So I recently did a SAS on my 93 4runner. When I put my axle together I was told to tighten the king nuts hand tight. I did this and it resulted in tire wobble. So then of course I took my axle all apart... tightened up the king nuts pretty tight. That made the outside bearing scrape against the washer. Made a nice squeaking noise and started to wear away the washer. Took it apart again... loosened the king nut a bit. Got tire wobble again.
So.... anyone have any info on how tight they should be... ft lbs.... recommendations...?
Here's the link to pics of it as well
http://community.webshots.com/album/276393302fIsnKK
here's some more you guys might like as well....
http://community.webshots.com/user/easy_c247
