search down... 22re heater core?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-21-2006, 02:45 PM   #1 (permalink)
DeFazio's Avatar
Member # 56047
i fix one leak another starts coolent is leaking from the tube goin into the firewall to i assume the heater core... and i noticed i a stream of coolent leaking behind my console on to the passenger floor, i liftde up my floormat an there is a little puddle of coolent... so, my heater core is toast, right? what i want to know is if there is any way to bypass it, i dont give a fuck if i have heat or not, i just want the truck to run right.
**88 4x4 22re**
DeFazio is offline   Reply With Quote Quick reply to this message
Old 02-21-2006, 02:46 PM   #2 (permalink)
Roksamy's Avatar
Member # 752
Just roure the incoming and outgoing hoses together , viola , no heater
I'm on a boat
Roksamy is offline   Reply With Quote Quick reply to this message
Old 02-21-2006, 02:56 PM   #3 (permalink)
DeFazio's Avatar
Member # 56047
so take the 2 hoses goin into the firewall, out of the firewall, and hook them together??
Old 02-21-2006, 03:15 PM   #4 (permalink)
Member # 34769
Send a message via Yahoo to BigSlide
Yes. Pull off one of the hoses, run down to the hardware store to get a piece of pipe 2-3" long to fit the hose, connect with new hose clamps and you are happy again.
NOW: since you have done all that(bypassing the heater) run your truck a few days and see if you are still losing coolant. The problem I ran into was that the clamps on the hoses running into the fire were not tight; allowing leakage into the cab. Heck check this first before trying everything else. Another thing is to look at the pipes going into the fire wall to see if the coolant is staying in the heater core or if you simply had some loose hose clamp.
BigSlide is offline   Reply With Quote Quick reply to this message
Old 02-21-2006, 03:29 PM   #5 (permalink)
Member # 33438
Make sure to keep an eye out for more leaks, everytime you fix something the lost pressure you had with the previous leak is there again and thats why new problems surface. sooner or later, you'll get all the leaks fixed
binderbart is offline   Reply With Quote Quick reply to this message
Old 02-21-2006, 06:11 PM   #6 (permalink)
DeFazio's Avatar
Member # 56047
should the hoses going into the firewall just pull out after the clamp is off? i dont wanna yank on em if its gunna mess sumthing up.
Old 02-21-2006, 06:41 PM   #7 (permalink)
toy4crawlin's Avatar
Member # 5342
Location: Mid CA West Bay Area next to NASA Jet dudes! 3hrs to RUBICON!!
glad yo posted this and not me
I have not dug into mine yet
sometimes have water on passenger side floor but does not smell like coolant
Do you get a water noise in the dash sometimes, like water trickeling
toy4crawlin is offline   Reply With Quote Quick reply to this message
Old 02-21-2006, 06:55 PM   #8 (permalink)
DeFazio's Avatar
Member # 56047
i can see the water squirting on to my passenger floor from the heater core, haha...
Old 02-22-2006, 11:52 AM   #9 (permalink)
DeFazio's Avatar
Member # 56047
so can anyone tell me how the firewall hoses should come off? should i just pull as hard as i can to remove them or is there a specieal way?
Old 02-22-2006, 12:06 PM   #10 (permalink)
What The Fleck?!
flecker's Avatar
Member # 23744
Location: White Mtns., Arizona... it's on the map, just not on any map!
Try twisting them to break em' loose first, then wiggle them off.
If that doesn't work, your gonna need a plasma cutter and a Factory Service Manual for the secret tip hidden on page 972A...
They are hoses man!!! Come awn people...
SEARCH under HOSE removal
I R A REVOLUTION LEADER!
flecker is offline   Reply With Quote Quick reply to this message
Old 02-22-2006, 12:11 PM   #11 (permalink)
tanman2003's Avatar
Member # 19325
have you ever taken them out? they are hard as hell. so hard that i gave up and bypassed the heater.
tanman2003 is offline   Reply With Quote Quick reply to this message
Old 02-22-2006, 12:25 PM   #12 (permalink)
DeFazio's Avatar
Member # 56047
yeah, they definitly are a bitch to get off.
Old 02-22-2006, 12:27 PM   #13 (permalink)
brector's Avatar
Member # 192
Send a message via AIM to brector Send a message via Yahoo to brector
If it's that bad, a razor blade is your friend.
-Brian
1 ton yoda
I make nerd sexy
brector is offline   Reply With Quote Quick reply to this message
Old 02-22-2006, 12:34 PM   #14 (permalink)
What The Fleck?!
flecker's Avatar
Member # 23744
Oh yeah I've removed em'.... It ain't rocket science here. Either cutem, jab a screwdriver/pick between the hoses, razor blade em' amd replace the hoses all together (10 bux for new hose and some clamps) or get the damn plasma cutter and the manual!!!
And Tanman2003... get some of those grip exercise thingies, wuss.
Old 02-22-2006, 12:38 PM   #15 (permalink)
tanman2003's Avatar
Member # 19325
hell i couldent figure out if the hoses under the hood go through the firewall and onto the heater core tubes, or if the heater core tubes went thought the fire wall and then the hose goes over the tubes.
Old 02-22-2006, 12:51 PM   #16 (permalink)
What The Fleck?!
flecker's Avatar
Member # 23744
Thought the same thing, but they will bust loose. If they won't then just cut em' and razor blade off what's left on the tubes to remove the core... I see Defazio is in Washington and it would suck to have no heat for the rest of winter.... you can get the replacement core from checker or Vatozone for not that much!
LOOKY! $46 bux for a replacement! http://www.partsamerica.com/ProductL...or=Heater+Core
Old 02-22-2006, 01:20 PM   #17 (permalink)
tanman2003's Avatar
Member # 19325
i think that is for a rear heater.
Old 02-22-2006, 03:41 PM   #18 (permalink)
DeFazio's Avatar
Member # 56047
well a new 53 cent clamp seemed to have fix the leakedge on the inside and outside... wierd?
Old 02-22-2006, 04:36 PM   #19 (permalink)
What The Fleck?!
flecker's Avatar
Member # 23744
That is wierd....
Old 09-14-2009, 02:56 PM   #20 (permalink)
Member # 121469
I pulled the dash and heater out of my truck today so I could paint the interior, and I wasn't sure I want/need to put the heater back in.
I searched for "heater bypass", found this thread, and the answer I needed.
I'll post pics when I'm done.
Junk_truck is offline   Reply With Quote Quick reply to this message
Old 09-14-2009, 03:16 PM   #21 (permalink)
Member # 54522
if your getting leaks from those factory wire hose clamps replacing them with the worm drive hose clamps will help but you should think about replacing your hoses.
86 4runner 7MGE bobed, exo, SAS on 38s, 5.29, fully locked with duals/4.7 and 30spl longs
dopeassjackson is offline   Reply With Quote Quick reply to this message
