22R aftermarket gauge ???s - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-02-2004, 09:34 AM   #1 (permalink)
Member # 32671
Send a message via AIM to jtenright
Hey Guys...I am a Newbie here
I am a prerunner guy myself, but got respect for all offraoders
I am thinking of getting some gauges when I build my cage
thinking of running a Oil pressure, oil Temp, and Volt
How do I hook these up? is it pretty straight forward?
are there oil temp/pressure senders already on the 22R?
thanks!!!
James
jtenright is offline   Reply With Quote Quick reply to this message
Old 07-02-2004, 11:28 AM   #2 (permalink)
Member # 10405
I can't wait to see the next few posts on this one.
Omt x4 is offline   Reply With Quote Quick reply to this message
Old 07-02-2004, 11:28 AM   #3 (permalink)
Member # 24837
that stuff should be a piece of cake. what year is your truck? if you have an '84-88 you can get an SR5 gauge cluster with all those in it. you'd just need to hook up the tach wire and install a $20 oil pressure gauge sender from toyota
aftermarket shouldn't be too hard either. for the oil at least, you can keep your idiot light as there's a hole in the block for installing a pressure sender(it'll work with an aftermarket one, mine does). i think there's a spare hole in the intake manifold that will work with an aftermarket temp sensor, and a voltmeter is pretty simple to hook up
kyle_22r is offline   Reply With Quote Quick reply to this message
Old 07-02-2004, 12:50 PM   #4 (permalink)
Member # 32671
cool thanks
I also did a search on the site and found some info
yea I am planning on doing aftermarket stuff
Do U guys use eletric or mech. oil temp and pressure?
Old 07-02-2004, 03:38 PM   #5 (permalink)
Member # 24837
electrical is often more expensive but definitely better. with something like a mechanical oil gauge, you have an oil line running into the cab...just imagine if it goes pop
Old 07-02-2004, 06:13 PM   #6 (permalink)
Member # 16789
Where in San Diego are you located?
shipping and free returns
Wanted! Solid axle steering boxes from 1979-1985 toyota pick-ups and four runners. PM me for details.
Wanted! Power assist Rams and Valves from 75-77 Ford F-250's. PM me for details.
montezuma is offline   Reply With Quote Quick reply to this message
Old 07-02-2004, 06:21 PM   #7 (permalink)
Member # 32671
Carmel Valley/Del Mar area, but
go to school up in San Luis Obispo so 80% of the year I am in SLO
Old 07-02-2004, 08:27 PM   #8 (permalink)
KLF
Member # 3910
Actually, if you talk to the AutoMeter guys, they will tell you the mechanical gauges are more accurate and reliable. But yeah, you have to run that darned capilary tube, which requires a large hole in the firewall for the temp gauge.
I personally don't trust the SR5 gauges, very innacurate.
'87 Toyota xcab SR5 - SAS'd, stuff
'07 Lexus ES350 - babe magnet
KLF is offline   Reply With Quote Quick reply to this message
Old 07-02-2004, 09:16 PM   #9 (permalink)
Member # 9001
Send a message via ICQ to Lord Orange Send a message via AIM to Lord Orange Send a message via Yahoo to Lord Orange
I had a mechanical one shear on me at johnson valley, and one on the rubicon get a pin hole in it.....oil was fawking everywhere. For now the factory ones are great because when your at extreme angles you don't what to know what your oil psi is.
Lord Orange is offline   Reply With Quote Quick reply to this message
