Solid Axle Caster ????"s - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-12-2002, 01:41 AM   #1 (permalink)
Member # 9864
Does anyone have a how-to web page on caster alignment? I've contemplated attempting it, but have never heard of anyone doing it until now. 4runner still has the push-pull steering and I bolted my torque rod after crossing three lanes of traffic during an emergency stop. It has Black Diamond 3.5" springs and Black Diamond XT shocks on the front as well as poly bushings everywhere. Eventually, I hope to install hy-steer as well as some flexy 5" springs such as Allpro's. My question is: How difficult is it to get accurate adjustments of caster on a solid axle? Has this mostly been done to trailer queens or daily drivers that see 20k miles per year? If it is not recommended to be done at home, Can anyone recommend a shop in Portland, OR or even in the Northwest. All suggestions and personal experiences welcome!
Thanks again guys,
Scott
FlatBroke1 is offline   Reply With Quote Quick reply to this message
Old 02-12-2002, 06:15 AM   #2 (permalink)
Member # 2133
Send a message via ICQ to 85TrailToy Send a message via AIM to 85TrailToy
2 ways to adjust caster; you can cut and rotate the knuckles or use shims between the spring and axle.
85 4Runner 4.88's 4.7's Lockers 35's Drivetrain/Gas tank lifted Dents all over
[b]9-11-01: REMEMBER DAMMIT![/b]
"Who's the fella owns this saloon?"
[QUOTE=4RnrRick]Whay would woul have poer to teh wheels if I'm in neutal![/QUOTE]
85TrailToy is offline   Reply With Quote Quick reply to this message
Old 02-12-2002, 07:52 AM   #3 (permalink)
44Runner's Avatar
Member # 9095
Send a message via AIM to 44Runner
If you can weld and grind, do it yourself. It will make your DD and trail rig drive better. There are plenty of how-to web pages out there. Sorry I don't have one on me right now but I'm sure someone else will chime in with one
44Runner is offline   Reply With Quote Quick reply to this message
Old 02-12-2002, 08:15 AM   #4 (permalink)
Member # 9927
look on the Suzuki BB or this BB for a thread entitled.....Rotating knuckles.
seabastard is offline   Reply With Quote Quick reply to this message
Old 02-12-2002, 11:17 AM   #5 (permalink)
Wilson's Avatar
Member # 7233
Not sure about toy axles, but factory castor settings for D44's is 6 degrees negative castor. As mentioned, you can adjust it by either rotating the knuckles or using shims. Shims should probably work for you, it seems like your angle shouldn't be that far out. I rotated the knuckles on my full width 12 degrees, then used a combination of 6 degree shims and milling (actually careful work with a grinder) the pad on the housing and rotating the other spring pad another 6 degrees. I used a simple dial angle indicator ($15 at sears) and placed it on my flat top knuckles to get the angle emasurement. My castor angle is actually 10 degrees negative now, but it drives fine, up to 80 mph, I haven't gone faster than that yet. From what I've heard, you'll start to have problems real fast as you approach or if you have a positive castor angle.
Old 02-12-2002, 11:25 AM   #6 (permalink)
4CrawlR's Avatar
Member # 4716
Here you go:
http://www.hunter.com/pub/undercar/2573T/steer.htm
BTW: Caster angle is probably *the* hardest thing to measure without special equpment. Best advice is to take it to an alignment shop to get a reading then take it home and correct it if needed:
http://4crawler.cruiserpages.com/4x4...shtml#Steering
4CrawlR is offline   Reply With Quote Quick reply to this message
Old 02-12-2002, 05:36 PM   #7 (permalink)
Member # 2892
Send a message via AIM to Pavement Pounder83 Send a message via Yahoo to Pavement Pounder83
hey wilson can i borrow that angle finder when i do my sas
Drew
Drew Reynolds
[SIZE="4"][COLOR="Red"]ECV 7-11[/COLOR][/SIZE]
1991 Toyota Ex Cab
All Stock
1993 Xr650L
[COLOR="Red"]
[/COLOR]
Isautia[88:54] Delta World, Town: PBB Broski
Pavement Pounder83 is offline   Reply With Quote Quick reply to this message
Old 02-12-2002, 07:29 PM   #8 (permalink)
Member # 6604
Send a message via ICQ to Mr. Bastard
[COLOR=Red][B][CENTER]1TONK5[/CENTER][/B][/COLOR]
Mr. Bastard is offline   Reply With Quote Quick reply to this message
Old 02-12-2002, 07:54 PM   #9 (permalink)
Battle Masher
Tydes's Avatar
Member # 9255
Send a message via Yahoo to Tydes
Leonards Off Road & Automotive
2615 Se 39th Loop. Hillsboro, OR. 97123
(503) 693-8689
SketchyOregonBoys
Tydes is offline   Reply With Quote Quick reply to this message
Old 02-12-2002, 08:09 PM   #10 (permalink)
Member # 9324
Send a message via AIM to T1H5_TA3 Send a message via MSN to T1H5_TA3 Send a message via Yahoo to T1H5_TA3
factory spec on a 84 was +2.5 deg not a whole lot esp when your used to looking at specs for a car..
87 zuk 1.3, soa, 31's, spartan in rear
T1H5_TA3 is offline   Reply With Quote Quick reply to this message
Old 02-13-2002, 01:44 AM   #11 (permalink)
Wilson's Avatar
Member # 7233
Drew
Yep, no problem
Old 02-13-2002, 09:12 AM   #12 (permalink)
Grocery Getter
ErikB's Avatar
Member # 59
44's have different caster settings depending on what vehicle they came out of. Example: I think its Scout 44's that have zero caster from the factory, which sucks...
Also, you've got the positive/negative thing backwards. You WANT positive caster. Negative would be bad...
http://aligncraft.com/terms/terms.html#FrontCaster
As Roger mentioned, its pretty difficult to measure caster (at least on a Toy axle), however on a D44 w/ flat top knuckles you can set an angle finder on the flat top to get an easy (appoximate) caster reading...
