good reusable filters? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-06-2004, 04:54 PM   #1 (permalink)
Member # 24837
on my new motor that's going together i've got a generic 9x2 filter assembly. given all the crap i've heard about k&n filters letting dirt in and such, are there any other good reusable filters out there? i'd prefer not to have to buy paper filters...
kyle_22r is offline   Reply With Quote
Old 12-06-2004, 06:58 PM   #2 (permalink)
Member # 20208
Location: Pollock Pines, but dont worry, I decided to keep my full set of teeth, unlike most everyone else up here...
I dont know... My K+N has NEVER let in ANY dirt, and you should see the Rubicon and all of the other local trails around here in mid August!!!
Just make sure its oiled properly with the real K+N oil, and youll be good to go.
Cant beat the 1,000,000 mile warranty either.
[QUOTE=Myanarchy;6682920] Thanks for the tips, I think I'm gonna stick it between max volume and his boyfriend's pelvis. The force of their love could crush a bowling ball[/QUOTE]
sickfab is offline   Reply With Quote
Old 12-07-2004, 05:36 AM   #3 (permalink)
Member # 8203
amsoil filters get rave reviews from the Taco guys.
I've done K&N's but I prefer the paper filters.
super cool turbo 4runner
Sundowner is offline   Reply With Quote
Old 12-07-2004, 06:21 AM   #4 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
This is what I use to use on all the dirt bikes, now if I can just find them for the trucks!!!!
Uni High Performance Air Filters Facts
Open cell industrial grade filter foam represents the latest advance in air filtration technology. This section describes how and why it works so well when compared to the other three types also in common use. An optimum air filtering system is very inexpensive insurance against untimely replacement of rings, valves, bearings, and fouled spark plugs. These items represent very significant maintenance costs. Additional benefits are provided by higher performance, better gas mileage, and lower emission products.
With an engine operating at the optimum air-fuel ratio of 15 or 16 to 1 (air volume to gasoline vapor volume), it normally means that 10,000 to 15,000 "gallons" of air are sucked into the cylinders for every gallon of liquid gasoline in the tank. The exact volume of air, of course, depends on the engine displacement, RPM, and miles per gallon. For example, a 2800cc engine turning 2600 RPM at 55 MPH got 26 miles per gallon, and used 23,000 gallons of air per gallon of gasoline in the tank. You can imagine what 23,000 gallons of air and dust going into your engine every half hour would do if you had no air filtration at all.
Remember:
Amateurs ... Built the ark.
Professionals ... Built the Titanic
http://www.davezoffroadperformance.com/
http://www.marlincrawler.com/
http://www.12voltguy.com/
OOP'S is offline   Reply With Quote
Old 12-07-2004, 12:25 PM   #5 (permalink)
Member # 14489
Send a message via Yahoo to Daveyclimber
amsoil , they are much cheaper than a k&n and they seem to have a better reputation for filtering capability
NorCal Tree Expert Co. (530)527-2844
Need tree trimming/removal , need defensible space ?
Call us ,insured and licensed . Serving Tehama, Glenn, Shasta and Butte County
Daveyclimber is offline   Reply With Quote
Old 12-07-2004, 01:13 PM   #6 (permalink)
Member # 38341
I've run K&N's for years, but they sure do let in dirt. They are performance filters, but not that great for the engine. Trueflow makes REALLY good filters, not sure if they make anything that would work for you. I've seen their demonstrations at the SEMA show, top notch product.
http://www.trueflow.com/
HMI1 is offline   Reply With Quote
Old 12-07-2004, 02:47 PM   #7 (permalink)
Member # 37658
what are the options 4 a cone filter?, i've got a open element air cleaner
driftaco is offline   Reply With Quote
Old 12-07-2004, 03:46 PM   #8 (permalink)
Member # 20208
Well, whatever bro, I dont know what to say, except that I put
alot of trail miles on my junk, in the summer, primarily on the Rubicon, and it is dustier than a mother, ask anyone here that is local to the trail, and my intake is CLEAN. I still stand behind K+N. You just gotta treat them properly.
Old 12-07-2004, 04:28 PM   #9 (permalink)
miniyota's Avatar
Member # 5963
i've never had any problems with k&n filters letting dirt in. i live in a desert. the intake is always cleaner then with a paper. just gotta follow the directions and oil it well! they work great for me.
2001 Range Rover HSE 4.6
2001 BMW E39 sport package
miniyota is online now   Reply With Quote
Old 12-07-2004, 05:11 PM   #10 (permalink)
mx924's Avatar
Member # 36797
if the oil on the K&N dried out, or there wasn't enough applied, then that is probably how dirt gets sucked in.
mx924 is offline   Reply With Quote
Old 12-07-2004, 05:40 PM   #11 (permalink)
Member # 3607
We run a K&N inner covered by a Uni foam outer. even under racing conditions there is no dust getting in. Proper fitting and oiling are the key.
PacNORE.com and BlueCoyoteRacing.com * UTV 1997
BlueCoyote3 is offline   Reply With Quote
Old 12-07-2004, 06:24 PM   #12 (permalink)
Member # 20208
Originally Posted by mx924
if the oil on the K&N dried out...
Yeah, if you live on Mercury....
Old 12-07-2004, 07:06 PM   #13 (permalink)
Member # 24837
i'd spring for an amsoil filter...but they don't seem to have a universal size chart(car model lookup only) and the 9x2 filter doesn't seem to come stock in any cars...
Old 12-07-2004, 08:13 PM   #14 (permalink)
Chopperman's Avatar
Member # 2634
Click here Daniel Son
Chopperman is offline   Reply With Quote
