Is there a 22R Engine FAQ ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-11-2005, 08:16 AM   #1 (permalink)
Member # 11709
Is there a 22R Engine FAQ.
I am still having a backfire problem with my 83 22R.
Backfires when:
1)pedal is quickly pressed and released.
2)decending hills when it given some fuel
Changed plugs,egr,air cleaner, replaced AAP, timing 5* tried 0* BTDC based on the manual.
Altitude: 5000 feet.
TIA.........No Flames only the FACTS !!
LoneZuk, Louisville Colorado
LoneZuk is offline   Reply With Quote Quick reply to this message
Old 11-11-2005, 09:57 AM   #2 (permalink)
81_4xToy's Avatar
Member # 21027
Pull the dist. cap and twist the rotor to make sure that the mech. advance isn't froze up.
Quote by JeepRecoveryTeam: "I didn't realize you had a Jeep...That confirms it, you are clueless"
81_4xToy is offline   Reply With Quote Quick reply to this message
Old 11-11-2005, 10:59 AM   #3 (permalink)
trannyboy's Avatar
Member # 43456
shit i have that same problem i am going to check mine.if the mechanical advance is froze up will it cause any lose of power?mine has been doing this for years and i have more power than most 22r that i have driven in.lonezuk it could also be some sort of slight vacumn leak.check over all lines and replace any that seem shady
ECV 7-11 JACKASS WHEELERS PAIR-O-DICE , CA
Hello and welcome to La-La Land.
trannyboy is offline   Reply With Quote Quick reply to this message
Old 11-11-2005, 12:04 PM   #4 (permalink)
Roksamy's Avatar
Member # 752
either one of you guys have exhast leaks at the manifold?
I'm on a boat
Roksamy is offline   Reply With Quote Quick reply to this message
Old 11-11-2005, 12:17 PM   #5 (permalink)
Member # 11709
No exhaust leaks, already checked the fastners.
Will check the distributor tonight.
Old 11-11-2005, 12:42 PM   #6 (permalink)
4CrawlR's Avatar
Member # 4716
Check the dashpot under the throttle linkage on the throttle body or carb:
- http://www.4crawler.com/4x4/CheapTri....shtml#Dashpot
4CrawlR is offline   Reply With Quote Quick reply to this message
Old 11-11-2005, 12:50 PM   #7 (permalink)
Member # 11709
Does this part exist on a 22R (carb) ?
Old 11-11-2005, 01:51 PM   #8 (permalink)
4CrawlR's Avatar
Member # 4716
According to my '85 FSM, both 22Rs and 22REs have dashpots under the throttle linkage. Their purpose is to slow the closing of the throttle when you let off the pedal to prevent backfiring (and to reduce the high emissions caused by backfiring). Often there is an adjuster screw that falls out preventing the DP plunger from being depressed or someone in the past has removed it.
Old 11-11-2005, 02:05 PM   #9 (permalink)
trannyboy's Avatar
Member # 43456
that does exist and that would make a little more sense then a frozen advance in distrubitor.if dist. was frozen that should affect performance.might have to give that a shot.thanks for info no more hijack
Old 11-11-2005, 07:00 PM   #10 (permalink)
Member # 24837
no, but i could write one
'79 toy, 20R/22R hybrid with oversized valves, thorley header, offy intake and 32/36 weber
longbeds rock!
kyle_22r is offline   Reply With Quote Quick reply to this message
Old 11-11-2005, 07:36 PM   #11 (permalink)
Member # 11709
Checked the distributor and it does have movement.
When at the end of the easy movement, it still has additional movement
and makes a very slight click one can hear and feel.
Is this normal.
My truck has an idle up diaphragm (throttle positioner) and positioner adjustment screw. This screw is screwed all the way down on several parts carbs that I have (which I have not messed with).
Thought the idle up was used on trucks with an air conditioner, no air on this one !
There is no dash pot that you mention on my 83, I found an 1985 diagram and picture that does have one.
Old 11-13-2005, 05:08 AM   #12 (permalink)
Member # 11709
22r FAQ and BACKFIRE
Desperate, the carburetor on the 83 was replaced with the one from my 85 that does not backfire.
With the carburetor from the 85, the 83 backfires in the exhaust system when:
1) Pedal is quickly pressed and released.
2) Descending hills when it given some fuel
This leaves the emissions system, distributor and manifolds.
Old 11-13-2005, 05:48 AM   #13 (permalink)
Member # 18089
Have you checked and adjusted your valves?
From you other post....."83 22R backfire"
Originally Posted by Hoodlum
Have you?
Seriously, mine did the same backfire during the same instances you describe...
Even after a carb rebuild.
It ended up being my valves were slightly off. Set them right and violla, no more backfire.
I would have suggested the aap before the valves but you said...
...and I thought that was for sure on the list.
Something else I noticed before setting the valves right was a higher than normal pressure in the valve cover. Like enough to keep the air cleaner canister residually oily in the bottom. Oh yah...all valves were only about .001-.003 loose.
Good luck. Sure hopes it something easy like a valve adjustment for ya.
Reading the thread it seems you done everything suggested BUT check and adjust your valves. If they are just slightly out, it will cause the symptoms you describe.
It could be your timing chain is streatched just a tad. How many miles on it?
Yoats n stuff
Hoodlum is offline   Reply With Quote Quick reply to this message
