4 Door Tacoma at the Jambo - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-27-2006, 02:10 PM   #1 (permalink)
Jason R's Avatar
Member # 11598
There was a white 4 Door Taco running around the Jambo. Looked pretty nice...fabricated axle housings...Solid axle front. Anyone get any pics of this thing, or have any specs?
It'd be interesting to know the wheelbase on it as well. Seemed like a nice 4 passenger rig!
This space for rent.
Jason R is offline   Reply With Quote
Old 04-27-2006, 02:22 PM   #2 (permalink)
Member # 2115
go to TTORA and ask there, you have better chances there than here.
1 ton '48 Willys in progress
alienjeep is offline   Reply With Quote
Old 04-27-2006, 02:24 PM   #3 (permalink)
blacktoy's Avatar
Member # 22837
captkirkyota...
[URL=highvibesoffroad.com]highvibesoffroad.com[/URL]
blacktoy is offline   Reply With Quote
Old 04-27-2006, 02:25 PM   #4 (permalink)
TheBandit's Avatar
Member # 30965
Was it captkirkyota's?
/forum/toyota-tacoma/382512-new-tacoma-tube-bumper-winch-pics.html
*EDIT* LOL blacktoy barely beat me to it!
---Cancer Survivor Since 10/06---
TheBandit is offline   Reply With Quote
Old 04-27-2006, 02:29 PM   #5 (permalink)
blacktoy's Avatar
Member # 22837
hard for me to forget his rig, makes me want to chop up my DD ...
Old 04-27-2006, 02:50 PM   #6 (permalink)
Member # 45196
yeah he was there and that things bad ass
96 taco, lockd, linkd, caged, beat, daily driven 24" frame on 4dz ready to jump
toy86 is offline   Reply With Quote
Old 04-27-2006, 02:50 PM   #7 (permalink)
Grocery Getter
ErikB's Avatar
Member # 59
That rig definitely caught my eye at the Jambo too. NICE!
ErikB is offline   Reply With Quote
Old 04-27-2006, 02:55 PM   #8 (permalink)
Chopperman's Avatar
Member # 2634
x2
Chopperman is offline   Reply With Quote
Old 04-27-2006, 03:15 PM   #9 (permalink)
Brian Ellinger's Avatar
Member # 1088
65" wide front, 64" rear
FF rear, now 5.29
front HP, arb, 5.29
was 37's, now 40" mtrs.
I think 5" suspension, alcan springs. auto of course, and crawler. Nice ride for sure!
Thank you to our loyal customers!
Diamond Axle
http://www.diamondaxle.com
Diamond axled buggies take 2 1st's, at Worlds WEROCK!!
Front Range Off-Road Fab with NEW forum!
http://www.frontrangeoffroadfab.com
NEW BUILD FTOY #44
/forum/toyota-formula-toy-forum/562295-front-range-builds-new-toy-old-toy-44-a.html
Brian Ellinger is offline   Reply With Quote
Old 04-27-2006, 03:34 PM   #10 (permalink)
Jason R's Avatar
Member # 11598
Thanks, anyone know what the wheel base is?
Old 04-27-2006, 03:52 PM   #11 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
Yep, caught my eye also, nice rig. Saw him as I was coming to get my rig waiting by the road, he had a blown diff and was waiting for his Dad to come from Barstow with the tow rig!!!!!
Remember:
Amateurs ... Built the ark.
Professionals ... Built the Titanic
http://www.davezoffroadperformance.com/
http://www.marlincrawler.com/
http://www.12voltguy.com/
OOP'S is offline   Reply With Quote
Old 04-27-2006, 05:30 PM   #12 (permalink)
generalee7's Avatar
Member # 16522
If I remember correctly, he blew his gears up in AZ a couple weeks ago too. Some shitty luck you got goin' on there Kirk
-Brian
01 4 door Taco- soon to be 3 link on tons with 40's
generalee7 is offline   Reply With Quote
Old 04-27-2006, 05:40 PM   #13 (permalink)
Banned
Member # 56946
clean....
eightyfive is offline   Reply With Quote
Old 04-27-2006, 05:58 PM   #14 (permalink)
BCzuk's Avatar
Member # 21320
I was checking it out on the lakebed super clean rig
BCzuk is offline   Reply With Quote
Old 04-27-2006, 06:19 PM   #15 (permalink)
captkirkyota's Avatar
Member # 36101
Thanks evryone.
