22re runs like ass please help! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-15-2006, 06:12 PM   #1 (permalink)
Member # 67501
ya, it just wouldent start one day and after cranking on it for an hour it finnally started.But when i give it more than an eitgth of throttle it boggs and misses and dies after a while.I pulled codes and it blinked 7 times than 11 times,both codes point to the tps and the ecm,so i replaced both of them,same ol shit I also put in a new fuel filter,afm,coil+ignitor,plugs+wires,coolant sensors.any advice would be great!
yotabewser is offline   Reply With Quote Quick reply to this message
Old 02-15-2006, 06:35 PM   #2 (permalink)
Member # 16719
please ups me your old tps, ecm, afm, coil/ignitor etc-i know they must be junk to you but i may be able to find a use for some of that old stuff. thanks.
jdrocks is offline   Reply With Quote Quick reply to this message
Old 02-15-2006, 06:41 PM   #3 (permalink)
Member # 49706
Location: Wherever I want to go and my trucks can take me!
check your intake hose for cracks. check all grounds(usually white/black stripe) make sure the afm flapper isn't stuck open. pull the plugs and see what they look like. or you could search. click on search and put in 22re and get ready to read your eyes out.
mdd0127 is offline   Reply With Quote Quick reply to this message
Old 02-15-2006, 08:14 PM   #4 (permalink)
Member # 3161
check your fuel pressure also. tell me you didn't run fuel injector cleaner through it. if so try some marvel mistery oil, about a 1/3 of quart to half a tank or so. if it is the fuel pump that may save it.
also compression check, timing check. look in the distributer and see if there is any water, or little pencil line looking things.
missouriman is offline   Reply With Quote Quick reply to this message
Old 02-16-2006, 03:10 PM   #5 (permalink)
Member # 67501
I just noticed that when i crack the throttle i hear a sucking noise from under the # 4 runner on the intake mani.i wonder if thats what is screwing with the response
Old 02-16-2006, 05:25 PM   #6 (permalink)
Member # 3161
pull fan belt, start it, take a hand held propane torch. (not lit )
blow it up under where you think the leak is, increase in rpm = leak
intake manifold gasket may have taken a dump.
Old 02-16-2006, 08:12 PM   #7 (permalink)
Member # 9001
Send a message via ICQ to Lord Orange Send a message via AIM to Lord Orange Send a message via Yahoo to Lord Orange
tell us what you did prior to it dieing...what did you change? Where you mall crusing? Curb hopping? Or where you actually wheeling? Did it over heat? Your gonna have to give me more than just it died.
Lord Orange is offline   Reply With Quote Quick reply to this message
Old 02-16-2006, 10:34 PM   #8 (permalink)
Member # 67501
I put my boat in the water,came back to the ramp at the end of the day and it wouldent start.It ran tits before, aside from a bit of a stumble at idle.Also ive been having problems with hot starts for a while (fire it up when its already worm and it would die unless i punched it.Thanks 4 the feedback!
Old 02-16-2006, 10:54 PM   #9 (permalink)
Member # 65966
What he said. Carb cleaner works great too. Check your intake tube and throttle body gasket, all vacuum hoses and replace any that are questionable. I did everything I could think of until my buddy told me to check the intake tube and sure enough there was a hole in the bottom from the PS pump pulley. In the year that I've had my 85 4R, 99% of all my issues have been from a vacuum leak.
somebourbon is offline   Reply With Quote Quick reply to this message
Old 02-17-2006, 03:43 AM   #10 (permalink)
Member # 52443
If you hear a hissing sound under the intake num 4 you should look at it. Not normal, and holes are bad. Holes in the header will cause wierd things and the junk smells of gasoline. So on the intake side Id say same thing.
Post some pics of the hole!
eVil.TwiT
A man that brings more trash from nature's trails than he brings to them is a hero.
ev13wt is offline   Reply With Quote Quick reply to this message
Old 02-17-2006, 10:43 AM   #11 (permalink)
Member # 3228
Send a message via MSN to Zrock
i had similar problem and had everything checked... The codes i pulled all pointed to TPS.... But since i knew the O2 sensor needed replacing i started with that and the problem disapeared...
Zrock is offline   Reply With Quote Quick reply to this message
Old 02-17-2006, 11:09 AM   #12 (permalink)
Member # 65966
The TPS won't cause the engine to run rough or not at all. The TPS sensor has a default fail mode. When I took my 85 4R in to have it smogged they had to check the timing by grounding the test connector. The computer would not relinquish control due to, later determined, a bad TPS. It still ran like a champ tho and I didn't have any trouble codes either.
