I am thinking about using 1" tube for an exo. And then, in between the tubes on the lower half, plexy glass so the paint doesn't get scratched. whatcha think
How about if I thread the 1" and make it removeable... Make it easier to wash :smokin:Bones said:brilliant! use 90* elbows and conduit joints as well.
Hmmmm, wonder if I fill it with sand tooHomeGrown said:im thinking pvc pipe.
It'll look bluish-green once weathered as well4RnrRick said:No No No, go for the copper tubing so you can shine it up!!! Thats what REAL plumbers use.
I know what. Polish it with mothers polish, and clear coat it.. That way, it won't turn green.Bones said:It'll look bluish-green once weathered as well
wholey fawknuts, you da man...... :smokin:HomeGrown said:fill the pvc with some beer and put a tap on it. :beer:
Naw, 2 pipes, one inside the other (get your head out of the gutter), all the way around the entire exo. First pipe with a 1" OD and the second pipe with an 1 3/4" ID. Compress the inner pipe to about 300 lbs, fill the outer pipe with beer. After wheeling, decompress the inner pipe (remove the air) rapidly. This will cause a cooling effect on the inner pipe and chill the beer in the outer pipe. Drink and be merry.HomeGrown said:copper pipe lol now thats some bling. fill the pvc with some beer and put a tap on it. :beer:
I would only do that with an IFS rig..A stright axle won't hold up to 44's :flipoff2:crash said:
BTW, this is for the wifes rig. 45" lift and 44's
crap, guess I'll throw these rockwells awaymr4x42u said:I would only do that with an IFS rig..A stright axle won't hold up to 44's :flipoff2:
I've heard that bamboo has some pretty strong yet flexible qualities. Bend hoop here and there, couple of legs, a little triangulation, and voila!!!obex26 said:Fawk that use some wood tree stakes and wood glue. It only needs water to get it to curve and best of all it doesn't rust.
I wonder if the same thing would work for Pepsi!!!!!!!! :grinpimp:crash said:DAMN!!! We are onto something here.. How about we wrap the copper AROUND the pipe, and run chilled water thru it... Hey homegrown ya need a bussiness partner...
I think those styrofoam peanuts would be better - you can get several impacts with those before you need to replace them. With bubble wrap, you only get on POP.crash said:Has anybody thought about wrapping there exo with bubble wrap
HomeGrown said:lol holly shit bubble wrap now you are thinking. excepet everytime you get close to a tree your going to think a birf let lose. lol bubble wrap thats great.