I had a great time, even though I blew up my rear again. It seems I can talk to 20 people and 10 will say 40's are to big for a Tundra rear, and the other 10 say no way, should be fine, dudes are running 42's filled with water, making the tire too heavy to lift for one person and they don't blow the 3rd up. So I'm in a quandary to say the least.
Specs here.....
2001 Tacoma Double cab SAS conversion.
At the time of my build my truck was set up as follows, only MINOR things have changed liked tires, wheels and new bumpers etc.
Approx 12 inches of lift including 2" Body lift.
37 in Irok Radials
15x10 in MT classic 2 wheels
Custom width Diamond axles front and rear 4 inches wider front and rear from stock.
Front is 65 inches wide from WMS to WMS Inners are Longfields 30 spline.
The 3rd member in the front is a toyota HP 8" with 4.88 gears with an ARB locker
The rear axle is 64 inches wide and also has chromoly inners with a toyota 8" 3rd with 4.88's and an ARB and is a full floater with disc brakes. ( FROR set up )
The spring hangers, frame plating, steering box mount, cross member, and shackles on the front are all from Front Range Offroad Fab.
A 90's toyota IFS steering box is used to turn the truck, with Marlin Crawler High steering kit and pitman.
The front leafs are from Alcan Springs made to Tacoma weight but made the same as
85 Toyota Front stock length
3.0" lift
7 Leaf pack
7)- 7mm thick leafs
2.0" Center pin Offset toward the front
The rears are also Alcan and spec as follows
00 Tacoma Rear stock length
5.0" Lift
3)- 7mm Thick Leafs (8leaf pack)
1-1/2" extended on the tail
I also have a Front Range Offroad Fab clock-able Transfer-case cross-member
I am running 14" travel Bilstein 5150's all around.
Summit rear brake manually controlled proportioning valve.
Custom front bumper, warn 9.5 xp winch
rear is clearance cut with custom bumper.
PSC hydro assist steering kit.
Inchworm gear crawler clocked at 30 degrees and an almost flat pan skid custom made.
More pics and such here.... http://www.pirate4x4.com/forum/showp...7&postcount=68
[FONT="Comic Sans MS"] [SIZE="2"][COLOR="Yellow"]Truck specs:2001 D-cab Taco with solid axle conversion, front and rear 65" wide Diamond axles, Tundra 8 inch rear w/ARB, H.P. front w/ARB 30 spline Long's, full floating rear from FROR and blah blah blah, IE lots-a cool stuff.[/FONT][/SIZE][/COLOR]
[COLOR=Red][SIZE=4][FONT=Comic Sans MS]Later~[/FONT][/SIZE][/COLOR][COLOR=White][SIZE=4][FONT=Comic Sans MS]captkirkyota[/FONT][/SIZE][/COLOR][COLOR=Blue][SIZE=4][FONT=Comic Sans MS]~Kirk[/FONT][/SIZE][/COLOR]
captkirkyota is offline   Reply With Quote
Old 04-27-2006, 07:31 PM   #16 (permalink)
Jason R's Avatar
Member # 11598
so what's the wheelbase....?
Old 04-27-2006, 08:32 PM   #17 (permalink)
Member # 36101
I just measured from front edge of rim to front edge of rim and it is 125 and 3/4 inches.
Old 04-28-2006, 09:57 AM   #18 (permalink)
Jason R's Avatar
Member # 11598
You didn't have to go out and measure it..but thanks dude!
How's that wheelbase for the rocks?
Old 04-28-2006, 10:16 AM   #19 (permalink)
Member # 39857
That front bumper is the shit....
Cackfaka...
"Even if their name was "the sunhine and lollypop wheelers" they were still a-holes." - Red_Baron6
808toy is offline   Reply With Quote
Old 04-28-2006, 03:54 PM   #20 (permalink)
Member # 36101
So far I have not really encountered a trail, and I wheel a ton on hard stuff, where I was wishing it was shorter. I may have had to work at a spot or 2 more than a shorter rig, but because I'm used to it, I really don't notice it as a shortcoming. I KNOW that I have benefitted plenty from the longer wheelbase on some obstacles that short ones struggled or had to winch on, because my front tires made it up and over a lip and could pull me up where the shorter rigs just could not climb up. so overall, I am very pleased and really only want to resolve my 3rd member nuking problem.
