I learned as much as i could from the F.A.Q. but want to drill down specifically, and clear up some confusion I have...
Can the IFS callipers and rotors be used on a solid axel without modifing the solid axel hub? or do you need to use the IFS hub... If so is any modification needed to use them on a solid axel?
What about L.C. fj40 rotors? They and IFS rotors are both 20mm thick right? The only difference is venting?
What specific years of L.C. fj40 rotors work with the IFS calipers? 81' and up? Are there any differences between the diffent years that will work?
Thanks in advance for your answers or for pointing me to the appropriate thread with the answers...
