink)
Banned
4RnrRick's Avatar
Member # 3933
Here you go...
Air bumps: http://www.polyperformance.com/air_bumps.htm
They are sweet but out of my price range!
Old 06-23-2004, 03:28 PM   #24 (permalink)
GRMhick's Avatar
Member # 87
Ya, out of my price range too, which is why i would like to see how they are made.
Chris, think with a set of air bumps I can keep up with nebel in the desert
Old 06-23-2004, 03:30 PM   #25 (permalink)
Member # 14116
I am running the same ones as Bones, but mine are mounted perpendicular to the frame (90* from pictured), which really helps with the side loading during articulation.
4x4Him.org
LouBell is offline   Reply With Quote
