new clutch making whining noise - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-16-2004, 09:14 PM   #1 (permalink)
brianc's Avatar
Member # 35672
Send a message via MSN to brianc Send a message via Yahoo to brianc
just replaced my clutch, flywheel, both bearings, slave & master cyl on 88 v6. Its a marlin clutch, and a reman flywheel. Now getting a whining noise when i let the clutch out. The noise stops when clutch is pushed in all the way or all the way out. Sounds almost like a loose belt but i know that is not it. Besides the noise the clutch works fine. did notice the pedal is a little light but thinking thats just cause the new slave & master (also may need to rebleed). Anyone have this problem? Ideas on what could be wrong? Is this normal for new clutch & flywheel?
Thanks,
Brian
00 GMC 2500 4X4
05 Funrunner Toy Hauler
02 WR250F
03 TTR125LE
New Offroad directory - add your site
brianc is offline   Reply With Quote Quick reply to this message
Old 11-17-2004, 06:07 AM   #2 (permalink)
Lowtorious's Avatar
Member # 2387
Send a message via AIM to Lowtorious
Mine did the same thing after I replaced all the same stuff; it had a real soft whine. It'll stop after break-in.
Lowtorious is offline   Reply With Quote Quick reply to this message
Old 11-17-2004, 07:08 AM   #3 (permalink)
Member # 27182
Could be your throwout bearing too. The reason it doesn't make that noise when the clutch is engaged is because the bearing doesn't have a load on it. Let the clutch out, and that's when your bearing will start to make noise. I hope that's not it and that it's a break-in thing, but it's entirely possible.
ToyotaGod85 is offline   Reply With Quote Quick reply to this message
Old 11-17-2004, 09:36 AM   #4 (permalink)
brianc's Avatar
Member # 35672
it was a new throwout bearing so it better not be bad. I checked it out before putting it in and it seemed fine.
00 GMC 2500 4X4
02 WR250F
03 TTR125LE
Old 11-17-2004, 09:47 AM   #5 (permalink)
Member # 23011
Just bcause it's new doesn't necessarily mean it isn't defective.
My is doing the same thing.
Defective throwout bearing.
vikingsven is offline   Reply With Quote Quick reply to this message
Old 11-17-2004, 09:48 AM   #6 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
Drive it for a while and see if it quits, TO bearings sometimes make noise for a bit. If it gets worse pull the tranny and see whats up. It could be a bad TO or since you live in California serve it some cheese to go with the whine!!!!!
Old 11-17-2004, 11:27 AM   #7 (permalink)
Member # 4677
Thanks,
Brian
A bad TO bearing would make noise (if it makes noise) when holding in the clutch -- max pressure/max spin -- which you say it does not. It would stop when the clutch pedal is released - no pressure/no spin. Since the pilot bearing can only spin when the clutch has been disengaged from the flywheel, it sounds like it could be a bad/noisey pilot bearing. I've done lots of clutch jobs over the years and never have had a defective TO bearing or pilot bearing out of the box, but it's entirely possible. I do not believe a clutch job with new parts should make ANY noise!! If the noise (whine) was in the tranny, you should hear it with the clutch out - right?
That's just my humble opinion.
Gnarls.
Gnarly4X is offline   Reply With Quote Quick reply to this message
Old 11-17-2004, 12:51 PM   #8 (permalink)
Member # 23011
I suppose it could be the pilot bearing also...
Old 11-17-2004, 02:35 PM   #9 (permalink)
brianc's Avatar
Member # 35672
it only makes a noise when the clutch starts to grab. So when u start letting the clutch out, no noise till u can feel it start to grab, then as let it out more and more it gets louder, when fully engaged then no more noise. I had a mechanic listen and he thinks its just the new flywheel and clutch groving. So plan to put more miles on it and see if it gets worse or better. as of now it only has about a quarter mile on it.
00 GMC 2500 4X4
02 WR250F
03 TTR125LE
Old 11-17-2004, 02:56 PM   #10 (permalink)
Member # 9001
Send a message via ICQ to Lord Orange Send a message via AIM to Lord Orange Send a message via Yahoo to Lord Orange
Mine does the same thing.....just run it or change the Throw out bearing and go with it.
Lord Orange is offline   Reply With Quote Quick reply to this message
Old 11-17-2004, 03:26 PM   #11 (permalink)
Member # 4677
I'm not there to hear it, but I don't think this is normal. If the clutch disc and the flywheel at contact are making that much noise, something is wrong with the surface of the flywheel or the clutch disc. Could you have the clutch disc in backwards? How smooth was the surface of the flywheel? Can you drive it around for 30 minutes with lots of stop and go to see if it goes away?
Gnarls.
Old 11-17-2004, 03:51 PM   #12 (permalink)
Member # 9001
almost for got....I snapped the cast iron things(want to call them supports) from transmission to block, that allowed the some of the bolts to back out from tranny to block...
Torque your shite...
Old 11-17-2004, 06:24 PM   #13 (permalink)
brianc's Avatar
Member # 35672
Gnarls.
clutch disk would only fit one way so i assume its in correct. Can not remember what the flywheel surface was like... i wanna say it was a little rough, not as smooth as the one i took out. Should be ready to drive home tomorrow so will run it around town for a bit and see if it gets better.
00 GMC 2500 4X4
02 WR250F
03 TTR125LE
Old 11-18-2004, 08:01 AM   #14 (permalink)
Member # 4677
If the machining on the flywheel was abnormally rough, driving it around will most likely "smooth" it out. Let us know.
Gnarls.
Old 11-24-2004, 11:25 AM   #15 (permalink)
Member # 37685
I recently install new clutch in my 88 runner 3.0. I used a cheap Luk clutch kit from pep boys. I also Had a whine when it was first installed. I believe it was the throw out bearing. It did go away afte a few day and a approx 100 miles.
longmirejl is offline   Reply With Quote Quick reply to this message
Old 11-24-2004, 03:59 PM   #16 (permalink)
Member # 4677
I don't know about what Pep Boys call "Luk", but Luk as a brand is one of the best clutch/pressure plate manufacturers around.
Gnarls.
