22re smog removal - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-09-2002, 09:10 AM   #1 (permalink)
Member # 2685
22re smog removal
Only found stuff relating to 22r's under the search.
How much can you remove as far as smog/emissions stuff with out removing too much?? Is it basically just a matter of removing smog pump, blocking EGR and plugging vacumn lines?? What vacumn lines should be left alone?? What else should I avoid?? Thanks
www.PoorBoys4wd.com
convertiyota is offline   Reply With Quote Quick reply to this message
Old 04-09-2002, 12:37 PM   #2 (permalink)
Member # 1246
I removed the EGR and all related components on my truck. The only vacuum lines I have hooked up are, vacuum booster, PCV hose front and rear, line to power steering thingy and vacuum hose to charcoal canister for the fuel tank.
Arnold is offline   Reply With Quote Quick reply to this message
Old 04-09-2002, 12:54 PM   #3 (permalink)
Member # 587
Arnold so you kept the PCV but removed the BVSV (sp?). I am converting my 22R to RE as we speak and did block off the EGR by making a plate.
eighty three on thirty eights and a nice tow rig too.
woody99 is offline   Reply With Quote Quick reply to this message
Old 04-09-2002, 02:29 PM   #4 (permalink)
Member # 1246
Actually, the BVSV is still on the intake. I just removed the lines going to it. I really didn't want to search/buy a plug for it.
Old 05-23-2008, 04:28 AM   #5 (permalink)
Member # 100827
Send a message via AIM to smewhtguy
Had to pull this back from the dead. I am trying to delete all the unessacary (sp) shit on my 87 with 22re as I am going to dovetail my front end and lose my inner fenders. The lessshit I have to relocate or even have under the hood the better so what has to stay?
I do math and stuff, on a professional level.
smewhtguy is offline   Reply With Quote Quick reply to this message
Old 05-23-2008, 11:42 AM   #6 (permalink)
Pook's Avatar
Member # 3370
Only thing other than PCV on my motor is the VSV for the fuel pressure regulater. Everything else is gone. Runs good, but I am throwing a code after running for a few minutes.
Pook is offline   Reply With Quote Quick reply to this message
Old 05-23-2008, 02:30 PM   #7 (permalink)
4CrawlR's Avatar
Member # 4716
You can eliminate that VSV, I've run mine w/o one for years:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/10.html
And it is not related to smog, so no issues with it's removal. Supposedly there to prevent some sort of hot start issue, but I have never encountered that problem since removing the VSV.
4CrawlR is offline   Reply With Quote Quick reply to this message
Old 05-23-2008, 03:24 PM   #8 (permalink)
Hillbilly's Avatar
Member # 857
just in time! I'm ready to strip down my 22re of it's smog equipment and get rid of the rats nest
Hillbilly is offline   Reply With Quote Quick reply to this message
Old 05-23-2008, 03:31 PM   #9 (permalink)
Member # 106389
egr is a good thing. helps reduce pinging by cooling the combustion chamber.
your engine will last longer and run cleaner if you dont F with the egr. dont think by disconnecting the egr, it will gain power.
gus straussen is offline   Reply With Quote Quick reply to this message
Old 05-23-2008, 03:47 PM   #10 (permalink)
Grim Reaper's Avatar
Member # 6726
Yeah when gas is $4+ a gallon remove the EGR. It only improves MPG keeps detonation down at steady cruise and helps prevent burning valves. When operating properly it never hurts performance. Its not needed becasue you don't understand what it does.
While you are at it pull the EVAP can too. It only takes fuel fumes and burns them. After all burning fuel vapor is stupid when you can dump it to atmosphere and then instead of you fuel system being totally closed and water proof and pulling water vapor out of the tank and flowing it in through the intake air charge where it won't hurt anything you can now collect water with your fuel tank pump it through the injectors to help cool those burning valves.
Remove nothing. None of the emissions controls on a 22RE hurt performance at all. Most actually help.
The only thing I would by pass is the VSV for the fuel pressure regulator becasue chances are it doesn't work.
[COLOR="Black"]Did you expect to find something deep and meaningful here?[/COLOR]
"He has all the virtues I dislike and none of the vices I admire." -- Winston Churchill
Grim Reaper is offline   Reply With Quote Quick reply to this message
Old 05-24-2008, 11:01 PM   #11 (permalink)
Member # 109133
Does any one have more pitures of a cleaned up engine, where one can see whats gone and how it was bt passed etc. ?
