How much advance can a 22re take? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-27-2005, 07:50 PM   #1 (permalink)
Roc Doc's Avatar
Member # 20631
My engine was rebuilt by the PO, and it seems strong as hell, with good compression across the cylinders. It's got a Thorley header, a good 2.25" exhaust, an undertimined cam (I think it's a mild 252 type cam), and K&N in the stock air box, and "some head work". The thing is it runs best with 17 or 18 degrees of ignition advance, (unshorted), I mean it runs great! Good throttle response, no flat spots, and it pulls hard on up to about 5k before it runs out of breath.
Question is, can I run it with those two extra degrees of iginition advance? I don't hear any pinging, and it seems to run fine even on regular gas. Do you think the cam is allowing this?
Blue Coyote was saying their race truck responds well to advance, but I don't know what they've done to it internally.
Doc
Pussy!
Suck it up buttercup, pirate takes care of its own. Even when they are post whoring retards!
Roc Doc is online now   Reply With Quote Quick reply to this message
Old 09-27-2005, 07:57 PM   #2 (permalink)
Member # 35791
I have been running mine there for about 20,000 miles, no problems yet. I also run a hotter plug, and I richened the mixture two clicks via the cogged wheel under the black cover of the maf. Mine is bored, and also has a header and it runs pretty well for a deuce deuce.
twitch88 is offline   Reply With Quote Quick reply to this message
Old 09-27-2005, 08:03 PM   #3 (permalink)
BTC
Member # 36253
Well Assclown, if it runs good and does'nt detonate don't you think thats your answer.
BTC is offline   Reply With Quote Quick reply to this message
Old 09-27-2005, 08:28 PM   #4 (permalink)
Roc Doc's Avatar
Member # 20631
I know for each degree of advance we get here, you Canucks can only get about .7 degree's.
Dude, I was just fawkin' witch cha!
Bring your junk to SoNV or SoCal and I'll give you plenty of places to use your buddies POS winch!
Doc, who's always had a good time in BC
Pussy!
Old 09-27-2005, 09:29 PM   #5 (permalink)
Grim Reaper's Avatar
Member # 6726
Better never hear detonation on a RE. The knock sensor will hear it before you do and back off the timing.
Putting to much advance you may think your fine but actually dumping more advance then you are gaining because of the knock sensor. Not sure how you could check it under load to see how much advance you have and how much is backing off. On a GM you can run WINASDL on a lap top but never seen anything similar for a Toy.
[COLOR="Black"]Did you expect to find something deep and meaningful here?[/COLOR]
"He has all the virtues I dislike and none of the vices I admire." -- Winston Churchill
Grim Reaper is offline   Reply With Quote Quick reply to this message
Old 09-27-2005, 10:25 PM   #6 (permalink)
Member # 40315
How much total advance are you running? That's the number I'd be more concerned with. Use a nice light that you can adjust and rev it up.
Mine runs 38 degrees total, and I think that it's around 13 or so initial. I wouldn't go over 40 degrees total.
Yellow Yota is offline   Reply With Quote Quick reply to this message
Old 09-28-2005, 08:59 AM   #7 (permalink)
Roc Doc's Avatar
Member # 20631
I've got a good advance light, so I'll try that tonight, but I'm thinking that with the altitude that I do most of my wheeling at, I should be able to get away with a little extra.
Doc
Pussy!
