as I said in the other thread I'm hacking the truck together for Moab. I wondered what your set up is all around. what lift, have you moved axles at all? what drive shaft blah blah blah.
Here is my problem. I'm 1 inch forward on the rear axle. 63" chevies, the bottom of the transfer is about an inch below the frame rail.
The front shaft (which is now in the rear) fits but will bind the CV if I drop the axle about an inch or so. That's with a 6* shim. I've just cut the perches off and rotated them about 15* and things are looking better. I'm going to go stick the axle back in real quick to see what happens.
Just curious as to what your set up is. If any of the stuff I have done is on your to do list than I want to share my info w/ you.
Jay
Jay