86 Ext Cab,4" TG fronts,Chevy rears,duals,5.29 Aussie Lockers F&R, 30 spline Longfields,36" Irocs
AZroper is offline   Reply With Quote Quick reply to this message
Old 05-26-2008, 10:54 PM   #12 (permalink)
Member # 109133
bump
Old 05-26-2008, 11:12 PM   #13 (permalink)
Member # 89286
bump
bump x2
tyler840 is offline   Reply With Quote Quick reply to this message
Old 05-27-2008, 09:37 PM   #14 (permalink)
Member # 109133
Originally Posted by tyler840 View Post
bump x2
Bump again, still hoping to see some pics of a cleaned engine, no more damn hoses over hoses, please show us what we can get rid of and how.
Old 05-30-2008, 09:53 AM   #15 (permalink)
Member # 89286
x2
Old 05-30-2008, 11:27 AM   #16 (permalink)
MtnYota's Avatar
Member # 83913
What is it you guys trying to gain by removing everything? You are not going to get any noticeable power gain if any.
I agree with Grim, leave it alone.
My $0.02
'85 Xtra Cab 3rz,Duals, D60/14b, Detroit front/rear, 35spline chromos,rears/chevys, bad temper
MtnYota is online now   Reply With Quote Quick reply to this message
Old 05-30-2008, 11:40 AM   #17 (permalink)
DWT
DWT's Avatar
Member # 19850
I pulled all the emmissions off my truck to get it out of the way. All that crap on the engine made it a bastid to adjust the valves and whatnot. Now that its gone I have a much nicer looking engine that still performs just like I want it to.
'89 auto x toyota pickup, most fun I've ever had with my clothes on.
Taiwanese Garbage should stay in Taiwan.
DWT is offline   Reply With Quote Quick reply to this message
Old 05-30-2008, 02:13 PM   #18 (permalink)
Member # 109133
ok, cool, do you have pics ? and can you tell us what all you took of and how you by passed things that need to be hooked up ?
Old 05-30-2008, 04:06 PM   #19 (permalink)
DWT
DWT's Avatar
Member # 19850
The only things I still have hooked up is the PCV valve, charcoal canister, fuel pressure regulator and brake booster. The rest of it got removed and the nipples got vacuum plugs.
I hooked the pressure regulator and charcoal canister to the big nut deal with 3 nipples on it in the picture 4 crawler posted. Problem solved...
If you REALLY need a pic to show you that then I guess I can snap one off for ya but its pretty damned simple...
Old 08-22-2008, 06:35 PM   #20 (permalink)
Member # 118779
still no pics?. and i have a 1984 runner. and the lines must be blocked by now it has to much crank case pressure/[blown a gasket].. probably from faulty PCV valve.i fixed the leak but has the pressure.[no time to look at it] im not quite ready to spend all this money on mew hoses and parts so im better off removing it....
d_trueman@hotmail.co is offline   Reply With Quote Quick reply to this message
Old 08-22-2008, 06:52 PM   #21 (permalink)
Member # 106389
there is no reason to remove anything but the air pump. and on a RE there is none. Fuckin maroons. I bet you think those pipes on the exhaust manifold is the EGR.
Raccoons have green blood don't worry about the fluid.
Old 08-23-2008, 02:23 PM   #22 (permalink)
Erick561's Avatar
Member # 100293
Location: I ship from New London County Connecticut & Undercut
Send a message via AIM to Erick561
Everyone says it's good to have those things hooked up, but it really does look like a mess. Here's a before picture, and I'll post here after i pass emissions for the last time (this is an 84 celica)
Erick561 is offline   Reply With Quote Quick reply to this message
Old 08-23-2008, 09:28 PM   #23 (permalink)
Member # 118779
and thats a EFI none the less.
Old 08-28-2008, 01:28 AM   #24 (permalink)
Member # 44628
Can someone chime in on the charcoal canister removal, I've searched and read all the FAQ’s and am now 4 pages back trying to find something that cover's the removal of this part of the vacuum system. I'm going to a fuel cell because I'm chopping the back off and do not need the charcoal canister setup any longer..... Any help would be appreciated thanks
Eight Seventy Fabrication
RIP Davey Kyle Halabuk
yotaphil is offline   Reply With Quote Quick reply to this message
Old 08-28-2008, 08:57 AM   #25 (permalink)
Erick561's Avatar
Member # 100293
I can help with that. ON my 87 2wd, the 2nd gas tank line coming into the engine bay which is supposed to have the charcoal cannister hooked up to it goes directly to a 'barb' (for lack of the right word) on the carb. The gas tank fumes will in part go right into your intake. TOUCHE!
It is the hose that starts narrow on the 2nd tank line, which gets wider and goes into the bowl of the carb, i believe.
