Member # 27943
Load sensing proportioning valve ???
alright i was wondering what you guys are doing with the Load sensing proportioning valve are you running it or by passing or how are you doing it i am running a eliptical system so i think it would be hard to run from at the back what about doing something like whats in cars where its programed to automatically do 60/40 braking im just wondering what you guys are doing and how it works, its a semi dd at least its road worthy to get to and from trails at least once its finished.
thanks for help |
Member # 4716
Here's what I did with mine many years ago:
![]() More info: http://www.4crawler.com/4x4/4R_suspe...ortioningValve |
Member # 15697
Put a manual prop valve in there, the stock LSPV was a great idea, but is unreliable, and doesn't really work that well. Get a manual prop valve, tune it just right and Toys will stop on a dime. I outbraked my friend in an Audi
Although I think a lot of that was knowing how to threshold brake properly.
Wait, what? |
#5 (permalink) | |
Member # 4464
this is the same thing i did.
only the dead have seen the end of war 1995 T100 - finally done (well, kind of) 1988 4Runner - DD (some days) 2005 Ram 2500 CTD, 4x4, NV5600 - Tow Rig 2013 E92 M3 - track toy |
if you don't want to replace it yet, just cut the arm short and zip strip it pointing up but the prop valve from summit is the deal.
[URL="http://www.pirate4x4.com/forum/showthread.php?t=530797"]Don't be the nice guy anymore[/URL] |
#9 (permalink) | |
Wicked Raciest !
Member # 30
David & Theresa, Roseville, CA, As long as my tires are dirty, I am happy!!!! ![]() http://www.davezoffroadperformance.com/ http://www.marlincrawler.com/ http://www.12voltguy.com/ |
My valve rotted out, since I run a lot of weight in the back and tow, I am not worried about locking up the brakes. They never really worked well before so i want a lot of brake. I have two lines running to the rear which are damaged as is the line from the valve to the rear soft line. I have a flare tool so i can make the necessary lines up. How do I go about eliminating the valve? Can I just use a tee to bring the lines together or is one a return that needs to be plugged?
I need to get this truck running again.
Jesse Fry Property Management Special Services www.jessefrymaintenance.com Hard work does not scare us! 1987 4Runner, 1986 4x4 Xcab |
#11 (permalink) | |
Wicked Raciest !
Member # 30
#12 (permalink) | |
Member # 17413
Seriously, its worth the $70. You wont regret it. Especially if you go disk brakes in the rear later.
[QUOTE=4whldude]thinking on getting ltb's 33 you guys like them on rocks how tall are they on 8 wheel[/QUOTE] |
#13 (permalink) |
I removed the valve and lines back to the front underneath the passenger door today. I plugged the return line in the front wheel well. Then I ran a new line from front to rear, bending it up and out of the narrow slot between the frame and tank. In the rear I cut the soft line bracket and welded it back at a better angle for my new line.
Brakes are better then ever. Only lock up if I really stand on them, they never used to lock up before. I actually have rear brakes now. Now all I have to do is replace the rotted exhaust I noticed while under the truck. Thanks for your help.
