for 2005
flatbelly
cut the frame off at the motor mounts
three link
SAW 2" airs, 18" rear, 16" front
lowered 4" from 2004
wheelbase up from 113" to 118"
radiator in the rear
full hydro
approach angle is about 110*
More Im forgeting to mention.......
Dima, you should stop by when your back in the area.
Yeah, sorry about that, we're having problems with our host right now, should be back up soon, give us a call (408) 496-6595 and come take a look at the shop, we've got a lot of good stuff in here right now.
You assume correctly, its our first run with the airs, so we're testing on our junk, we should have them dialed tomorrow, they are pretty touchy, they had some air for the urban wheeling, but for the pictures the rears are empty.
The lowrider has a build up in Gen somewhere. We hacked the back of the frame off and ran the tubing under the axle, reverse four link and bags.
1/4" solid rod, bent over a wheel hub, cut, grinded and welded. I figure that it took about 8 hours of work to get it all done, really sucked, but now that its done, it was all worth it.
ya good job. i really like your rig. the tube on it looks good and i like how its all connected together. the 2nd pic is my desktop background at the moment. mine will be there one day....
Go to link above essentialy for a year is was coilovers, four link rear, leafs up front. Forklift shot after second build
Threelink front SAW airs all four corners, flatbelly, narrowed front end, pushed the front axle forward, radiator in the back. dash lit on fire, so tore it all out and its a hacked together piece of aluminum for the moment, Ill re-do it when I have th time.
one from the rear, radiator is from a Cherokee, forgot what year, but its the ones you can find at pickandpull by the dozen, like early nineties. The came stock with an electric fan on ones side and clutch fan on the other, just grabbed two electric fans works great. Copper cause I can.
