Does any one know if i put sr5 buckets in my 93 extra cab pickup which has a 60 40 split now if they would be a direct bolt it fit if i took them out of another 93 extra cab. I know i could make them fit but i would rather have a factory bolt in on my seats.
Also i would like to switch to an sr5 steering wheel which im pretty sure will bolt right in. correct me if im wrong
Pretty much a direct swap. 3 of the 4 bolts per seat are supposed to just go in no problems. The 4th bolt, lines up with the hole but there is no threaded fastener underneath to screw into. So you need to come up with something to screw the bolt into. Usually some sort of blind hole fasterner will work.
and actually i did search but there was nothing on a truck around my year the posts i found were on old forerunners and a few on beleave it or not swapping in bench seats in place of buckets.
