Someone got a little torch happy with my front housing and burned up the hole for the centerpin on the longside. I didnt really worry about it because I knew I would be shimming it to match the other side in height anyway. the perches a little different from side to side so I dont think I should just measure off of the front of the perch. How can I measure it to make sure the pin is in the same place front to back on each side? I can eyeball the centerline of the axle and measure from that but I dont think that would be precise enough.
